[GeoNode-users] Error 405 not permitted
Alessio Fabiani alessio.fabiani at geo-solutions.it
Thu Feb 18 01:07:51 PST 2016
Nice,
good to know that you debugged the issue, and thanks for your analysis and
feedbacks.
It would be nice if you could open an issue on GitHub about this problem
and if you like propose the patch to fix it.
Eventually I'll try to find some time in the next days to refine the patch
and envisage a test case to attach to the PR.
Best Regards,
Alessio Fabiani.
GeoServer Professional Services from the experts!
Visit http://goo.gl/it488V for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 333 8128928
http://www.geo-solutions.it
*AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
On Thu, Feb 18, 2016 at 10:01 AM, David Alda Fernandez de Lezea <
dalda at hazi.eus> wrote:
> Hi,
> > GeoNode supports any SRS because geoserver does. The 900913 and 4326 are
> the two supported by the mapping client for visualisation purpose.
> Originally was supported only the 900913 and recently > the 4326 has been
> added, but this doesn't impact the way the data are stored but only how
> they are requested to geoserver.
> I know, I know, but what I meant is that in
> http://192.168.1.190/admin/layers/layer/568/  (DJANGO admin page -->
> Layers) in some way some information about the SRS's is stored (900913 and
> 4326) See the image attached. No problem with that. My tests confirmed that
> even though my global SRS was in EPSG:3857, in the geoexplorer view
> (layer_geoext_map.html) I was getting the information about the extent of
> the layer in EPSG:4326 so I started to change things in this file. But it
> wasn't the right place.
> In the end I came to realize that the file to edit was
> geonode/layers/views.py in which information about the layers is retrieved
> to build the "layer_detail.html" web page. So inside the function
>         def layer_detail(request, layername,
> template='layers/layer_detail.html'):
>         in Line 227 I added
>             config["srs"] = 'EPSG:900913'
>             config["bbox"] = llbbox_to_mercator([float(coord) for coord in
> bbox])
> My reasoning was that as during the configuration of the GXPMAP object the
> SRS was the 'DEFAULT_MAP_CRS', which I set to 3857, but the bbox of the
> layer was in Geographic coordinates so there was a coordinate difference
> that caused that the layer was positioned far away from where it was
> supposed to be, so I forced the SRS (although it is not stored like that)
> to be 900913.
>         config["srs"] = getattr(settings, 'DEFAULT_MAP_CRS', 'EPSG:900913')
>         config["bbox"] = bbox if config["srs"] != 'EPSG:900913' \
>                 else llbbox_to_mercator([float(coord) for coord in bbox])
> It's a bit messy but I've finally made it work (for the moment). :-D
> Alessio, I'll take a note about the advancing logging you proposed for
> future problems.
> Maybe this could help to someone else.
> Thanks both of you.
> Regards,
> Agur bero bat,
> David Alda Fernández de Lezea
> Área de Sistemas de Información Geográfica, Planificación Territorial y
> Forestal Informazio Geografikoen Sistemak, Lurralde eta Baso Antolaketaren
> Arloa.
> dalda at hazi.eus | www.hazi.eus
> T 945 003 240 – M 627 923 170 – F 945 003 290
> Hazi | Granja Modelo de Arkaute s/n | 01192 Arkaute – Araba
> *********************  LEGE OHARRA   *******************   AVISOLEGAL
> *******************   DISCLAIMER   *****************************
> Mezu hau pertsonala eta isilpekoa da eta baimenik gabeko erabilera
> debekatua dago legalki. Jasotzailea ez bazara ezabatu mezua, bidali eta
> kontserbatu gabe.
> Este mensaje es personal y confidencial y su uso no autorizado está
> prohibido legalmente. Si usted no es el destinatario, proceda a borrarlo,
> sin reenviarlo ni conservarlo.
> This message is personal and confidential, unauthorised use is legally
> prohibited. If you are not the intended recipient, delete it without
> resending or backing it.
> De: Simone Dalmasso [mailto:simone.dalmasso at gmail.com]
> Enviado el: miércoles, 17 de febrero de 2016 16:23
> Para: David Alda Fernandez de Lezea
> CC: Alessio Fabiani; geonode-users at lists.osgeo.org
> Asunto: Re: [GeoNode-users] Error 405 not permitted
> Hi David,
> just a clarification on the supported SRS. GeoNode supports any SRS
> because geoserver does. The 900913 and 4326 are the two supported by the
> mapping client for visualisation purpose. Originally was supported only the
> 900913 and recently the 4326 has been added, but this doesn't impact the
> way the data are stored but only how they are requested to geoserver.
> 2016-02-17 12:12 GMT+01:00 David Alda Fernandez de Lezea <dalda at hazi.eus>:
> Hi,
> Thanks for your response Alessio.
> I think it has nothing to do with what I mentioned previously. I’ve
> checked the contents of each tile of the preview image and I’m getting some
> coords really away from our extent although the SRS is OK. My mistake.
> -76.43702827394,0,0,76.43702827394
> I've added to the javascript code a coordinate transformation. Now it
> zooms to where it should, but it doesn't load the layer.
> Would this probably be related to the fact that GeoNode supposes that
> everything that comes with an SRS different from EPSG:900913 it turns to
> EPSG:4326?
> Because in the Django admin web, I've seen in the layers properties that
> there's a field SRS (filled with ESG:4326) and other fields with the
> corresponding bbox.
> Is there a way to change this programatically?
> In which python is this set?
> Thanks and sorry for the mistake.
> Regards,
> Agur bero bat,
> Arloa.
> kontserbatu gabe.
> De: alessio.fabiani at gmail.com [mailto:alessio.fabiani at gmail.com] En
> nombre de Alessio Fabiani
> Enviado el: miércoles, 17 de febrero de 2016 10:05
> CC: geonode-users at lists.osgeo.org
> Mmm,
> I'm not fully sure this method is valid
>  url:"/gs/" + workspace + layer.params.LAYERS
> I guess /gs/ is a GeoNode Proxy to GeoServer, used by GeoServer itself to
> get the authorization rules from GeoNode.
> I'm not fully sure the workspace is supported, but I may be wrong.
> Best Regards,
> Alessio Fabiani.
> @alfa7691
> GeoSolutions S.A.S.
> Italy
> http://twitter.com/geosolutions_it
> Le informazioni contenute in questo messaggio di posta elettronica e/o
> principi dettati dal D.Lgs. 196/2003.
> The information in this message and/or attachments, is intended solely for
> the attention and use of the named addressee(s) and may be confidential or
> proprietary in nature or covered by the provisions of privacy act
> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
> Code).Any use not in accord with its purpose, any disclosure, reproduction,
> copying, distribution, or either dissemination, either whole or partial, is
> strictly forbidden except previous formal approval of the named
> addressee(s). If you are not the intended recipient, please contact
> immediately the sender by telephone, fax or e-mail and delete the
> made after they were sent or for other risks which arise as a result of
> e-mail transmission, viruses, etc.
> On Tue, Feb 16, 2016 at 2:11 PM, David Alda Fernandez de Lezea
> <dalda at hazi.eus> wrote:
> Yes, I guess so, I haven't changed anything related to GeoNode and
> Geoserver configuration. Everything is in the same machine.
> The changes I made in the code are (in red):
> /usr/local/lib/python2.7/dist-packages/geonode/settings.py
> LOCAL_GEOSERVER = {
>         "source": {
>             "ptype": "gxp_wmscsource",
>             "url": OGC_SERVER['default']['PUBLIC_LOCATION'] +
> "geonode/wms",
>             "restUrl": "/gs/rest"
> /var/www/geonode/static/geonode/js/extjs/GeoNode-mixin.js
> layer.url.indexOf(app.localGeoServerBaseUrl.replace(app.urlPortRegEx,
> "$1/")) === 0)) {
>                     var workspace="geonode:";
>                     if (layer.params.LAYERS.indexOf(":")!=-1){
>                         workspace = "";
>                 Ext.Ajax.request({
>                     /* TODO: use a template variable here if possible */
>                     url:"/gs/" + workspace + layer.params.LAYERS +
> "/edit-check",
>                     method:"POST",
>                     success:function (response) {
>                         var result = Ext.decode(response.responseText);
>                         if (result.authorized === false) {
>                             toggleButtons(false);
>                         } else {
>                             layer.displayOutsideMaxExtent = true;
>                             toggleButtons(true);
>                     failure:function () {
>             } else {
> Thanks.
> Regards.
> Agur bero bat,
> Arloa.
> kontserbatu gabe.
> Enviado el: martes, 16 de febrero de 2016 13:24
> Are GeoServer and GeoNode under the same domain? (same hostname and same
> port)?
> Best Regards,
> Alessio Fabiani.
> @alfa7691
> GeoSolutions S.A.S.
> Italy
> On Tue, Feb 16, 2016 at 1:02 PM, David Alda Fernandez de Lezea
> Hi list,
> I'm continuing with our GeoNode customization. One of our requirements was
> to show in the GeoExplorer Local GeoServer combo only the layers from
> "geonode" workspace. So far I've been able to modify everything and get it
> working, but I've found an issue while accessing layer details. I get an
> HTTP 405 error METHOD NOT ALLOWED while accessing
> http://192.168.1.190/gs/rest/styles
> HTTP/1.1 405 METHOD NOT ALLOWED
> Date: Tue, 16 Feb 2016 11:39:17 GMT
> Server: Apache/2.4.7 (Ubuntu)
> Vary: Accept-Language,Cookie
> X-Frame-Options: SAMEORIGIN
> Content-Language: es
> Content-Length: 0
> Keep-Alive: timeout=5, max=100
> Connection: Keep-Alive
> Content-Type: text/plain
> And the layer is not displayed in the preview. Apache doesn't show any
> error.
> Can anyone point me to the file(s) that I have to change?
> Thanks in advance.
> Regards,
> Agur bero bat,
> Arloa.
> T 945 003 240 - M 627 923 170 - F 945 003 290
> Hazi | Granja Modelo de Arkaute s/n | 01192 Arkaute - Araba
> kontserbatu gabe.
> geonode-users mailing list
> http://lists.osgeo.org/mailman/listinfo/geonode-users
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160218/2ef9fc1d/attachment-0001.html>
More information about the geonode-users mailing list
