[GeoNode-users] Errors on layer info after upgrade
Paolo Corti
pcorti at gmail.com
Thu Feb 18 06:27:54 PST 2016
Hi Annalisa
this is strange indeed, because accordingly to what you did the value
for sld_url shouldn't have changed (unless you run updatelayers on the
layer), and that value indicates that at
some point the layer was saved and this generated the error (every
time the layer is saved the style table is synced with GeoServer).
Are you sure that this page was not causing error also on 2.4c1?
cheers
p
On Thu, Feb 18, 2016 at 9:19 AM, Annalisa Schiavon
<annalisa.schiavon at gmail.com> wrote:
> Maybe I found the error. In my layers_style table, the field "sld_url" is
> like:
> <bound method Style.body_href of <geoserver.style.Style object at
> 0x7f9a0fda9610>>
> or
> http://localhost:8080/geoserver/rest/styles/depuratoripubblici.xml
> If I change the field to
> "http://localhost:8080/geoserver/rest/styles/acque_transizione.sld", for
> example, there's no errors for that layer.
> I've launched an updatelayers for all my layers, before found this, but it
> doesn't correct the layer's styles. Is it linked to this issue:
> https://github.com/GeoNode/geonode/issues/2329 ?
> However the updatelayers has deleted some layers, I don't know why, and then
> it has re-created them, correctly.
> So, now, I have to change manually all "sld_url" values or you have other
> suggestions?
> Thanks
> Annalisa
> 2016-02-18 14:44 GMT+01:00 Muhammad <mnabiahmad at gmail.com>:
>> Hi Alessio
>> See if data in field 'detail_url' from table base_resourcebase are
>> correct. It should not be empty.
>> On 02/18/2016 04:11 PM, Alessio Fabiani wrote:
>> Did you specify the DB PORT on your local_settings.py?
>> If so, be sure the value is quoted:
>> "5432"
>> if you remove the quotes you'll get an error similar to the one on the
>> logs.
>> Best Regards,
>> Alessio Fabiani.
>> GeoServer Professional Services from the experts!
>> Visit http://goo.gl/it488V for more information.
>> Ing. Alessio Fabiani
>> @alfa7691
>> Founder/Technical Lead
>> GeoSolutions S.A.S.
>> Via di Montramito 3/A
>> 55054 Massarosa (LU)
>> Italy
>> phone: +39 0584 962313
>> fax: +39 0584 1660272
>> mob: +39 333 8128928
>> http://www.geo-solutions.it
>> http://twitter.com/geosolutions_it
>> AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
>> Le informazioni contenute in questo messaggio di posta elettronica e/o
>> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il loro
>> utilizzo è consentito esclusivamente al destinatario del messaggio, per le
>> finalità indicate nel messaggio stesso. Qualora riceviate questo messaggio
>> senza esserne il destinatario, Vi preghiamo cortesemente di darcene notizia
>> via e-mail e di procedere alla distruzione del messaggio stesso,
>> cancellandolo dal Vostro sistema. Conservare il messaggio stesso, divulgarlo
>> anche in parte, distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per
>> finalità diverse, costituisce comportamento contrario ai principi dettati
>> dal D.Lgs. 196/2003.
>> The information in this message and/or attachments, is intended solely for
>> the attention and use of the named addressee(s) and may be confidential or
>> proprietary in nature or covered by the provisions of privacy act
>> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
>> Code).Any use not in accord with its purpose, any disclosure, reproduction,
>> copying, distribution, or either dissemination, either whole or partial, is
>> strictly forbidden except previous formal approval of the named
>> addressee(s). If you are not the intended recipient, please contact
>> immediately the sender by telephone, fax or e-mail and delete the
>> information in this message that has been received in error. The sender does
>> not give any warranty or accept liability as the content, accuracy or
>> completeness of sent messages and accepts no responsibility for changes
>> made after they were sent or for other risks which arise as a result of
>> e-mail transmission, viruses, etc.
>> On Thu, Feb 18, 2016 at 1:47 PM, Annalisa Schiavon
>>> I have sld styles for all my layers. But on geoserver, the preview works
>>> fine.
>>> What field on DB I have to check?
>>> It may be due to the fact that I don't have upload sessions associated to
>>> my layers?
>>> I usually load layers on postgis, then I create layers in geoserver and
>>> then I throw geonode updatelayers from console.
>>> 2016-02-18 13:14 GMT+01:00 Amedeo Fadini <amefad at gmail.com>:
>>>> 2016-02-18 12:54 GMT+01:00 Annalisa Schiavon
>>>> <annalisa.schiavon at gmail.com>:
>>>> > Hi all,
>>>> > I've just upgrade geonode from 2.4c1 to 2.4 stable. No errors during
>>>> > installation, no problem to log in geonode and geoserver, but the
>>>> > layer info
>>>> > page gives "Internal Server Error".
>>>> > It's all ok in maps, on layers list's, but when I click on a layer, it
>>>> > gives
>>>> > internal error.
>>>> Accoridng to lines 73-74 of erro.log it seems that the script
>>>> geonode/layers/models.py is unable to make the right url for sld style
>>>> (index out of range)
>>>> Do you have custom sld style associated to the tested layer
>>>> (rete_balneazione_2015)?
>>>> Amedeo Fadini
>>> geonode-users mailing list
>>> geonode-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/geonode-users
>> best regards
>> Muhammad Nabi Ahmad
>> Twitter : mnabiahmad
>> Blog : https://scriptndebug.wordpress.com/
Paolo Corti
Geospatial software developer
web: http://www.paolocorti.net
twitter: @capooti
skype: capooti
More information about the geonode-users
