[GeoNode-users] Errors on layer info after upgrade
Annalisa Schiavon
annalisa.schiavon at gmail.com
Fri Feb 19 02:05:52 PST 2016
I was wondering, there is a place in geonode where setting the
Geoserver-data-dir?
I've just modified web.xml file in /usr/share/geoserver/WEB-INF
2016-02-18 18:18 GMT+01:00 Annalisa Schiavon <annalisa.schiavon at gmail.com>:
> The layer info page doesn't caused errors on 2.4c1, but the "manage style"
> operation caused no result on "load styles".
> I don't know what value had sld_url.
> I upgrade ubuntu, after having update ppa references. Then I've changed
> the geoserver data-dir, from default to my path. At this point I have 73
> layers on geoserver and also on geonode, but the errors described above.
> Than I run updatelayers, but with no result. I run again updatelayers,
> adding some layers, and the new layers have the right value of sld_url and
> the layer info page is OK forma the news.
> Il 18/feb/2016 03:28 PM, "Paolo Corti" <pcorti at gmail.com> ha scritto:
>> Hi Annalisa
>> this is strange indeed, because accordingly to what you did the value
>> for sld_url shouldn't have changed (unless you run updatelayers on the
>> layer), and that value indicates that at
>> some point the layer was saved and this generated the error (every
>> time the layer is saved the style table is synced with GeoServer).
>> Are you sure that this page was not causing error also on 2.4c1?
>> cheers
>> p
>> On Thu, Feb 18, 2016 at 9:19 AM, Annalisa Schiavon
>> <annalisa.schiavon at gmail.com> wrote:
>> > Maybe I found the error. In my layers_style table, the field "sld_url"
>> is
>> > like:
>> > <bound method Style.body_href of <geoserver.style.Style object at
>> > 0x7f9a0fda9610>>
>> > or
>> > http://localhost:8080/geoserver/rest/styles/depuratoripubblici.xml
>> > If I change the field to
>> > "http://localhost:8080/geoserver/rest/styles/acque_transizione.sld",
>> for
>> > example, there's no errors for that layer.
>> > I've launched an updatelayers for all my layers, before found this, but
>> it
>> > doesn't correct the layer's styles. Is it linked to this issue:
>> > https://github.com/GeoNode/geonode/issues/2329 ?
>> > However the updatelayers has deleted some layers, I don't know why, and
>> then
>> > it has re-created them, correctly.
>> > So, now, I have to change manually all "sld_url" values or you have
>> other
>> > suggestions?
>> > Thanks
>> > Annalisa
>> > 2016-02-18 14:44 GMT+01:00 Muhammad <mnabiahmad at gmail.com>:
>> >> Hi Alessio
>> >> See if data in field 'detail_url' from table base_resourcebase are
>> >> correct. It should not be empty.
>> >> On 02/18/2016 04:11 PM, Alessio Fabiani wrote:
>> >> Did you specify the DB PORT on your local_settings.py?
>> >> If so, be sure the value is quoted:
>> >> "5432"
>> >> if you remove the quotes you'll get an error similar to the one on the
>> >> logs.
>> >> Best Regards,
>> >> Alessio Fabiani.
>> >> GeoServer Professional Services from the experts!
>> >> Visit http://goo.gl/it488V for more information.
>> >> Ing. Alessio Fabiani
>> >> @alfa7691
>> >> Founder/Technical Lead
>> >> GeoSolutions S.A.S.
>> >> Via di Montramito 3/A
>> >> 55054 Massarosa (LU)
>> >> Italy
>> >> phone: +39 0584 962313
>> >> fax: +39 0584 1660272
>> >> mob: +39 333 8128928
>> >> http://www.geo-solutions.it
>> >> http://twitter.com/geosolutions_it
>> >> AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
>> >> Le informazioni contenute in questo messaggio di posta elettronica e/o
>> >> nel/i file/s allegato/i sono da considerarsi strettamente riservate.
>> Il loro
>> >> utilizzo è consentito esclusivamente al destinatario del messaggio,
>> per le
>> >> finalità indicate nel messaggio stesso. Qualora riceviate questo
>> messaggio
>> >> senza esserne il destinatario, Vi preghiamo cortesemente di darcene
>> notizia
>> >> via e-mail e di procedere alla distruzione del messaggio stesso,
>> >> cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
>> divulgarlo
>> >> anche in parte, distribuirlo ad altri soggetti, copiarlo, od
>> utilizzarlo per
>> >> finalità diverse, costituisce comportamento contrario ai principi
>> dettati
>> >> dal D.Lgs. 196/2003.
>> >> The information in this message and/or attachments, is intended solely
>> for
>> >> the attention and use of the named addressee(s) and may be
>> confidential or
>> >> proprietary in nature or covered by the provisions of privacy act
>> >> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
>> >> Code).Any use not in accord with its purpose, any disclosure,
>> reproduction,
>> >> copying, distribution, or either dissemination, either whole or
>> partial, is
>> >> strictly forbidden except previous formal approval of the named
>> >> addressee(s). If you are not the intended recipient, please contact
>> >> immediately the sender by telephone, fax or e-mail and delete the
>> >> information in this message that has been received in error. The
>> sender does
>> >> not give any warranty or accept liability as the content, accuracy or
>> >> completeness of sent messages and accepts no responsibility for
>> changes
>> >> made after they were sent or for other risks which arise as a result of
>> >> e-mail transmission, viruses, etc.
>> >> On Thu, Feb 18, 2016 at 1:47 PM, Annalisa Schiavon
>> >>> I have sld styles for all my layers. But on geoserver, the preview
>> works
>> >>> fine.
>> >>> What field on DB I have to check?
>> >>> It may be due to the fact that I don't have upload sessions
>> associated to
>> >>> my layers?
>> >>> I usually load layers on postgis, then I create layers in geoserver
>> and
>> >>> then I throw geonode updatelayers from console.
>> >>> 2016-02-18 13:14 GMT+01:00 Amedeo Fadini <amefad at gmail.com>:
>> >>>> 2016-02-18 12:54 GMT+01:00 Annalisa Schiavon
>> >>>> > Hi all,
>> >>>> > I've just upgrade geonode from 2.4c1 to 2.4 stable. No errors
>> during
>> >>>> > installation, no problem to log in geonode and geoserver, but the
>> >>>> > layer info
>> >>>> > page gives "Internal Server Error".
>> >>>> > It's all ok in maps, on layers list's, but when I click on a
>> layer, it
>> >>>> > gives
>> >>>> > internal error.
>> >>>> Accoridng to lines 73-74 of erro.log it seems that the script
>> >>>> geonode/layers/models.py is unable to make the right url for sld
>> style
>> >>>> (index out of range)
>> >>>> Do you have custom sld style associated to the tested layer
>> >>>> (rete_balneazione_2015)?
>> >>>> Amedeo Fadini
>> >>> _______________________________________________
>> >>> geonode-users mailing list
>> >>> geonode-users at lists.osgeo.org
>> >>> http://lists.osgeo.org/mailman/listinfo/geonode-users
>> >> best regards
>> >> Muhammad Nabi Ahmad
>> >> Twitter : mnabiahmad
>> >> Blog : https://scriptndebug.wordpress.com/
>> Paolo Corti
>> Geospatial software developer
>> web: http://www.paolocorti.net
>> twitter: @capooti
>> skype: capooti
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160219/603c6f2f/attachment.html>
More information about the geonode-users
