[GeoNode-users] demo.geonode.org
Ivo Santos
ivojfs at gmail.com
Mon Feb 22 06:40:46 PST 2016
geonode collectstatic changed some files:
Copying
'/usr/lib/python2.7/dist-packages/geoexplorer/static/geoexplorer/theme/app/img/silk/pencil_add.png'
Copying
'/usr/lib/python2.7/dist-packages/geoexplorer/static/geoexplorer/theme/app/img/silk/map_save.png'
Copying
'/usr/lib/python2.7/dist-packages/geoexplorer/static/geoexplorer/theme/app/img/silk/arrow_inout.png'
Copying
'/usr/lib/python2.7/dist-packages/geoexplorer/static/geoexplorer/theme/app/img/silk/palette.png'
Copying
'/usr/lib/python2.7/dist-packages/geoexplorer/static/geoexplorer/externals/gxp/src/theme/img/silk/map_save.png'
Copying
'/usr/lib/python2.7/dist-packages/geoexplorer/static/geoexplorer/externals/gxp/src/theme/img/silk/map_go.png'
Copying
'/usr/lib/python2.7/dist-packages/geoexplorer/static/geoexplorer/externals/ext/resources/images/default/grid/grid3-hd-btn-2.gif'
Copying
'/usr/lib/python2.7/dist-packages/geoexplorer/static/geoexplorer/externals/ext/resources/images/default/grid/caret-down_1a1a1a_14.png'
Copying
'/usr/lib/python2.7/dist-packages/geoexplorer/static/geoexplorer/externals/ext/resources/images/gray/panel/tool-sprites-old.gif'
But it was not enough. I tried to
compare /var/www/geonode/static/geoexplorer/theme/app/geoexplorer.css and
https://github.com/GeoNode/django-geoexplorer/blob/master/geoexplorer/static/geoexplorer/theme/app/geoexplorer.css
and they are very different.
I have the correct file
on /usr/lib/python2.7/dist-packages/geoexplorer/static/geoexplorer/theme/app/geoexplorer.css
Thank you for your help.
2016-02-22 14:28 GMT+00:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
> ok, then geonode collectstatic. Sorry, forgot to add this before.
> 2016-02-22 15:21 GMT+01:00 Ivo Santos <ivojfs at gmail.com>:
>> Hi Simone,
>> I am not sure of the previous version of geonode, but it was not from the
>> stable ppa. It was installed using the spapshots ppa on the last trimester
>> of 2015. After it, I upgraded to the version on the stable ppa.
>> Tried a sudo pip install django-geoexplorer --upgrade and it was already
>> up-to-date... Version: 4.0.5
>> 2016-02-22 13:42 GMT+00:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
>>> Hi Ivo,
>>> yes the demo is the 2.4 stable. The white theme for gxp has been
>>> introduced a while ago. Any chance you upgraded from an older version?
>>> A $ sudo apt-get install django-geoexplorer might help.
>>> 2016-02-22 13:03 GMT+01:00 Ivo Santos <ivojfs at gmail.com>:
>>>> Hi all,
>>>> I went to the geonode demo yesterday and I realized that the style
>>>> (css?) of the layout of geoexplorer is different than the one installed on
>>>> my server. I do like it a lot.
>>>> I have the last stable version installed on my server (2.4). Do you
>>>> know if it is the same version that is on demo.geonode.org?
>>>> Thank you,
>>>> Ivo
>>>> Ivo Santos
>>>> _______________________________________________
>>>> geonode-users mailing list
>>>> geonode-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/geonode-users
>>> Simone
>> Ivo Santos
> Simone
Ivo Santos
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160222/26e3cd58/attachment-0001.html>
More information about the geonode-users
