[GeoNode-users] Copy part of the layers in a geonode instance
Alessio Fabiani
alessio.fabiani at geo-solutions.it
Wed Feb 24 03:15:48 PST 2016
Dear Daniel,
as part of the Backup&Restore procedure I am investigating a way to
export/import part of the GeoNode data.
WARNING: All this work is in progress, so at this time there is nothing
ready to use.
The idea is the following one:
1. Providing to the user a management command to backup the GeoNode
catalog. The whole catalog or part of it.
- This will make use of the "fixtures" and there should be a way to provide
somehow a query or a list of keys to store a subset of the layers.
- Backup the GeoServer data.
2. Providing to the user a management command to restore the GeoNode
- The command will use saved fixtures to restore GeoNode data.
- Restore the GeoServer data.
As a first implementation there will be the possibility to save the whole
catalog as a set of Json fixtures.
For you specific use case, the possibility would be to take the Layers JSON
and preserve "only" the layers you want to restore.
On GeoServer side you will need to get the layers data manually. This is
possible simply by getting the files from the GEOSERVER_DATA_DIRECTORY:
- Get the saved shapefiles from the upload subfolder
- Get the catalog metadata from workspace/geonode subfolder
- Get the styles SLDs and XMLs from styles subfolder
- Reload the catalog from the admin interface or restart GeoServer.
Best Regards,
Alessio Fabiani.
GeoServer Professional Services from the experts!
Visit http://goo.gl/it488V for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054 Massarosa (LU)
Italy
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39 331 6233686
http://www.geo-solutions.it
*AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
On Tue, Feb 23, 2016 at 8:44 PM, Daniel Victoria <daniel.victoria at gmail.com>
wrote:
> We have a GeoNode instance with more than 1000 layers published. We'd like
> to have a seccond GeoNode site with only some of the layers published in
> the first site, around 100. So far we've though of two ways to do this:
> 1) install a clean GeoNode and manually register the 100 layers
> 2) Copy the GeoNode with 1000 layers and manually delete the 900 excess
> layers
> The first option sound better, specially if we use the importlayers
> command. But can I import the metadata with the importlayers commad?
> Are there any other options?
> Thanks
> Daniel
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160224/16311cad/attachment.html>
More information about the geonode-users
