[GeoNode-users] GeoNode Backup and Restore: first draft
Ariel Nunez ingenieroariel at gmail.com
Fri Feb 26 05:08:29 PST 2016
Alesio, thanks for this work, looks very exciting.
Very excited to see the GeoServer plugin side afterwards.
One question, what's the strategy for migrating between different versions
of GeoNode? In particular between GeoNode forks and between future (and db
incompatible) GeoNode versions.
One of the main uses for these scripts would be to help users backup their
GeoNode before attempting an upgrade, either between major releases or
between heavily modified dev versions.
-a
On Fri, Feb 26, 2016 at 7:07 AM, Alessio Fabiani <
alessio.fabiani at geo-solutions.it> wrote:
> Dear all,
> as a follow up on this you can find here
> https://github.com/GeoNode/geonode/commit/cf1c7e7c7a90239f5171a6f83608d4d40360c262
> The GeoNode backup and restore utilities converted into GeoNode Base
> Management Commands.
> They can be invoked now as:
> *python manage.py backup --backup-dir=/tmp/*
> *python manage.py restore --backup-file=/tmp/2016-02-26_054445.zip*
> Best Regards,
> Alessio Fabiani.
> GeoServer Professional Services from the experts!
> Visit http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A
> 55054  Massarosa (LU)
> Italy
> phone: +39 0584 962313
> fax:     +39 0584 1660272
> mob:   +39 331 6233686
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> *AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
> Le informazioni contenute in questo messaggio di posta elettronica e/o
> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
> darcene notizia via e-mail e di procedere alla distruzione del messaggio
> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
> principi dettati dal D.Lgs. 196/2003.
> The information in this message and/or attachments, is intended solely for
> the attention and use of the named addressee(s) and may be confidential or
> proprietary in nature or covered by the provisions of privacy act
> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
> Code).Any use not in accord with its purpose, any disclosure, reproduction,
> copying, distribution, or either dissemination, either whole or partial, is
> strictly forbidden except previous formal approval of the named
> addressee(s). If you are not the intended recipient, please contact
> immediately the sender by telephone, fax or e-mail and delete the
> information in this message that has been received in error. The sender
> does not give any warranty or accept liability as the content, accuracy or
> completeness of sent messages and accepts no responsibility  for changes
> made after they were sent or for other risks which arise as a result of
> e-mail transmission, viruses, etc.
> On Thu, Feb 25, 2016 at 4:22 PM, Alessio Fabiani <
>> Dear all,
>> please find here
>> *https://github.com/GeoNode/geonode/tree/backup_restore/scripts/backup-restore
>> <https://github.com/GeoNode/geonode/tree/backup_restore/scripts/backup-restore>*
>> a first implementation of the backup and restore scripts using JSON
>> fixtures.
>> The scripts allow to automatically store into a ZIP archive all the
>> GeoNode Objects as JSON files along with the static resources.
>> A restore command takes the zip file as input and restores everything. At
>> the end you will have an exact copy of the old GeoNode replicated into the
>> new instance independently from the datastore.
>> *NOTICE 1:* I'm still working on the GeoServer side. GeoServer will be
>> enriched with a plugin allowing an administrator to store on a zip file the
>> whole data and configuration and having the ability to restore it at any
>> time.
>> *NOTICE 2: *In order to make things working you'll need to apply also
>> the "patch" attached to the email to the GeoNode source code *OR* clone
>> the *backup_restore *repository
>> How the GeoNode scripts work:
>> 1. Backup (on source instance)
>> Just go to the geonode/scripts/backup-restore folder and run the command
>>     *python backup.py*
>> The command will output few lines on the console
>> geonode at geonode:~/geonode/scripts/backup-restore$ python backup.py
>> Dumping 'people' into 'people.json'.
>> Dumping 'account' into 'accounts.json'.
>> Dumping 'avatar.avatar' into 'avatars.json'.
>> Dumping 'base.license' into 'licenses.json'.
>> Dumping 'base.topiccategory' into 'topiccategories.json'.
>> Dumping 'base.region' into 'regions.json'.
>> Dumping 'base.resourcebase' into 'resourcebases.json'.
>> Dumping 'base.contactrole' into 'contactroles.json'.
>> Dumping 'base.link' into 'links.json'.
>> Dumping 'base.restrictioncodetype' into 'restrictioncodetypes.json'.
>> Dumping 'base.spatialrepresentationtype' into
>> 'spatialrepresentationtypes.json'.
>> Dumping 'guardian.userobjectpermission' into 'useropermissions.json'.
>> Dumping 'guardian.groupobjectpermission' into 'groupopermissions.json'.
>> Dumping 'layers.uploadsession' into 'uploadsessions.json'.
>> Dumping 'layers.layer' into 'layers.json'.
>> Dumping 'layers.attribute' into 'attributes.json'.
>> Dumping 'maps.map' into 'maps.json'.
>> Dumping 'maps.maplayer' into 'maplayers.json'.
>> Dumping 'documents.document' into 'documents.json'.
>> Dumping 'taggit' into 'tags.json'.
>> Saved Media Files from '/home/geonode/geonode/geonode/uploaded'.
>> Saved Static Root from '/home/geonode/geonode/geonode/static_root'.
>> Saved Static Files from '/home/geonode/geonode/geonode/static'.
>> Saved Template Files from '/home/geonode/geonode/geonode/templates'.
>> Saved Locale Files from '/home/geonode/geonode/geonode/locale'.
>> Backup Finished. Archive generated 'backup/*2016-02-25_180915.zip*'.
>> None
>> and will store a timestamped ZIP file into the "backup" subfolder.
>> Notice that the scripts gets the locations and settings automatically
>> from the "geonode.settings" file.
>> 2. Restore (on destination instance)
>> *WARNING: **This procedure will completely purge and overwrite your
>> destination GeoNode instance. BE CAREFUL.*
>> Go to the geonode/scripts/backup-restore folder and edit the
>> *settings.ini* file, providing the connection parameter of the *TARGET
>> DB*.
>> [targetdb]
>> dbname = geonode_rst
>> host   = localhost
>> port   = 5432
>> user   = geonode
>> passwd = geonode
>> This is necessary in case you have a PostgreSQL Backend. The Restore
>> procedures tries to apply some patches to the DB in order to make things
>> working.
>> If you don't have a PostgreSQL backend, just ignore this passage.
>> Now run the Restore command providing the ZIP file to restore
>>    *python restore.py backup/2016-02-25_180915.zip*
>> The command will ask you confirmation to proceed.
>> By inserting *"y"* it will wipe out the target instance DB and folders
>> and restore the old ones.
>> geonode at geonode:~/geonode/scripts/backup-restore$ python restore.py
>> WARNING: The restore will overwrite all your GeoNode data and files. Are
>> you sure you want to proceed? [n]|y: y
>> Creating tables ...
>> Installing custom SQL ...
>> Installing indexes ...
>> Deserializing restore/2016-02-25_180915/people.json
>> Installed 3 object(s) from 1 fixture(s)
>> Deserializing restore/2016-02-25_180915/accounts.json
>> Installed 5 object(s) from 1 fixture(s)
>> Deserializing restore/2016-02-25_180915/avatars.json
>> WARNING: No valid fixture data found for 'avatars'.
>> Deserializing restore/2016-02-25_180915/licenses.json
>> Installed 7 object(s) from 1 fixture(s)
>> Deserializing restore/2016-02-25_180915/topiccategories.json
>> Installed 19 object(s) from 1 fixture(s)
>> Deserializing restore/2016-02-25_180915/regions.json
>> Installed 259 object(s) from 1 fixture(s)
>> Deserializing restore/2016-02-25_180915/resourcebases.json
>> Installed 2 object(s) from 1 fixture(s)
>> Deserializing restore/2016-02-25_180915/contactroles.json
>> Installed 4 object(s) from 1 fixture(s)
>> Deserializing restore/2016-02-25_180915/links.json
>> Installed 27 object(s) from 1 fixture(s)
>> Deserializing restore/2016-02-25_180915/restrictioncodetypes.json
>> Installed 8 object(s) from 1 fixture(s)
>> Deserializing restore/2016-02-25_180915/spatialrepresentationtypes.json
>> Installed 6 object(s) from 1 fixture(s)
>> Deserializing restore/2016-02-25_180915/useropermissions.json
>> Installed 18 object(s) from 1 fixture(s)
>> Deserializing restore/2016-02-25_180915/groupopermissions.json
>> Deserializing restore/2016-02-25_180915/uploadsessions.json
>> Deserializing restore/2016-02-25_180915/layers.json
>> Installed 1 object(s) from 1 fixture(s)
>> Deserializing restore/2016-02-25_180915/attributes.json
>> Deserializing restore/2016-02-25_180915/maps.json
>> Deserializing restore/2016-02-25_180915/maplayers.json
>> Deserializing restore/2016-02-25_180915/documents.json
>> WARNING: No valid fixture data found for 'documents'.
>> Deserializing restore/2016-02-25_180915/tags.json
>> WARNING: No valid fixture data found for 'tags'.
>> Media Files Restored into '/home/geonode/geonode/geonode/uploaded'.
>> Static Root Restored into '/home/geonode/geonode/geonode/static_root'.
>> Static Files Restored into '/home/geonode/geonode/geonode/static'.
>> Template Files Restored into '/home/geonode/geonode/geonode/templates'.
>> Locale Files Restored into '/home/geonode/geonode/geonode/locale'.
>> Restore finished. Please find restored files and dumps into:
>> 'restore/2016-02-25_180915'.
>> That's all for now.
>> I'm moving forward with the Backup&Restore plugin for GeoServer and more
>> improvements on the GeoNode backup/restore scripts.
>> Notice that having JSON fixtures it should be possible with the next
>> improvements to:
>> 1. Filter out only some features to restore. As an instance you may want
>> to restore just a subset of the Layers and or Maps
>> 2. Remap the Layers (or part of them) on another instance
>> For the moment if you want/need to do some experiments with this, just do
>> a full backup and manually edit the layers.json file inside the ZIP archive.
>> Best Regards,
>> Alessio Fabiani.
>> @alfa7691
>> GeoSolutions S.A.S.
>> Italy
>> for the attention and use of the named addressee(s) and may be confidential
>> or proprietary in nature or covered by the provisions of privacy act
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160226/be4d05e3/attachment-0001.html>
More information about the geonode-users mailing list
