[GeoNode-users] Basemaps not showing up if printed
Florian Hoedt
florian.hoedt at hs-owl.de
Thu Jan 7 06:43:24 PST 2016
Ok this is interessting. From my terminal:
user at geonode:~$ export http_proxy=http://proxy.hs-owl.de:80
user at geonode:~$ export https_proxy=http://proxy.hs-owl.de:80
user at geonode:~$ wget http://otile1.mqcdn.com/tiles/1.0.0/map/09/268/169.png
--2016-01-07 15:40:34-- http://otile1.mqcdn.com/tiles/1.0.0/map/09/268/169.png
Auflösen des Hostnamen »proxy.hs-owl.de (proxy.hs-owl.de)«... 193.174.119.246, 2001:638:505:101::cafe
Verbindungsaufbau zu proxy.hs-owl.de (proxy.hs-owl.de)|193.174.119.246|:80... verbunden.
Proxy-Anforderung gesendet, warte auf Antwort... 200 OK
Länge: 18406 (18K) [image/jpeg]
In »»169.png«« speichern.
100%[======================================>] 18.406 --.-K/s in 0s
2016-01-07 15:40:34 (172 MB/s) - »»169.png«« gespeichert [18406/18406]
After setting the http_proxy and https_proxy environmental variables everything worked. Without doing this it failed in the same way as via printing.
mit freundlichen Grüßen
Florian Hoedt
B.Sc. Florian Hoedt
Hochschule Ostwestfalen-Lippe / Campus Höxter
FB 9 Landschaftsarchitektur und Umweltplanung
An der Wilhelmshöhe 44
37671 Höxter
Tel.: 05271-687-7478
E-Mail: florian.hoedt at hs-owl.de<mailto:florian.hoedt at hs-owl.de>
www.hs-owl.de/fb9<http://www.hs-owl.de/fb9>
Von: Simone Dalmasso [mailto:simone.dalmasso at gmail.com]
Gesendet: Donnerstag, 7. Januar 2016 15:36
An: Florian Hoedt
Cc: geonode-users at lists.osgeo.org
Betreff: Re: [GeoNode-users] Basemaps not showing up if printed
Ok,
any chance that your server is under a proxy or something like this?
You should check if your server is able to get one of those images, maybe logging in with ssh and do a wget on one of those addresses.
2016-01-07 15:31 GMT+01:00 Florian Hoedt <florian.hoedt at hs-owl.de<mailto:florian.hoedt at hs-owl.de>>:
Here is he log:
http://pastebin.com/zTvT0cLS
The errors are listed at line 2419
2016-01-07 15:23:48,993 ERROR [print.PDFUtils] - Server returned an error for http://otile1.mqcdn.com/tiles/1.0.0/map/09/268/169.png: Verbindungsaufbau abgelehnt
2016-01-07 15:23:48,993 ERROR [print.PDFUtils] - Server returned an error for http://otile1.mqcdn.com/tiles/1.0.0/map/09/268/170.png: Verbindungsaufbau abgelehnt
2016-01-07 15:23:48,994 ERROR [print.PDFCustomBlocks] - Error while adding a PDF elementjava.io.IOException: Verbindungsaufbau abgelehnt
Where “Verbindungsaufbau abgelehnt“ translates to „connection refused“.
Florian Hoedt
B.Sc. Florian Hoedt
37671 Höxter
Von: Simone Dalmasso [mailto:simone.dalmasso at gmail.com<mailto:simone.dalmasso at gmail.com>]
Gesendet: Donnerstag, 7. Januar 2016 15:08
An: Florian Hoedt
Cc: geonode-users at lists.osgeo.org<mailto:geonode-users at lists.osgeo.org>
Hi Florian,
could you post the stacktrace on a pastebin site?
2016-01-07 12:09 GMT+01:00 Florian Hoedt <florian.hoedt at hs-owl.de<mailto:florian.hoedt at hs-owl.de>>:
Hello list,
If I print a map the basemap will not get drawed – but will show up on the geoexplorer web view. It tells me there is a java.io<http://java.io> error and connection issue on the pdf file.
My settings are:
Geoserver ProxyBase URL:
http://geonode.aes.hs-owl.de/geoserver
Any hints where to look?
Florian Hoedt
B.Sc. Florian Hoedt
37671 Höxter
geonode-users mailing list
http://lists.osgeo.org/mailman/listinfo/geonode-users
Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160107/4c6b419a/attachment-0001.html>
More information about the geonode-users
