[GeoNode-users] Geonode error "page not found" on production install
Simone Dalmasso
simone.dalmasso at gmail.com
Fri Jan 8 02:42:43 PST 2016
Ivo, if your server doesn't have a name (just the ip address) then you
cannot have multiple sites under the root. if you have a domain name then
you can take a look at the apache virtualhost configuration
https://httpd.apache.org/docs/2.2/vhosts/examples.html.
hope this helps
2016-01-08 11:39 GMT+01:00 Ivo Santos <ivojfs at gmail.com>:
> Hi Simone,
> Thank you for showing me the correct way. I managed to use geonode on a
> subdomain like you suggested. But now every other site on the server is
> giving error "Bad Request (400)". Probably this is a common error due to my
> inexperience with apache. If this questions are not for this list please
> let me know.
> Regards,
> Ivo
> 2016-01-08 7:36 GMT+00:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
>> Hi Ivo,
>> Geonode works at the root of the domain and you cannot serve it under
>> /geonode unless you change the code or maybe do some tricks with Apache.
>> Not sure if someone else has tried that. The suggestion is to keep at the
>> root but serve it with an Apache virtualhost when you have a domain name.
>> Like geonode.yourdomain.com.
>> Regards
>> Il giovedì 7 gennaio 2016, Ivo Santos <ivojfs at gmail.com> ha scritto:
>>> Hi everyone,
>>> I am new to geonode and testing the possibility of using it on my work.
>>> For now, I am trying to install Geonode for production.
>>> I instaled via apt-get with the snapshots repository on latest version
>>> of ubuntu. After that I created the superuser, updated the ip and after
>>> that changed the local_settings.py (SITEURL = 'http://10.0.2.15/geonode/')
>>> as on the docs <http://docs.geonode.org/en/dev/deploy/production.html>.
>>> But when I try to reach that page it appears "page not found". The homepage
>>> of geonode remains http://10.0.2.15
>>> Am I missing something here? Can you help me? If you need any kind of
>>> information, please ask.
>>> Best regards and thank you in advance,
>>> Ivo
>>> Ivo Santos
>> Simone
> Ivo Santos
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160108/1ff58276/attachment.html>
More information about the geonode-users
