[GeoNode-users] segmentation fault on saving maps (was error on saving maps, again!)
Eugenio Trumpy
frippe12573 at hotmail.com
Tue Jan 12 06:42:40 PST 2016
Dear all,
I'm trying to go ahead to solve my segmentation error on saving maps.
Just a brief summary: as wrote in the email here below (dated 04/12/2015)
I had a problem during the map saving.
Francesco suggested me to debug the apache coredump.
I got these lines during the gdb command run:
sudo gdb apache2 -c /tmp/cores/core.apache2.20926.repoigg.1452608854
GNU gdb (Ubuntu 7.7.1-0ubuntu5~14.04.2) 7.7.1
Copyright (C) 2014 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law. Type "show copying"
and "show warranty" for details.
This GDB was configured as "x86_64-linux-gnu".
Type "show configuration" for configuration details.
For bug reporting instructions, please see:
<http://www.gnu.org/software/gdb/bugs/>.
Find the GDB manual and other documentation resources online at:
<http://www.gnu.org/software/gdb/documentation/>.
For help, type "help".
Type "apropos word" to search for commands related to "word"...
Reading symbols from apache2...Reading symbols from /usr/lib/debug//usr/sbin/apache2...done.
done.
[New LWP 20955]
[New LWP 20963]
[New LWP 20961]
[New LWP 20958]
[New LWP 20965]
[New LWP 20957]
[New LWP 20964]
[New LWP 20956]
[New LWP 20962]
[New LWP 20959]
[New LWP 20926]
[New LWP 20966]
[New LWP 20960]
[New LWP 20951]
[New LWP 20954]
[New LWP 20953]
[New LWP 20952]
[New LWP 20933]
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1".
warning: the debug information found in "/usr/lib/debug//usr/lib/php5/20121212/mysql.so" does not match "/usr/lib/php5/20121212/mysql.so" (CRC mismatch).
warning: the debug information found in "/usr/lib/debug/usr/lib/php5/20121212/mysql.so" does not match "/usr/lib/php5/20121212/mysql.so" (CRC mismatch).
warning: the debug information found in "/usr/lib/debug//usr/lib/php5/20121212/mysqli.so" does not match "/usr/lib/php5/20121212/mysqli.so" (CRC mismatch).
warning: the debug information found in "/usr/lib/debug/usr/lib/php5/20121212/mysqli.so" does not match "/usr/lib/php5/20121212/mysqli.so" (CRC mismatch).
warning: the debug information found in "/usr/lib/debug//usr/lib/php5/20121212/pdo_mysql.so" does not match "/usr/lib/php5/20121212/pdo_mysql.so" (CRC mismatch).
warning: the debug information found in "/usr/lib/debug/usr/lib/php5/20121212/pdo_mysql.so" does not match "/usr/lib/php5/20121212/pdo_mysql.so" (CRC mismatch).
Core was generated by `/usr/sbin/apache2 -k start'.
Program terminated with signal SIGSEGV, Segmentation fault.
#0 pj_gc_apply_gridshift (defn=0x7f82098149e0, inverse=0, point_count=1, point_offset=1, x=0x7f820982e6a0,
y=0x7f8209908f90, z=0x7f8209908fb0) at src/pj_gridcatalog.c:145
145 src/pj_gridcatalog.c: No such file or directory.
File "/usr/share/gdb/auto-load/usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.19-gdb.py", line 63, in <module>
from libstdcxx.v6.printers import register_libstdcxx_printers
ImportError: No module named 'libstdcxx'
(gdb)
Can those lines help to find out the problem, and of course solve it?
I got the same problem by using both geonode 2.4.dev20151119194919 and the last origin/master version.
Please let me know.
best
Eugenio
Subject: Re: [GeoNode-users] error on saving maps, again!
Date: Sun, 6 Dec 2015 16:33:10 +0100
CC: simone.dalmasso at gmail.com; geonode-users at lists.osgeo.org
To: frippe12573 at hotmail.com
Eugenio,
a possible way to investigate more your problem is to attach httpd child process to gdb, cause it’s not reproducible. Follow instructions in this blog [1] and then look at the next crash.
Francesco
[1] http://sysadmin.carlusgg.com/?p=197
Il giorno 06/dic/2015, alle ore 10:58, Eugenio Trumpy <frippe12573 at hotmail.com> ha scritto:
Hi Francesco,
I'm trying to use geonode 2.4.dev20151203130956.
I tried to save both an empty map and one containing a wms from an external geoserver. Same error.
I also tried to upload a new layer for using it on a new map, but that geonode version misses the category choose, so I got error also on upload a shp file.
Any idea on the reason of my problem?
Eugenio
Date: Sat, 5 Dec 2015 18:03:21 +0100
Hi Eugenio,
what version are you running? Did your unsaved map contain remote any layer from remote service?
Francesco
Il giorno 04/dic/2015, alle ore 16:51, Eugenio Trumpy <frippe12573 at hotmail.com> ha scritto:
Dear Simone and all,
I'm very sad to announce you that I'm getting the same error I got 1 month ago.
I got an error on saving maps, and I retrieve the same error in apache error.log:
[Fri Dec 04 16:40:39.271057 2015] [core:notice] [pid 15782] AH00051: child pid 26334 exit signal Segmentation fault (11), possible coredump in /etc/apache2
same stuff on segmentation fault!
I can consider me very unlucky on this installation.
Actually It was 10 days up to yesterday that I did not use geonode, but I'm sure it was working fine.
Yesterday I had the problem raised on the geonode user mailing list, so today I decided to upgrade all geonode system.
The installation went fine, but I have the same problem on saving map.
I don't understand what happen.
I solved this problem upgrading the server from 12.04 up to 14.04 version. This task was a bit time spending but all the applications
as well as geonode then worked fine.
In the meanwhile no important activities I performed on the server, only a few OS update.
Can you help me again?
Eugenio
geonode-users mailing list
http://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160112/55418ec6/attachment.html>
More information about the geonode-users
