[GeoNode-users] segmentation fault on saving maps (was error on saving maps, again!)
Simone Dalmasso
simone.dalmasso at gmail.com
Tue Jan 12 08:04:17 PST 2016
Well,
I'm not sure that that was the right thing to do :)
Maybe you removed some necessary dependencies. Try to reinstall geonode and
in case work only at the python package level like python-pyproj.
Anyway if you google around with those errors (not the gdb one, that is
just a gdb bug) you will find some info.
2016-01-12 16:20 GMT+01:00 Eugenio Trumpy <frippe12573 at hotmail.com>:
> Hi Simone,
> just tried to remove -purge proj-bin and proj-data (this operation removed
> also: gdal-bin libgdal1h liblwgeom-2.1.2 libmapserver1 libogdi3.2
> libproj-dev libproj0 libspatialite5 mapserver-bin php5-mapscript postgis
> postgresql-9.3-postgis-2.1 python-gdal) and reinstall proj-bin and
> proj-data.
> Unfortunately on saving maps I have the same segmentation fault, but
> slightly different in the final part:
> sudo gdb apache2 -c /tmp/cores/core.apache2.20927.repoigg.1452611149
> GNU gdb (Ubuntu 7.7.1-0ubuntu5~14.04.2) 7.7.1
> Copyright (C) 2014 Free Software Foundation, Inc.
> License GPLv3+: GNU GPL version 3 or later <
> http://gnu.org/licenses/gpl.html>
> This is free software: you are free to change and redistribute it.
> There is NO WARRANTY, to the extent permitted by law. Type "show copying"
> and "show warranty" for details.
> This GDB was configured as "x86_64-linux-gnu".
> Type "show configuration" for configuration details.
> For bug reporting instructions, please see:
> <http://www.gnu.org/software/gdb/bugs/>.
> Find the GDB manual and other documentation resources online at:
> <http://www.gnu.org/software/gdb/documentation/>.
> For help, type "help".
> Type "apropos word" to search for commands related to "word"...
> Reading symbols from apache2...Reading symbols from
> /usr/lib/debug//usr/sbin/apache2...done.
> done.
> [New LWP 20937]
> [New LWP 20938]
> [New LWP 20949]
> [New LWP 20950]
> [New LWP 20939]
> [New LWP 20934]
> [New LWP 20948]
> [New LWP 20935]
> [New LWP 20947]
> [New LWP 20940]
> [New LWP 20946]
> [New LWP 20945]
> [New LWP 20936]
> [New LWP 20944]
> [New LWP 20943]
> [New LWP 20927]
> [New LWP 20942]
> [New LWP 20941]
> [Thread debugging using libthread_db enabled]
> Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1".
> warning: the debug information found in
> "/usr/lib/debug//usr/lib/php5/20121212/mysql.so" does not match
> "/usr/lib/php5/20121212/mysql.so" (CRC mismatch).
> "/usr/lib/debug/usr/lib/php5/20121212/mysql.so" does not match
> "/usr/lib/debug//usr/lib/php5/20121212/mysqli.so" does not match
> "/usr/lib/php5/20121212/mysqli.so" (CRC mismatch).
> "/usr/lib/debug/usr/lib/php5/20121212/mysqli.so" does not match
> "/usr/lib/debug//usr/lib/php5/20121212/pdo_mysql.so" does not match
> "/usr/lib/php5/20121212/pdo_mysql.so" (CRC mismatch).
> "/usr/lib/debug/usr/lib/php5/20121212/pdo_mysql.so" does not match
> Core was generated by `/usr/sbin/apache2 -k start'.
> Program terminated with signal SIGSEGV, Segmentation fault.
> #0 __GI___libc_free (mem=0x160) at malloc.c:2929
> 2929 malloc.c: No such file or directory.
> Traceback (most recent call last):
> File "/usr/share/gdb/auto-load/usr/lib/x86_64-linux-gnu/libstdc++.
> so.6.0.19-gdb.py", line 63, in <module>
> from libstdcxx.v6.printers import register_libstdcxx_printers
> ImportError: No module named 'libstdcxx'
> (gdb)
> Now it seems to be a memory problem....isn't it?
> What can I do?
> E.
> From: simone.dalmasso at gmail.com
> Date: Tue, 12 Jan 2016 16:00:05 +0100
> Subject: Re: segmentation fault on saving maps (was error on saving maps,
> again!)
> To: frippe12573 at hotmail.com
> CC: xbartolone at gmail.com; geonode-users at lists.osgeo.org
> Hi Eugenio,
> the error could be this one
> src/pj_gridcatalog.c: No such file or directory
> which seems related to the PROJ.4/pyproj libraries.
> Not sure what is wrong but try to reinstall them. Is the best I can tell :)
> good luck
> 2016-01-12 15:42 GMT+01:00 Eugenio Trumpy <frippe12573 at hotmail.com>:
> Dear all,
> I'm trying to go ahead to solve my segmentation error on saving maps.
> Just a brief summary: as wrote in the email here below (dated 04/12/2015)
> I had a problem during the map saving.
> Francesco suggested me to debug the apache coredump.
> I got these lines during the gdb command run:
> sudo gdb apache2 -c /tmp/cores/core.apache2.20926.repoigg.1452608854
> done.
> [New LWP 20955]
> [New LWP 20963]
> [New LWP 20961]
> [New LWP 20958]
> [New LWP 20965]
> [New LWP 20957]
> [New LWP 20964]
> [New LWP 20956]
> [New LWP 20962]
> [New LWP 20959]
> [New LWP 20926]
> [New LWP 20966]
> [New LWP 20960]
> [New LWP 20951]
> [New LWP 20954]
> [New LWP 20953]
> [New LWP 20952]
> [New LWP 20933]
> #0 pj_gc_apply_gridshift (defn=0x7f82098149e0, inverse=0, point_count=1,
> point_offset=1, x=0x7f820982e6a0,
> y=0x7f8209908f90, z=0x7f8209908fb0) at src/pj_gridcatalog.c:145
> 145 src/pj_gridcatalog.c: No such file or directory.
> (gdb)
> Can those lines help to find out the problem, and of course solve it?
> I got the same problem by using both geonode *2.4.dev20151119194919* and
> the last origin/master version.
> Please let me know.
> best
> Eugenio
> Subject: Re: [GeoNode-users] error on saving maps, again!
> From: xbartolone at gmail.com
> Date: Sun, 6 Dec 2015 16:33:10 +0100
> CC: simone.dalmasso at gmail.com; geonode-users at lists.osgeo.org
> Eugenio,
> a possible way to investigate more your problem is to attach httpd child
> process to gdb, cause it’s not reproducible. Follow instructions in this
> blog [1] and then look at the next crash.
> Francesco
> [1] http://sysadmin.carlusgg.com/?p=197
> Il giorno 06/dic/2015, alle ore 10:58, Eugenio Trumpy <
> frippe12573 at hotmail.com> ha scritto:
> Hi Francesco,
> I'm trying to use geonode
> *2.4.dev20151203130956.*I tried to save both an empty map and one
> containing a wms from an external geoserver. Same error.
> I also tried to upload a new layer for using it on a new map, but that
> geonode version misses the category choose, so I got error also on upload a
> shp file.
> Any idea on the reason of my problem?
> Eugenio
> Date: Sat, 5 Dec 2015 18:03:21 +0100
> Hi Eugenio,
> what version are you running? Did your unsaved map contain remote any
> layer from remote service?
> Francesco
> Il giorno 04/dic/2015, alle ore 16:51, Eugenio Trumpy <
> Dear Simone and all,
> I'm very sad to announce you that I'm getting the same error I got 1 month
> ago.
> I got an error on saving maps, and I retrieve the same error in apache
> error.log:
> [Fri Dec 04 16:40:39.271057 2015] [core:notice] [pid 15782] AH00051: child
> pid 26334 exit signal Segmentation fault (11), possible coredump in
> /etc/apache2
> same stuff on segmentation fault!
> I can consider me very unlucky on this installation.
> Actually It was 10 days up to yesterday that I did not use geonode, but
> I'm sure it was working fine.
> Yesterday I had the problem raised on the geonode user mailing list, so
> today I decided to upgrade all geonode system.
> The installation went fine, but I have the same problem on saving map.
> I don't understand what happen.
> I solved this problem upgrading the server from 12.04 up to 14.04 version.
> This task was a bit time spending but all the applications
> as well as geonode then worked fine.
> In the meanwhile no important activities I performed on the server, only a
> few OS update.
> Can you help me again?
> Eugenio
> geonode-users mailing list
> http://lists.osgeo.org/mailman/listinfo/geonode-users
> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160112/6b5a1c5c/attachment-0001.html>
More information about the geonode-users
