[GeoNode-users] Geonode geoserver not showing layers
Simone Dalmasso
simone.dalmasso at gmail.com
Fri Jan 15 04:09:08 PST 2016
It seems to me a connection issue between geoserver and Geonode. Check if
in the geoserver data folder/security/auth/geonodeAuthentication/config.xml
you have the correct address of Geonode. (Which may be localhost) then
restart tomcat.
Il venerdì 15 gennaio 2016, Basharat Iqbal <b11064714 at gmail.com> ha scritto:
> Hi everyone
> I installed genode following
> http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/index.html#geonode-install
> link on a server.
> Its working properly. when i add new layers through geonode they get saved
> in Geoserver. But neither geonode is showing the layer nor geoserver (which
> i click on layer preview)
> I added my own layers in geoserver directly but still its not showing up.
> I created a custom style in QGIS and added sld in geoserver but still its
> not the style.
> Server status is : org.apache.wicket.WicketRuntimeException: Can't
> instantiate page using constructor public
> org.geoserver.web.admin.StatusPage()
> Warning is there : The default user/group service should use digest
> password encoding.
> Thank you for your help in advance
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160115/89f784d5/attachment.html>
More information about the geonode-users
