[GeoNode-users] Metadata partly parsed.
Margherita Di Leo
diregola at gmail.com
Mon Jan 18 01:12:00 PST 2016
Tom,
On Sun, Jan 17, 2016 at 7:48 PM, Tom Kralidis <tomkralidis at gmail.com> wrote:
> On Fri, Jan 15, 2016 at 5:04 AM, Margherita Di Leo <diregola at gmail.com>
> wrote:
> > Dears,
> > we would like to deploy our data using GeoNode. However, at present I am
> > finding multiple issues that i'm not sure I'm able to overcome. I'd
> probably
> > better start multiple thread on each issues. I depend upon your kind
> help.
> > First issue that I found is that, our metadata, even though 100% INSPIRE
> > compliant, seem not to be parsed correctly by GeoNode. The only info
> that I
> > can visualize after uploading are title, publication date, category and
> > owner. In the section Abstract appears "No abstract provided", but the
> > abstract was provided. You can download a sample metadata for testing
> here .
> GeoNode uses the OWSLib package to parse the ISO metadata. Looking deeper
> at your metadata sample, your abstract is cast as:
> <gmd:abstract>
> <gmx:Anchor ...>
> </gmd:abstract>
> OWSLib looks for the following construct:
> <gmd:abstract>
> <gco:CharacterString>
> </gmd:abstract>
> so in your case gmx:Anchor is not being picked up as an abstract.
> This is the first time (INSPIRE-based and elsewhere) that I've seen this
> design pattern. Is it possible to update your metadata as a workaround?
> At
> the same time it would be worth to investigate in OWSLib and possibly apply
> a issue/patch/workaround.
Thank you for the pointers. Anchor should (and in some catalogues does)
allow the nice property to have a clickable link in place of the chunk of
text (the abstract in this case) that lands to a html page. We have used
this feature because we want to be able to include a long text in the
abstract and lineage, and new lines are not recognised in xml, resulting in
a blob of text which is barely readable. I know this is not much used,
partly because not known and also because usually metadata editors normally
do not include pro features ;-) but we find it really useful. I think it is
worth to investigate at the level of OWSLib if a patch could be applied.
Thank you again,
Best,
> ..Tom
> > Thank you in advance
> > Cheers,
> > Margherita Di Leo
Margherita Di Leo
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160118/17ae6126/attachment.html>
More information about the geonode-users
