[GeoNode-users] GeoNode Windows installer: looking for testers
Alessio Fabiani
alessio.fabiani at geo-solutions.it
Mon Jan 18 03:49:14 PST 2016
Oh, I see.
Yes, if you have another Python installation it may conflict.
Don't know exactly what is the best way to proceed here, maybe asking to
the user if he wants to use its own Python installation? But this may lead
to installation issues since we don't know how the user has configured
Python.
Any feedbacks welcome.
Alessio.
http://goo.gl/NWWaa2 for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via Poggio alle Viti 1187
55054 Massarosa (LU)
Italy
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39 331 6233686
http://www.geo-solutions.it
*AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
On Mon, Jan 18, 2016 at 12:45 PM, Daniel Victoria <daniel.victoria at gmail.com
> wrote:
> Bingo,
> No pip and virtualenv.
> My computer had some funny python installation problems because I mixed
> ArcMap with python(XY) and OSGeo4W. I've removed python(xy). But I see in
> windows environment that
> GEONODE_PATHEXT=C:\GeoNode-2.4\Python27;C:\GeoNode-2.4\Python27\Scripts;C:\Program
> Files (x86)\GDAL. It looks correct
> Cheers
> Daniel
> On Mon, Jan 18, 2016 at 9:36 AM, Alessio Fabiani <
> alessio.fabiani at geo-solutions.it> wrote:
>> Daniel,
>> roger. Maybe the GeoNode environment did not correctly configured.
>> In the windows "All Apps" menu shortcuts, under the voide "GeoNode-2.4"
>> you should see the "GeoNode VirtualEnv Setup" link. Can you try to run
>> this? It should start automatically during the installation process, but
>> maybe it needed an internet connection or something went wrong during this
>> step. If this works for you we catched the issue and I can try to debug it.
>> Many thanks for you patient and help!
>> Alessio.
>> GeoServer Professional Services from the experts! Visit
>> @alfa7691
>> GeoSolutions S.A.S.
>> Italy
>> http://twitter.com/geosolutions_it
>> Le informazioni contenute in questo messaggio di posta elettronica e/o
>> principi dettati dal D.Lgs. 196/2003.
>> The information in this message and/or attachments, is intended solely
>> for the attention and use of the named addressee(s) and may be confidential
>> or proprietary in nature or covered by the provisions of privacy act
>> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
>> Code).Any use not in accord with its purpose, any disclosure, reproduction,
>> copying, distribution, or either dissemination, either whole or partial, is
>> strictly forbidden except previous formal approval of the named
>> addressee(s). If you are not the intended recipient, please contact
>> immediately the sender by telephone, fax or e-mail and delete the
>> completeness of sent messages and accepts no responsibility for changes
>> made after they were sent or for other risks which arise as a result of
>> e-mail transmission, viruses, etc.
>> On Mon, Jan 18, 2016 at 12:28 PM, Daniel Victoria <
>> daniel.victoria at gmail.com> wrote:
>>> Apache is running. If I stop the service and try to connect to
>>> localhost, firefox will tell that it can't connect. And when I start the
>>> service, firefox will just keep on trying to connect, with no success. Our
>>> network uses a proxy but I've disabled it when connecting to localhost. So
>>> that should not be the problem.
>>> The error log just keeps on getting bigger (9.5 Mb now). Don't
>>> understand much but it conplains about ImportError: No module named site
>>> (entire log is attached).
>>> Cheers
>>> Daniel
>>> On Mon, Jan 18, 2016 at 9:15 AM, Alessio Fabiani <
>>>> Thanks Daniel,
>>>> can you please check if Apache HTTPD service has started correctly? If
>>>> so can you try to see if in the $INSTALLDIR/Apache2/logs/error.log there is
>>>> something related to the issue?
>>>> Also, make a try by restarting the Apache HTTPD service.
>>>> @alfa7691
>>>> GeoSolutions S.A.S.
>>>> Italy
>>>> On Mon, Jan 18, 2016 at 12:12 PM, Daniel Victoria <
>>>>> Dear Alessio,
>>>>> That's great news. I believe it will help spread the use of geonode to
>>>>> other niches...
>>>>> Anyway, I downloaded and installed the package in my machine.
>>>>> Installation went without a problem (no error screens). However, when I try
>>>>> to connect to http://localhost, it just keeps on waiting for the
>>>>> server response and nothing happens. I never see the GeoNode web page. I
>>>>> also tried 127.0.0.1.
>>>>> I'm not sure this is because I'm in a corporate domain and there might
>>>>> be some security blocks or if the installation did not work out. Later I'll
>>>>> try the installation on my personal computer. Meanwhile, if you'd like to
>>>>> figure out what happened, I can run the necessary tests, just give me the
>>>>> instructions as to what to do.
>>>>> Cheers
>>>>> Daniel
>>>>> On Mon, Jan 18, 2016 at 7:48 AM, Alessio Fabiani <
>>>>>> Dear all,
>>>>>> at this address
>>>>>> https://www.dropbox.com/s/ujclwt7mtu5zy87/GeoNode-2.4.exe?dl=0
>>>>>> you can find a first version of the GeoNode Windows installer.
>>>>>> The installer has been created using NSIS compiler and if it works
>>>>>> fine it will be part at the official GeoNode distribution and continuous
>>>>>> build as a result of the folowing GNIP:
>>>>>> https://github.com/GeoNode/geonode/issues/2375
>>>>>> The installer works by installing under a folder chosen by the user:
>>>>>> 1. A 32bit version of JRE 1.8
>>>>>> 2. A 32bit version of Python 2.7.10 with virtualenv and GDAL bindings
>>>>>> 3. A 32bit version of Apache Tomcat 7.0.35 with GeoServer
>>>>>> 4. A customized version of minimal WinLAMP with only the Apache HTTPD
>>>>>> + mod_wsgi
>>>>>> At the end of the installation you should be able to see:
>>>>>> 1. A running service of Apache Tomcat for GeoServer
>>>>>> 2. A running service of Apache HTTPD server for GeoNode
>>>>>> Your GeoNode installation will be available at:
>>>>>> http://localhost
>>>>>> Your GeoServer installation will be available at:
>>>>>> http://localhost/geoserver
>>>>>> No DB is installed on this version. The installation relies on the
>>>>>> default GeoNode settings.
>>>>>> It could be possible to optionally install also PostGIS in the future
>>>>>> if the community really needs it.
>>>>>> Also notice that the GeoNode will be configured to run in production
>>>>>> mode through the mod_wsgi and not in development mode through paver.
>>>>>> Please test it and report any feedbacks.
>>>>>> Very soon I will make available the NSIS source code too.
>>>>>> Best Regards,
>>>>>> Alessio Fabiani.
>>>>>> @alfa7691
>>>>>> GeoSolutions S.A.S.
>>>>>> Italy
>>>>>> e/o nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
>>>>>> solely for the attention and use of the named addressee(s) and may be
>>>>>> confidential or proprietary in nature or covered by the provisions of
>>>>>> privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data
>>>>>> Protection Code).Any use not in accord with its purpose, any disclosure,
>>>>>> reproduction, copying, distribution, or either dissemination, either whole
>>>>>> or partial, is strictly forbidden except previous formal approval of the
>>>>>> named addressee(s). If you are not the intended recipient, please contact
>>>>>> _______________________________________________
>>>>>> geonode-users mailing list
>>>>>> geonode-users at lists.osgeo.org
>>>>>> http://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160118/2942e87e/attachment-0001.html>
More information about the geonode-users
