[GeoNode-users] Help with geonodeAuthProvider configuration
Ivo Santos
ivojfs at gmail.com
Fri Jan 22 07:06:47 PST 2016
Nevermind the last email. In my tests to try to solve the issue, I erased
the trailing slash of the <baseUrl> on geonodeAuthProvider/config.xml.
I am on the same point right now (I can't see the layers on geoexplorer
only if any geonode user is logged on). Possibily is something like this
error and I missed some slash or something like that.
I tryed "DEBUG = TEMPLATE_DEBUG = True" on local_settings.py
I am not sure if it helps, but the error that appears is:
IndexError at /layers/geonode:teste
list index out of range
Request Method:GET
Request URL:http://atlas.example.com/layers/geonode:teste
Django Version:1.6.1
Exception Type:IndexError
Exception Value:
Exception
Location:/usr/local/lib/python2.7/dist-packages/geonode/layers/models.py in
absolute_url, line 68
Python Executable:/usr/bin/python
Python Version:2.7.6
Python Path:
['/usr/lib/python2.7',
'/usr/lib/python2.7/plat-x86_64-linux-gnu',
'/usr/lib/python2.7/lib-tk',
'/usr/lib/python2.7/lib-old',
'/usr/lib/python2.7/lib-dynload',
'/usr/local/lib/python2.7/dist-packages',
'/usr/lib/python2.7/dist-packages',
'/usr/lib/python2.7/dist-packages/PILcompat',
'/usr/lib/pymodules/python2.7',
'/var/www']
Server time:Sex, 22 Jan 2016 08:59:55 -0600
Error during template rendering
In template
/usr/local/lib/python2.7/dist-packages/geonode/layers/templates/layers/layer_detail.html,
error at line *322*
*<a href="{{ GEOSERVER_BASE_URL }}{{ style.absolute_url }}" >{{
style.sld_title }}</a>*
I can try to send the all file if some of you think it would be better.
Thank you for your attention,
Ivo
2016-01-22 13:20 GMT+00:00 Ivo Santos <ivojfs at gmail.com>:
> Alessio,
> Thank you for the explanation about mod_wsgi. I think it wasn't the
> situation. I tried the steps on that page who could be apllied and it's not
> working. Inclusive, there was a step back. Now I am like before: the user
> admin has to be logged to geoserver (and can't be logged on geonode) to be
> able to see the layers on the geoexplorer.
> I am trying now the geoexplorer debug as described on the documentation.
> It has to be something wrong on the configuration. But what?
> Thank you,
> Ivo
> 2016-01-22 8:54 GMT+00:00 Alessio Fabiani <
> alessio.fabiani at geo-solutions.it>:
>> Well, specifically mod_wsgi is an Apache HTTPD module. It allows you to
>> create a virtual folder/host in order to proxy the GeoNode DJango
>> application.
>> If you see mod_wsgi errors on the Apache error logs, most probably there
>> is something wrong, which usually can be a configuration issue or a Python
>> exception.
>> In the GeoNode official documentation there are several pages showing the
>> steps for the correct configuration of GeoNode with mod_wsgi.
>> One page which may be helpful on your case maybe this one:
>> http://docs.geonode.org/en/latest/tutorials/admin/customize_lookfeel/customize/setup_admin.html#setup-admin
>> GeoServer Professional Services from the experts! Visit
>> http://goo.gl/NWWaa2 for more information.
>> Ing. Alessio Fabiani
>> @alfa7691
>> Founder/Technical Lead
>> GeoSolutions S.A.S.
>> Via Poggio alle Viti 1187
>> 55054 Massarosa (LU)
>> Italy
>> phone: +39 0584 962313
>> fax: +39 0584 1660272
>> mob: +39 331 6233686
>> http://www.geo-solutions.it
>> http://twitter.com/geosolutions_it
>> *AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
>> Le informazioni contenute in questo messaggio di posta elettronica e/o
>> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
>> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
>> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
>> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
>> darcene notizia via e-mail e di procedere alla distruzione del messaggio
>> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
>> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
>> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
>> principi dettati dal D.Lgs. 196/2003.
>> The information in this message and/or attachments, is intended solely
>> for the attention and use of the named addressee(s) and may be confidential
>> or proprietary in nature or covered by the provisions of privacy act
>> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
>> Code).Any use not in accord with its purpose, any disclosure, reproduction,
>> copying, distribution, or either dissemination, either whole or partial, is
>> strictly forbidden except previous formal approval of the named
>> addressee(s). If you are not the intended recipient, please contact
>> immediately the sender by telephone, fax or e-mail and delete the
>> information in this message that has been received in error. The sender
>> does not give any warranty or accept liability as the content, accuracy or
>> completeness of sent messages and accepts no responsibility for changes
>> made after they were sent or for other risks which arise as a result of
>> e-mail transmission, viruses, etc.
>> On Thu, Jan 21, 2016 at 2:12 PM, Ivo Santos <ivojfs at gmail.com> wrote:
>>> It's not working on development mode.
>>> Sorry the (probably) dumb question, but how can I use mod_wsgi to run
>>> GeonNode?
>>> Maybe this info could help. The error that appears on apache when the
>>> user is logged on geonode and tries to see a layer is:
>>> mod_wsgi (pid=7536): Exception occurred processing WSGI script
>>> '/var/www/geonode/wsgi/geonode.wsgi'.
>>> And I realized that:
>>> if the user is logged he can't see the layers (Example:
>>> http://atlas.example.com/layers/geonode%3Acom26_wgs84 ) .
>>> if the user tries to create a new map (
>>> http://atlas.example.com/layers/maps/new) the layers appear as
>>> available and could be shown on the map.
>>> But if the user tries to save the map with the layers on screen, it
>>> gives a 500 error.
>>> Thank you in advance.
>>> Best regards,
>>> Ivo
>>> 2016-01-21 13:01 GMT+00:00 Alessio Fabiani <
>>>> One more thing, if you are running GeoNode in development mode (paver
>>>> start_django) it may not work when running the embedded geoserver.
>>>> If is not yet like this, try using mod_wsgi to run GeoNode
>>>> @alfa7691
>>>> GeoSolutions S.A.S.
>>>> Italy
>>>> On Thu, Jan 21, 2016 at 1:30 PM, Ivo Santos <ivojfs at gmail.com> wrote:
>>>>> Alessio,
>>>>> Thank you for your reply. I think that I did understand what you were
>>>>> saying... After some improvements, geonode and geoserver are still unable
>>>>> to communicate when a user is logged on geonode (this time, independently
>>>>> of being logged on geoserver).
>>>>> On local_settings.py:
>>>>> # OGC (WMS/WFS/WCS) Server Settings
>>>>> OGC_SERVER = {
>>>>> 'default' : {
>>>>> 'BACKEND' : 'geonode.geoserver',
>>>>> 'LOCATION' : 'http://atlas.example.com:8080/geoserver/',
>>>>> 'PUBLIC_LOCATION' : GEOSERVER_URL,
>>>>> 'USER' : 'admin',
>>>>> 'PASSWORD' : '*********************'
>>>>> ALLOWED_HOSTS=['atlas.example.com']
>>>>> On geonodeAuthProvider/config.xml:
>>>>> <baseUrl>http://atlas.example.com/</baseUrl>
>>>>> Does anyone have a clue of what is the problem? It seems the same
>>>>> problem Ariel had in November:
>>>>> https://lists.osgeo.org/pipermail/geonode-users/2015-November/001150.html
>>>>> Best regards,
>>>>> Ivo
>>>>> 2016-01-20 15:19 GMT+00:00 Alessio Fabiani <
>>>>>> The GeoNode/GeoServer security, right now, in order to work correctly
>>>>>> needs both GeoNode and GeoServer exposed under the same domain (and the
>>>>>> same port).
>>>>>> Therefore if you expose GeoNode as http://mysite/ you must also
>>>>>> expose GeoServer as http://mysite/geoserver
>>>>>> The GeoNode authentication provider can be configured with
>>>>>> http://localhost, I guess, but you must be sure that GeoServer is
>>>>>> also exposed as http://localhost/geoserver.
>>>>>> The rationale is that the GeoNodeSecurityClient looks for the
>>>>>> AuthPrincipal from the cookies.
>>>>>> @alfa7691
>>>>>> GeoSolutions S.A.S.
>>>>>> Italy
>>>>>> e/o nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
>>>>>> solely for the attention and use of the named addressee(s) and may be
>>>>>> confidential or proprietary in nature or covered by the provisions of
>>>>>> privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data
>>>>>> Protection Code).Any use not in accord with its purpose, any disclosure,
>>>>>> reproduction, copying, distribution, or either dissemination, either whole
>>>>>> or partial, is strictly forbidden except previous formal approval of the
>>>>>> named addressee(s). If you are not the intended recipient, please contact
>>>>>> On Wed, Jan 20, 2016 at 3:58 PM, Ivo Santos <ivojfs at gmail.com> wrote:
>>>>>>> Hi everyone,
>>>>>>> After several limiting issues concerning the configuration of apache
>>>>>>> that I have to thank you especially to Simone for all the help and
>>>>>>> guidance, I am now with a problem with the connection between geonode and
>>>>>>> geoserver:
>>>>>>> If user as log in on geoserver but not on geonode, he can view the
>>>>>>> layers.
>>>>>>> If user is not loged on geoserver, he can not view the layers and
>>>>>>> the error is:
>>>>>>> 2016-01-20 14:39:59,947 WARN [geonode.security] - Error connecting
>>>>>>> to the GeoNode server for authentication purposes
>>>>>>> org.springframework.security.authentication.AuthenticationServiceException:
>>>>>>> Communication with GeoNode failed (UsernamePasswordAuthenticationToken)
>>>>>>> If user is logged on both geonode and geoserver it gives a internal
>>>>>>> error (500).
>>>>>>> Following this thread
>>>>>>> <https://groups.google.com/forum/m/#!topic/geonode-users/84HvjbarPE8>I
>>>>>>> tried to apply this doc
>>>>>>> <https://github.com/GeoNode/geonode/commit/cc732e0a73c6d04d8f57fdf376dfb9a9848abd86>to
>>>>>>> my installation but it didn't worked.
>>>>>>> Does it have to remain like "http://localhost/" on both files or
>>>>>>> should I substitute by "http://atlas.example.com" on both? If you
>>>>>>> need more info please let me know.
>>>>>>> Thank you for all the help and patience for this newcomer,
>>>>>>> regards,
>>>>>>> Ivo
>>>>>>> Ivo Santos
>>>>>>> _______________________________________________
>>>>>>> geonode-users mailing list
>>>>>>> geonode-users at lists.osgeo.org
>>>>>>> http://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>> Ivo Santos
>>> Ivo Santos
> Ivo Santos
Ivo Santos
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160122/5535c346/attachment-0001.html>
More information about the geonode-users
