[GeoNode-users] Help with geonodeAuthProvider configuration
Ariel Cabezas gerardoarielc at gmail.com
Mon Jan 25 20:10:18 PST 2016
Ivo,
I tell you my experience:
*(Does anyone have a clue of what is the problem? It seems the same problem
Ariel had in
November: https://lists.osgeo.org/pipermail/geonode-users/2015-November/001150.html
<https://lists.osgeo.org/pipermail/geonode-users/2015-November/001150.html>)*
My problems started when:
- Install GeoNode and default settings; upload some layers;
later,
- I did the steps to set GeoNode for Production
- I change the key geoserver from the web platform Geoserver without
changing the key in the file local_settings.py
then I tried to upload new data layers; and of course they began error
messages
and I could not go back to the settings.  don't remember that changes made.
mistakes were mine;
I had to reinstall GeoNode and could change the key geoserver without any
problem; and then load the data layers without problems too,
now everything works correctly
regards,
Ariel Cabezas
2016-01-25 19:28 GMT-03:00 Ivo Santos <ivojfs at gmail.com>:
> Alessio,
> The same error occurs on both situations. It only depends of being logged
> to geonode or not. Do you think I should reinstall geonode and geoserver?
> Regards,
> Ivo
> 2016-01-25 17:47 GMT+00:00 Alessio Fabiani <
> alessio.fabiani at geo-solutions.it>:
>> Is your layer a raster or vectorial one?
>> GeoServer Professional Services from the experts! Visit
>> http://goo.gl/NWWaa2 for more information.
>> Ing. Alessio Fabiani
>> @alfa7691
>> Founder/Technical Lead
>> GeoSolutions S.A.S.
>> Via Poggio alle Viti 1187
>> 55054  Massarosa (LU)
>> Italy
>> phone: +39 0584 962313
>> fax:     +39 0584 1660272
>> mob:   +39  331 6233686
>> http://www.geo-solutions.it
>> http://twitter.com/geosolutions_it
>> *AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
>> Le informazioni contenute in questo messaggio di posta elettronica e/o
>> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
>> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
>> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
>> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
>> darcene notizia via e-mail e di procedere alla distruzione del messaggio
>> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
>> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
>> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
>> principi dettati dal D.Lgs. 196/2003.
>> The information in this message and/or attachments, is intended solely
>> for the attention and use of the named addressee(s) and may be confidential
>> or proprietary in nature or covered by the provisions of privacy act
>> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
>> Code).Any use not in accord with its purpose, any disclosure, reproduction,
>> copying, distribution, or either dissemination, either whole or partial, is
>> strictly forbidden except previous formal approval of the named
>> addressee(s). If you are not the intended recipient, please contact
>> immediately the sender by telephone, fax or e-mail and delete the
>> information in this message that has been received in error. The sender
>> does not give any warranty or accept liability as the content, accuracy or
>> completeness of sent messages and accepts no responsibility  for changes
>> made after they were sent or for other risks which arise as a result of
>> e-mail transmission, viruses, etc.
>> On Fri, Jan 22, 2016 at 4:06 PM, Ivo Santos <ivojfs at gmail.com> wrote:
>>> Nevermind the last email. In my tests to try to solve the issue, I
>>> erased the trailing slash of the <baseUrl> on
>>> geonodeAuthProvider/config.xml.
>>> I am on the same point right now (I can't see the layers on geoexplorer
>>> only if any geonode user is logged on). Possibily is something like this
>>> error and I missed some slash or something like that.
>>> I tryed "DEBUG = TEMPLATE_DEBUG = True" on local_settings.py
>>> I am not sure if it helps, but the error that appears is:
>>> IndexError at /layers/geonode:teste
>>> list index out of range
>>> Request Method:GET
>>> Request URL:http://atlas.example.com/layers/geonode:teste
>>> Django Version:1.6.1
>>> Exception Type:IndexError
>>> Exception Value:
>>> Exception
>>> Location:/usr/local/lib/python2.7/dist-packages/geonode/layers/models.py in
>>> absolute_url, line 68
>>> Python Executable:/usr/bin/python
>>> Python Version:2.7.6
>>> Python Path:
>>> ['/usr/lib/python2.7',
>>>  '/usr/lib/python2.7/plat-x86_64-linux-gnu',
>>>  '/usr/lib/python2.7/lib-tk',
>>>  '/usr/lib/python2.7/lib-old',
>>>  '/usr/lib/python2.7/lib-dynload',
>>>  '/usr/local/lib/python2.7/dist-packages',
>>>  '/usr/lib/python2.7/dist-packages',
>>>  '/usr/lib/python2.7/dist-packages/PILcompat',
>>>  '/usr/lib/pymodules/python2.7',
>>>  '/var/www']
>>> Server time:Sex, 22 Jan 2016 08:59:55 -0600
>>> Error during template rendering
>>> In template
>>> /usr/local/lib/python2.7/dist-packages/geonode/layers/templates/layers/layer_detail.html,
>>> error at line *322*
>>> *<a href="{{ GEOSERVER_BASE_URL }}{{ style.absolute_url }}" >{{
>>> style.sld_title }}</a>*
>>> I can try to send the all file if some of you think it would be better.
>>> Thank you for your attention,
>>> Ivo
>>> 2016-01-22 13:20 GMT+00:00 Ivo Santos <ivojfs at gmail.com>:
>>>> Alessio,
>>>> Thank you for the explanation about mod_wsgi. I think it wasn't the
>>>> situation. I tried the steps on that page who could be apllied and it's not
>>>> working. Inclusive, there was a step back. Now I am like before: the user
>>>> admin has to be logged to geoserver (and can't be logged on geonode) to be
>>>> able to see the layers on the geoexplorer.
>>>> I am trying now the geoexplorer debug as described on the
>>>> documentation. It has to be something wrong on the configuration. But what?
>>>> Thank you,
>>>> Ivo
>>>> 2016-01-22 8:54 GMT+00:00 Alessio Fabiani <
>>>>> Well, specifically mod_wsgi is an Apache HTTPD module. It allows you
>>>>> to create a virtual folder/host in order to proxy the GeoNode DJango
>>>>> application.
>>>>> If you see mod_wsgi errors on the Apache error logs, most probably
>>>>> there is something wrong, which usually can be a configuration issue or a
>>>>> Python exception.
>>>>> In the GeoNode official documentation there are several pages showing
>>>>> the steps for the correct configuration of GeoNode with mod_wsgi.
>>>>> One page which may be helpful on your case maybe this one:
>>>>> http://docs.geonode.org/en/latest/tutorials/admin/customize_lookfeel/customize/setup_admin.html#setup-admin
>>>>> @alfa7691
>>>>> GeoSolutions S.A.S.
>>>>> Italy
>>>>> On Thu, Jan 21, 2016 at 2:12 PM, Ivo Santos <ivojfs at gmail.com> wrote:
>>>>>> It's not working on development mode.
>>>>>> Sorry the (probably) dumb question, but how can I use mod_wsgi to run
>>>>>> GeonNode?
>>>>>> Maybe this info could help. The error that appears on apache when the
>>>>>> user is logged on geonode and tries to see a layer is:
>>>>>>  mod_wsgi (pid=7536): Exception occurred processing WSGI script
>>>>>> '/var/www/geonode/wsgi/geonode.wsgi'.
>>>>>> And I realized that:
>>>>>> if the user is logged he can't see the layers (Example:
>>>>>> http://atlas.example.com/layers/geonode%3Acom26_wgs84 ) .
>>>>>> if the user tries to create a new map (
>>>>>> http://atlas.example.com/layers/maps/new) the layers appear as
>>>>>> available and could be shown on the map.
>>>>>> But if the user tries to save the map with the layers on screen, it
>>>>>> gives a 500 error.
>>>>>> Thank you in advance.
>>>>>> Best regards,
>>>>>> Ivo
>>>>>> 2016-01-21 13:01 GMT+00:00 Alessio Fabiani <
>>>>>>> One more thing, if you are running GeoNode in development mode
>>>>>>> (paver start_django) it may not work when running the embedded geoserver.
>>>>>>> If is not yet like this, try using mod_wsgi to run GeoNode
>>>>>>> @alfa7691
>>>>>>> GeoSolutions S.A.S.
>>>>>>> Italy
>>>>>>> e/o nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
>>>>>>> solely for the attention and use of the named addressee(s) and may be
>>>>>>> confidential or proprietary in nature or covered by the provisions of
>>>>>>> privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data
>>>>>>> Protection Code).Any use not in accord with its purpose, any disclosure,
>>>>>>> reproduction, copying, distribution, or either dissemination, either whole
>>>>>>> or partial, is strictly forbidden except previous formal approval of the
>>>>>>> named addressee(s). If you are not the intended recipient, please contact
>>>>>>> On Thu, Jan 21, 2016 at 1:30 PM, Ivo Santos <ivojfs at gmail.com>
>>>>>>> wrote:
>>>>>>>> Alessio,
>>>>>>>> Thank you for your reply. I think that I did understand what you
>>>>>>>> were saying... After some improvements, geonode and geoserver are still
>>>>>>>> unable to communicate when a user is logged on geonode (this time,
>>>>>>>> independently of being logged on geoserver).
>>>>>>>> On local_settings.py:
>>>>>>>> # OGC (WMS/WFS/WCS) Server Settings
>>>>>>>> OGC_SERVER = {
>>>>>>>>     'default' : {
>>>>>>>>         'BACKEND' : 'geonode.geoserver',
>>>>>>>>         'LOCATION' : 'http://atlas.example.com:8080/geoserver/',
>>>>>>>>         'PUBLIC_LOCATION' : GEOSERVER_URL,
>>>>>>>>         'USER' : 'admin',
>>>>>>>>         'PASSWORD' : '*********************'
>>>>>>>> ALLOWED_HOSTS=['atlas.example.com']
>>>>>>>> On geonodeAuthProvider/config.xml:
>>>>>>>>   <baseUrl>http://atlas.example.com/</baseUrl>
>>>>>>>> problem Ariel had in November:
>>>>>>>> Best regards,
>>>>>>>> Ivo
>>>>>>>> 2016-01-20 15:19 GMT+00:00 Alessio Fabiani <
>>>>>>>>> The GeoNode/GeoServer security, right now, in order to work
>>>>>>>>> correctly needs both GeoNode and GeoServer exposed under the same domain
>>>>>>>>> (and the same port).
>>>>>>>>> Therefore if you expose GeoNode as http://mysite/ you must also
>>>>>>>>> expose GeoServer as http://mysite/geoserver
>>>>>>>>> The GeoNode authentication provider can be configured with
>>>>>>>>> http://localhost, I guess, but you must be sure that GeoServer is
>>>>>>>>> also exposed as http://localhost/geoserver.
>>>>>>>>> The rationale is that the GeoNodeSecurityClient looks for the
>>>>>>>>> AuthPrincipal from the cookies.
>>>>>>>>> @alfa7691
>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>> Italy
>>>>>>>>> On Wed, Jan 20, 2016 at 3:58 PM, Ivo Santos <ivojfs at gmail.com>
>>>>>>>>> wrote:
>>>>>>>>>> Hi everyone,
>>>>>>>>>> After several limiting issues concerning the configuration of
>>>>>>>>>> apache that I have to thank you especially to Simone for all the help and
>>>>>>>>>> guidance, I am now with a problem with the connection between geonode and
>>>>>>>>>> geoserver:
>>>>>>>>>> If user as log in on geoserver but not on geonode, he can view
>>>>>>>>>> the layers.
>>>>>>>>>> If user is not loged on geoserver, he can not view the layers and
>>>>>>>>>> the error is:
>>>>>>>>>> 2016-01-20 14:39:59,947 WARN [geonode.security] - Error
>>>>>>>>>> connecting to the GeoNode server for authentication purposes
>>>>>>>>>> org.springframework.security.authentication.AuthenticationServiceException:
>>>>>>>>>> Communication with GeoNode failed (UsernamePasswordAuthenticationToken)
>>>>>>>>>> If user is logged on both geonode and geoserver it gives a
>>>>>>>>>> internal error (500).
>>>>>>>>>> Following this thread
>>>>>>>>>> <https://groups.google.com/forum/m/#!topic/geonode-users/84HvjbarPE8>I
>>>>>>>>>> tried to apply this doc
>>>>>>>>>> <https://github.com/GeoNode/geonode/commit/cc732e0a73c6d04d8f57fdf376dfb9a9848abd86>to
>>>>>>>>>> my installation but it didn't worked.
>>>>>>>>>> Does it have to remain like "http://localhost/" on both files or
>>>>>>>>>> should I substitute by "http://atlas.example.com" on both? If
>>>>>>>>>> you need more info please let me know.
>>>>>>>>>> Thank you for all the help and patience for this newcomer,
>>>>>>>>>> regards,
>>>>>>>>>> Ivo
>>>>>>>>>> Ivo Santos
>>>>>>>>>> _______________________________________________
>>>>>>>>>> geonode-users mailing list
>>>>>>>>>> geonode-users at lists.osgeo.org
>>>>>>>>>> http://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>>>>> Ivo Santos
>>>>>> Ivo Santos
>>>> Ivo Santos
>>> Ivo Santos
> Ivo Santos
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160126/73fc1c3c/attachment-0001.html>
More information about the geonode-users mailing list
