[GeoNode-users] Can't 'use geonode updatelayers' or 'python manage.py' to updatelayers to with geoserver
Mana Etches manadotcom at gmail.com
Tue Jan 26 07:19:36 PST 2016
Hi again,
Firstly, thanks Simone Dalmasso for your help,
Upon your advice, I removed django 1.9 from directory
/usr/local/lib/python2.7/dist-packages/
Then, reinstalled using:
sudo pip install Django==1.6.11
I ran the command 'geonode updatelayers' and I got the errors::
  File "/usr/local/bin/django-admin", line 5, in <module>
    from pkg_resources import load_entry_point
  File "/usr/lib/python2.7/dist-packages/pkg_resources.py", line 2749,
in <module>
    working_set = WorkingSet._build_master()
  File "/usr/lib/python2.7/dist-packages/pkg_resources.py", line 446,
in _build_master
    return cls._build_from_requirements(__requires__)
  File "/usr/lib/python2.7/dist-packages/pkg_resources.py", line 459,
in _build_from_requirements
    dists = ws.resolve(reqs, Environment())
  File "/usr/lib/python2.7/dist-packages/pkg_resources.py", line 628, in resolve
    raise DistributionNotFound(req)
pkg_resources.DistributionNotFound: Django==1.9.1
It looks like Django 1.9.1 is still being recognised.
I then backed up then removed 'GeoNode-2.4.egg-info', but to no avail.
Is their a way to safely remove/reinstall django 1.6.11
without affecting geonode 2.4 as a whole?
Thanks in advance
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160127/a52edee3/attachment.html>
More information about the geonode-users mailing list
