[GeoNode-users] Help with geonodeAuthProvider configuration
Ivo Santos
ivojfs at gmail.com
Tue Jan 26 08:35:43 PST 2016
You were right! Thank you! I installed via apt-get but something had to go
wrong because the version installed was 0.6.13. Now I am on 1.0.3. Thank
you. Everything seems to be fine except the map creation. Now the error
appearing is:
on *geoserver*:
2016-01-26 16:24:12,958 INFO [geoserver.gwc] - Error dispatching tile
request to GeoServer
org.geowebcache.grid.OutsideCoverageException: Coverage
[minx,miny,maxx,maxy] is [121, 156, 123, 161, 8], index [x,y,z] is [126,
154, 8]
155, 8]
on *apache*:
[Tue Jan 26 16:32:40.353085 2016] [authz_core:debug] [pid 21755]
mod_authz_core.c(802): [client 193.136.219.68:64001] AH01626: authorization
result of Require all granted: granted, referer:
http://atlas.example.com/maps/new
[Tue Jan 26 16:32:40.353095 2016] [authz_core:debug] [pid 21755]
result of <RequireAny>: granted, referer: http://atlas.example.com/maps/new
Fatal Python error: PyEval_AcquireThread: NULL new thread state
[Tue Jan 26 16:32:40.816720 2016] [core:error] [pid 21755] [client
193.136.219.68:64001] End of script output before headers: geonode.wsgi,
[Tue Jan 26 16:32:41.467175 2016] [core:notice] [pid 20454] AH00051: child
pid 20461 exit signal Segmentation fault (11), possible coredump in
/etc/apache2
Any idea?
Thank you for all!
Regards,
Ivo
2016-01-26 15:45 GMT+00:00 Alessio Fabiani <alessio.fabiani at geo-solutions.it
> I guess you have an old version of gsconfig installed on your system then.
> GeoServer Professional Services from the experts! Visit
> http://goo.gl/NWWaa2 for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via Poggio alle Viti 1187
> 55054 Massarosa (LU)
> Italy
> phone: +39 0584 962313
> fax: +39 0584 1660272
> mob: +39 331 6233686
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> *AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
> Le informazioni contenute in questo messaggio di posta elettronica e/o
> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
> darcene notizia via e-mail e di procedere alla distruzione del messaggio
> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
> principi dettati dal D.Lgs. 196/2003.
> The information in this message and/or attachments, is intended solely for
> the attention and use of the named addressee(s) and may be confidential or
> proprietary in nature or covered by the provisions of privacy act
> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
> Code).Any use not in accord with its purpose, any disclosure, reproduction,
> copying, distribution, or either dissemination, either whole or partial, is
> strictly forbidden except previous formal approval of the named
> addressee(s). If you are not the intended recipient, please contact
> immediately the sender by telephone, fax or e-mail and delete the
> information in this message that has been received in error. The sender
> does not give any warranty or accept liability as the content, accuracy or
> completeness of sent messages and accepts no responsibility for changes
> made after they were sent or for other risks which arise as a result of
> e-mail transmission, viruses, etc.
> On Tue, Jan 26, 2016 at 4:43 PM, Ivo Santos <ivojfs at gmail.com> wrote:
>> Ariel, thank you for sharing your experience. I am, of course, beginning
>> to think seriously on the reinstall hypothesis.
>> Alessio, the SLD URL on table "layers_style" was set to:
>> "<bound method Style.body_href of <geoserver.style.Style object at
>> 0x7f07a6038d10>>";
>> 0x7efcb9dabed0>>";
>> 0x7fb0e4a65f90>>"
>> I tried to change it on every single layer to
>> http://atlas.example.com:8080/geoserver/rest/styles/general.sld and it's
>> working now.
>> Tested to upload a new layer and to put the "Default Polygon" as defaut
>> style and the same error occurs.
>> The new layer on the SLD URL appear again the same type of
>> 0x7fb0e4ec4690>>"
>> After changing to the same url as above, every logged user can open the
>> layers.
>> But when I try to create a new map an internal 500 error occurs:
>> - On *apache *log:
>> [Tue Jan 26 15:38:46.834380 2016] [authz_core:debug] [pid 8066]
>> mod_authz_core.c(802): [client 193.136.219.68:63432] AH01626:
>> authorization result of Require all granted: granted, referer:
>> http://atlas.example.com/maps/new?layer=geonode:conc42_wgs84
>> [Tue Jan 26 15:38:46.834414 2016] [authz_core:debug] [pid 8066]
>> authorization result of <RequireAny>: granted, referer:
>> [Tue Jan 26 15:38:46.834524 2016] [authz_core:debug] [pid 8066]
>> [Tue Jan 26 15:38:46.834536 2016] [authz_core:debug] [pid 8066]
>> [Tue Jan 26 15:38:47.299144 2016] [core:error] [pid 8066] [client
>> 193.136.219.68:63432] End of script output before headers: geonode.wsgi,
>> referer: http://atlas.example.com/maps/new?layer=geonode:conc42_wgs84
>> [Tue Jan 26 15:38:47.972265 2016] [core:notice] [pid 1516] AH00051: child
>> pid 10059 exit signal Segmentation fault (11), possible coredump in
>> /etc/apache2
>> - on *geoserver *log:
>> 2016-01-26 15:28:37,071 WARN [yaml.CustomBeanWrapper] - MetaData: unknown
>> field 'footer' with value '{height=30,
>> items=[org.mapfish.print.config.layout.ColumnsBlock at 141dedd2]}'
>> 2016-01-26 15:28:37,085 WARN [yaml.CustomBeanWrapper] - MainPage: Error
>> while writing '{height=30,
>> items=[org.mapfish.print.config.layout.ColumnsBlock at 141dedd2]}' to
>> footer: java.lang.IllegalArgumentException: argument type mismatch
>> 2016-01-26 15:28:40,364 WARN [yaml.CustomBeanWrapper] - MetaData: unknown
>> items=[org.mapfish.print.config.layout.ColumnsBlock at 35ef1451]}'
>> Thank you,
>> Regards,
>> Ivo
>> 2016-01-26 8:47 GMT+00:00 Alessio Fabiani <
>> alessio.fabiani at geo-solutions.it>:
>>> Mmm, thinking ... maybe the issue is just the SLD URL stored on the DB.
>>> Try to change manually the geoserver URL on the table "layer_style" and
>>> see if it works.
>>> @alfa7691
>>> GeoSolutions S.A.S.
>>> Italy
>>> for the attention and use of the named addressee(s) and may be confidential
>>> or proprietary in nature or covered by the provisions of privacy act
>>> On Tue, Jan 26, 2016 at 5:10 AM, Ariel Cabezas <gerardoarielc at gmail.com>
>>> wrote:
>>>> Ivo,
>>>> I tell you my experience:
>>>> *(Does anyone have a clue of what is the problem? It seems the same
>>>> problem Ariel had in
>>>> November: https://lists.osgeo.org/pipermail/geonode-users/2015-November/001150.html
>>>> <https://lists.osgeo.org/pipermail/geonode-users/2015-November/001150.html>)*
>>>> My problems started when:
>>>> - Install GeoNode and default settings; upload some layers;
>>>> later,
>>>> - I did the steps to set GeoNode for Production
>>>> - I change the key geoserver from the web platform Geoserver without
>>>> changing the key in the file local_settings.py
>>>> then I tried to upload new data layers; and of course they began error
>>>> messages
>>>> and I could not go back to the settings. don't remember that changes
>>>> made.
>>>> mistakes were mine;
>>>> I had to reinstall GeoNode and could change the key geoserver without
>>>> any problem; and then load the data layers without problems too,
>>>> now everything works correctly
>>>> regards,
>>>> Ariel Cabezas
>>>> 2016-01-25 19:28 GMT-03:00 Ivo Santos <ivojfs at gmail.com>:
>>>>> Alessio,
>>>>> The same error occurs on both situations. It only depends of being
>>>>> logged to geonode or not. Do you think I should reinstall geonode and
>>>>> geoserver?
>>>>> Regards,
>>>>> Ivo
>>>>> 2016-01-25 17:47 GMT+00:00 Alessio Fabiani <
>>>>>> Is your layer a raster or vectorial one?
>>>>>> @alfa7691
>>>>>> GeoSolutions S.A.S.
>>>>>> Italy
>>>>>> e/o nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
>>>>>> solely for the attention and use of the named addressee(s) and may be
>>>>>> confidential or proprietary in nature or covered by the provisions of
>>>>>> privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data
>>>>>> Protection Code).Any use not in accord with its purpose, any disclosure,
>>>>>> reproduction, copying, distribution, or either dissemination, either whole
>>>>>> or partial, is strictly forbidden except previous formal approval of the
>>>>>> named addressee(s). If you are not the intended recipient, please contact
>>>>>> On Fri, Jan 22, 2016 at 4:06 PM, Ivo Santos <ivojfs at gmail.com> wrote:
>>>>>>> Nevermind the last email. In my tests to try to solve the issue, I
>>>>>>> erased the trailing slash of the <baseUrl> on
>>>>>>> geonodeAuthProvider/config.xml.
>>>>>>> I am on the same point right now (I can't see the layers on
>>>>>>> geoexplorer only if any geonode user is logged on). Possibily is something
>>>>>>> like this error and I missed some slash or something like that.
>>>>>>> I tryed "DEBUG = TEMPLATE_DEBUG = True" on local_settings.py
>>>>>>> I am not sure if it helps, but the error that appears is:
>>>>>>> IndexError at /layers/geonode:teste
>>>>>>> list index out of range
>>>>>>> Request Method:GET
>>>>>>> Request URL:http://atlas.example.com/layers/geonode:teste
>>>>>>> Django Version:1.6.1
>>>>>>> Exception Type:IndexError
>>>>>>> Exception Value:
>>>>>>> Exception
>>>>>>> Location:/usr/local/lib/python2.7/dist-packages/geonode/layers/models.py in
>>>>>>> absolute_url, line 68
>>>>>>> Python Executable:/usr/bin/python
>>>>>>> Python Version:2.7.6
>>>>>>> Python Path:
>>>>>>> ['/usr/lib/python2.7',
>>>>>>> '/usr/lib/python2.7/plat-x86_64-linux-gnu',
>>>>>>> '/usr/lib/python2.7/lib-tk',
>>>>>>> '/usr/lib/python2.7/lib-old',
>>>>>>> '/usr/lib/python2.7/lib-dynload',
>>>>>>> '/usr/local/lib/python2.7/dist-packages',
>>>>>>> '/usr/lib/python2.7/dist-packages',
>>>>>>> '/usr/lib/python2.7/dist-packages/PILcompat',
>>>>>>> '/usr/lib/pymodules/python2.7',
>>>>>>> '/var/www']
>>>>>>> Server time:Sex, 22 Jan 2016 08:59:55 -0600
>>>>>>> Error during template rendering
>>>>>>> In template
>>>>>>> /usr/local/lib/python2.7/dist-packages/geonode/layers/templates/layers/layer_detail.html,
>>>>>>> error at line *322*
>>>>>>> *<a href="{{ GEOSERVER_BASE_URL }}{{ style.absolute_url }}" >{{
>>>>>>> style.sld_title }}</a>*
>>>>>>> I can try to send the all file if some of you think it would be
>>>>>>> better.
>>>>>>> Thank you for your attention,
>>>>>>> Ivo
>>>>>>> 2016-01-22 13:20 GMT+00:00 Ivo Santos <ivojfs at gmail.com>:
>>>>>>>> Alessio,
>>>>>>>> Thank you for the explanation about mod_wsgi. I think it wasn't the
>>>>>>>> situation. I tried the steps on that page who could be apllied and it's not
>>>>>>>> working. Inclusive, there was a step back. Now I am like before: the user
>>>>>>>> admin has to be logged to geoserver (and can't be logged on geonode) to be
>>>>>>>> able to see the layers on the geoexplorer.
>>>>>>>> I am trying now the geoexplorer debug as described on the
>>>>>>>> documentation. It has to be something wrong on the configuration. But what?
>>>>>>>> Thank you,
>>>>>>>> Ivo
>>>>>>>> 2016-01-22 8:54 GMT+00:00 Alessio Fabiani <
>>>>>>>>> Well, specifically mod_wsgi is an Apache HTTPD module. It allows
>>>>>>>>> you to create a virtual folder/host in order to proxy the GeoNode DJango
>>>>>>>>> application.
>>>>>>>>> If you see mod_wsgi errors on the Apache error logs, most probably
>>>>>>>>> there is something wrong, which usually can be a configuration issue or a
>>>>>>>>> Python exception.
>>>>>>>>> In the GeoNode official documentation there are several pages
>>>>>>>>> showing the steps for the correct configuration of GeoNode with mod_wsgi.
>>>>>>>>> One page which may be helpful on your case maybe this one:
>>>>>>>>> http://docs.geonode.org/en/latest/tutorials/admin/customize_lookfeel/customize/setup_admin.html#setup-admin
>>>>>>>>> @alfa7691
>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>> Italy
>>>>>>>>> On Thu, Jan 21, 2016 at 2:12 PM, Ivo Santos <ivojfs at gmail.com>
>>>>>>>>> wrote:
>>>>>>>>>> It's not working on development mode.
>>>>>>>>>> Sorry the (probably) dumb question, but how can I use mod_wsgi to
>>>>>>>>>> run GeonNode?
>>>>>>>>>> Maybe this info could help. The error that appears on apache when
>>>>>>>>>> the user is logged on geonode and tries to see a layer is:
>>>>>>>>>> mod_wsgi (pid=7536): Exception occurred processing WSGI script
>>>>>>>>>> '/var/www/geonode/wsgi/geonode.wsgi'.
>>>>>>>>>> And I realized that:
>>>>>>>>>> if the user is logged he can't see the layers (Example:
>>>>>>>>>> http://atlas.example.com/layers/geonode%3Acom26_wgs84 ) .
>>>>>>>>>> if the user tries to create a new map (
>>>>>>>>>> http://atlas.example.com/layers/maps/new) the layers appear as
>>>>>>>>>> available and could be shown on the map.
>>>>>>>>>> But if the user tries to save the map with the layers on screen,
>>>>>>>>>> it gives a 500 error.
>>>>>>>>>> Thank you in advance.
>>>>>>>>>> Best regards,
>>>>>>>>>> Ivo
>>>>>>>>>> 2016-01-21 13:01 GMT+00:00 Alessio Fabiani <
>>>>>>>>>>> One more thing, if you are running GeoNode in development mode
>>>>>>>>>>> (paver start_django) it may not work when running the embedded geoserver.
>>>>>>>>>>> If is not yet like this, try using mod_wsgi to run GeoNode
>>>>>>>>>>> @alfa7691
>>>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>>>> Italy
>>>>>>>>>>> elettronica e/o nel/i file/s allegato/i sono da considerarsi strettamente
>>>>>>>>>>> riservate. Il loro utilizzo è consentito esclusivamente al destinatario del
>>>>>>>>>>> messaggio, per le finalità indicate nel messaggio stesso. Qualora riceviate
>>>>>>>>>>> questo messaggio senza esserne il destinatario, Vi preghiamo cortesemente
>>>>>>>>>>> di darcene notizia via e-mail e di procedere alla distruzione del messaggio
>>>>>>>>>>> On Thu, Jan 21, 2016 at 1:30 PM, Ivo Santos <ivojfs at gmail.com>
>>>>>>>>>>> wrote:
>>>>>>>>>>>> Alessio,
>>>>>>>>>>>> Thank you for your reply. I think that I did understand what
>>>>>>>>>>>> you were saying... After some improvements, geonode and geoserver are still
>>>>>>>>>>>> unable to communicate when a user is logged on geonode (this time,
>>>>>>>>>>>> independently of being logged on geoserver).
>>>>>>>>>>>> On local_settings.py:
>>>>>>>>>>>> # OGC (WMS/WFS/WCS) Server Settings
>>>>>>>>>>>> OGC_SERVER = {
>>>>>>>>>>>> 'default' : {
>>>>>>>>>>>> 'BACKEND' : 'geonode.geoserver',
>>>>>>>>>>>> 'LOCATION' : 'http://atlas.example.com:8080/geoserver/
>>>>>>>>>>>> 'PUBLIC_LOCATION' : GEOSERVER_URL,
>>>>>>>>>>>> 'USER' : 'admin',
>>>>>>>>>>>> 'PASSWORD' : '*********************'
>>>>>>>>>>>> ALLOWED_HOSTS=['atlas.example.com']
>>>>>>>>>>>> On geonodeAuthProvider/config.xml:
>>>>>>>>>>>> <baseUrl>http://atlas.example.com/</baseUrl>
>>>>>>>>>>>> same problem Ariel had in November:
>>>>>>>>>>>> Best regards,
>>>>>>>>>>>> Ivo
>>>>>>>>>>>> 2016-01-20 15:19 GMT+00:00 Alessio Fabiani <
>>>>>>>>>>>>> The GeoNode/GeoServer security, right now, in order to work
>>>>>>>>>>>>> correctly needs both GeoNode and GeoServer exposed under the same domain
>>>>>>>>>>>>> (and the same port).
>>>>>>>>>>>>> Therefore if you expose GeoNode as http://mysite/ you must
>>>>>>>>>>>>> also expose GeoServer as http://mysite/geoserver
>>>>>>>>>>>>> The GeoNode authentication provider can be configured with
>>>>>>>>>>>>> http://localhost, I guess, but you must be sure that
>>>>>>>>>>>>> GeoServer is also exposed as http://localhost/geoserver.
>>>>>>>>>>>>> The rationale is that the GeoNodeSecurityClient looks for the
>>>>>>>>>>>>> AuthPrincipal from the cookies.
>>>>>>>>>>>>> @alfa7691
>>>>>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>>>>>> Italy
>>>>>>>>>>>>> intended solely for the attention and use of the named addressee(s) and may
>>>>>>>>>>>>> be confidential or proprietary in nature or covered by the provisions of
>>>>>>>>>>>>> On Wed, Jan 20, 2016 at 3:58 PM, Ivo Santos <ivojfs at gmail.com>
>>>>>>>>>>>>> wrote:
>>>>>>>>>>>>>> Hi everyone,
>>>>>>>>>>>>>> After several limiting issues concerning the configuration of
>>>>>>>>>>>>>> apache that I have to thank you especially to Simone for all the help and
>>>>>>>>>>>>>> guidance, I am now with a problem with the connection between geonode and
>>>>>>>>>>>>>> geoserver:
>>>>>>>>>>>>>> If user as log in on geoserver but not on geonode, he can
>>>>>>>>>>>>>> view the layers.
>>>>>>>>>>>>>> If user is not loged on geoserver, he can not view the layers
>>>>>>>>>>>>>> and the error is:
>>>>>>>>>>>>>> 2016-01-20 14:39:59,947 WARN [geonode.security] - Error
>>>>>>>>>>>>>> connecting to the GeoNode server for authentication purposes
>>>>>>>>>>>>>> org.springframework.security.authentication.AuthenticationServiceException:
>>>>>>>>>>>>>> Communication with GeoNode failed (UsernamePasswordAuthenticationToken)
>>>>>>>>>>>>>> If user is logged on both geonode and geoserver it gives a
>>>>>>>>>>>>>> internal error (500).
>>>>>>>>>>>>>> Following this thread
>>>>>>>>>>>>>> <https://groups.google.com/forum/m/#!topic/geonode-users/84HvjbarPE8>I
>>>>>>>>>>>>>> tried to apply this doc
>>>>>>>>>>>>>> <https://github.com/GeoNode/geonode/commit/cc732e0a73c6d04d8f57fdf376dfb9a9848abd86>to
>>>>>>>>>>>>>> my installation but it didn't worked.
>>>>>>>>>>>>>> Does it have to remain like "http://localhost/" on both
>>>>>>>>>>>>>> files or should I substitute by "http://atlas.example.com"
>>>>>>>>>>>>>> on both? If you need more info please let me know.
>>>>>>>>>>>>>> Thank you for all the help and patience for this newcomer,
>>>>>>>>>>>>>> regards,
>>>>>>>>>>>>>> Ivo
>>>>>>>>>>>>>> Ivo Santos
>>>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>>>> geonode-users mailing list
>>>>>>>>>>>>>> geonode-users at lists.osgeo.org
>>>>>>>>>>>>>> http://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>>>>>>>>> Ivo Santos
>>>>>>>>>> Ivo Santos
>>>>>>>> Ivo Santos
>>>>>>> Ivo Santos
>>>>> Ivo Santos
>> Ivo Santos
Ivo Santos
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160126/e92c1705/attachment-0001.html>
More information about the geonode-users
