[GeoNode-users] Layers and Grants
David Alda Fernandez de Lezea
dalda at hazi.eus
Thu Jan 28 01:18:53 PST 2016
No matter with which user I'm logged in , it doesn't count any layer. Even if I'm unlogged.
Only a user with admin grants can add data directly into GeoServer so I suppose the correct way is to use that user..
Or perhaps it has to be a current user with admin grants??
Regards,
Agur bero bat,
David Alda Fernández de Lezea
Área de Sistemas de Información Geográfica, Planificación Territorial y Forestal Informazio Geografikoen Sistemak, Lurralde eta Baso Antolaketaren Arloa.
dalda at hazi.eus | www.hazi.eus
T 945 003 240 – M 627 923 170 – F 945 003 290
Hazi | Granja Modelo de Arkaute s/n | 01192 Arkaute – Araba
********************* LEGE OHARRA ******************* AVISOLEGAL ******************* DISCLAIMER *****************************
Mezu hau pertsonala eta isilpekoa da eta baimenik gabeko erabilera debekatua dago legalki. Jasotzailea ez bazara ezabatu mezua, bidali eta kontserbatu gabe.
Este mensaje es personal y confidencial y su uso no autorizado está prohibido legalmente. Si usted no es el destinatario, proceda a borrarlo, sin reenviarlo ni conservarlo.
This message is personal and confidential, unauthorised use is legally prohibited. If you are not the intended recipient, delete it without resending or backing it.
De: Simone Dalmasso [mailto:simone.dalmasso at gmail.com]
Enviado el: jueves, 28 de enero de 2016 10:09
Para: David Alda Fernandez de Lezea
CC: geonode-users at lists.osgeo.org
Asunto: Re: [GeoNode-users] Layers and Grants
Hi, strange behavior indeed.
Are you always logged in when visiting the two pages?
Il giovedì 28 gennaio 2016, David Alda Fernandez de Lezea <dalda at hazi.eus> ha scritto:
I have question/doubt.. In my GeoNode installation I have several normal users and one Admin user. With the admin user I've loaded several cascaded WMS's into Geoserver and published several layers as well. I execute geonode update layers to synchronize and it goes OK. But when I visit geonode's main web page it appears (0 layers, 0 maps, 12 users). There're no maps, I know that because we're still at an initial phase, but 0 layers? The thing is that if I go into the layers page I can see the layer list that I already loaded. Is this something related to the user that used to load the layers? Maybe this is a normal behavior?
Any ideas?
Thanks in advance,
Regards,
Agur bero bat,
T 945 003 240 - M 627 923 170 - F 945 003 290
Hazi | Granja Modelo de Arkaute s/n | 01192 Arkaute - Araba
geonode-users mailing list
http://lists.osgeo.org/mailman/listinfo/geonode-users
Simone
More information about the geonode-users
