[GeoNode-users] Random 403 error using Geonode behind a web-gateway
Amedeo Fadini
amefad at gmail.com
Wed Jul 6 06:08:09 PDT 2016
Hi everybody,
so my installation of geonode with ssl works fine (2.4 on Ubuntu
server via apt-get) but I still haven't found the time to update the
ssl guide because we're unable to view geonode from outside...
we ave a web gateway with apache 2.2 that forwards the request from
outside using proxy directive
gis.mydomain.com >> mygeonode
I had to set the SITEURL to the external name gis.mydomain.com as the
ssl certificate is issued for that domain, I also used
https://gis.mydomain.com as LOCATION in geoserver section of
local_settings.py (otherwise the command geonode updatelayers doesn't
work due to authorization failure)
Browsing the maps with geoexplorer the WMS requests are correctly addressed to
https://gis.mydomain.com/geoserver/wms and the response is ok , but
sometimes apparently random a few of that requests fails with 403
Forbidden error, altought the same request is working after half a
second. There's any logic on the errors, just happens after a few time
browsing.. then works then happens again.
Apache logs and geoserver logs don't file any error on these requests and
using ssl with the machine hostname inside our network works fine, so
the problem is on the gateway configuration.
Any clue on how should be configurated the gateway proxy? Other
directives than these?
ProxyPreserveHost On
ProxyPass /geoserver https://mygeonode/geoserver
ProxyPassReverse /geoserver https://mygeonode/geoserver
Amedeo Fadini
More information about the geonode-users
