[GeoNode-users] error on using svg or png in style
Annalisa Schiavon
annalisa.schiavon at gmail.com
Thu Jul 7 03:44:04 PDT 2016
Hi all,
I've tried to create a sld style using an external graphic:
<se:Rule>
<se:Name>Single symbol</se:Name>
<se:PointSymbolizer>
<se:Graphic>
<se:ExternalGraphic>
<se:OnlineResource xlink:type="simple"
xlink:href="file:///var/www/geonode/static/img/ico/poi_tower_communications.svg"/>
<se:Format>image/svg+xml</se:Format>
</se:ExternalGraphic>
<se:Size>15</se:Size>
</se:Graphic>
</se:PointSymbolizer>
</se:Rule>
and than:
<se:Rule>
<se:Graphic>
<se:OnlineResource xlink:type="simple" xlink:href="
http://geomap.arpa.veneto.it/static/img/ico/antenna-with-signal-transmission.png
<se:Format>image/png</se:Format>
</se:Graphic>
</se:Rule>
In both cases, into style editor the preview works fine, but the layer
preview of geoserver (and also the associated layer in geonode) returns an
error:
java.io.IOException: java.lang.RuntimeException: Parsing failed for
UserStyle: java.lang.ClassCastException: java.util.HashMap cannot be cast
to org.opengis.util.International
Geonode ver.: 2.4
Geoserver ver.: 2.7.4
It is the first time I try to use external graphics. Any ideas to resolve
error?
It depends from the images used?
Thanks
Annalisa
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160707/c80e4c29/attachment.html>
More information about the geonode-users
