[GeoNode-users] database update error
Angelos Tzotsos
gcpp.kalxas at gmail.com
Thu Jul 7 07:10:15 PDT 2016
I had the same issue when installing GeoNode master on a clean Ubuntu
Xenial.
In order to fix it I had to apply the following migrations:
python manage.py migrate layers
python manage.py migrate documents
python manage.py migrate actstream
python manage.py migrate people
python manage.py migrate admin
python manage.py migrate guardian
python manage.py migrate sessions
python manage.py migrate sites
python manage.py migrate auth
python manage.py migrate tastypie
python manage.py migrate maps
python manage.py migrate contenttypes
python manage.py migrate base
python manage.py migrate upload
python manage.py migrate groups
python manage.py migrate services
python manage.py migrate taggit
Best,
Angelos
On 06/23/2016 11:55 AM, Simone Dalmasso wrote:
> Hi Eugenio,
> beware that the data model and django version is changed in master. This
> issue happens when using postgres as db and not sqllite. At the moment the
> way to create the new db is by doing
> manage.py migrate
> We will fix this in the future.
> 2016-06-23 10:27 GMT+02:00 Eugenio Trumpy <frippe12573 at hotmail.com>:
>> Hi all,
>> today I was trying to update geonode from git (custom installation on
>> ubuntu 14.04).
>> I made a backup of the data from geonode and geonode_data db, then I
>> created new DBs,
>> and I run syncdb --noinput, but something seems not working:
>> System check identified some issues:
>> WARNINGS:
>> account.EmailConfirmation.created: (fields.W161) Fixed default value
>> provided.
>> HINT: It seems you set a fixed date / time / datetime value as default
>> for this field. This may not be what you want. If you want to have the
>> current date as default, use `django.utils.timezone.now`
>> dialogos.Comment.ip_address: (fields.W900) IPAddressField has been
>> deprecated. Support for it (except in historical migrations) will be
>> removed in Django 1.9.
>> HINT: Use GenericIPAddressField instead.
>> Operations to perform:
>> Synchronize unmigrated apps: tasks, dialogos, modeltranslation,
>> django_extensions, polymorphic, agon_ratings, gis,
>> pinax_theme_bootstrap_account, django_forms_bootstrap, catalogue, humanize,
>> geoserver, announcements, storages, user_messages, mptt, friendlytagloader,
>> staticfiles, geoexplorer, sitemaps, proxy, account, pinax_theme_bootstrap,
>> pagination, autocomplete_light, messages, leaflet, api, avatar, social,
>> security
>> Apply all migrations: layers, documents, actstream, people, admin,
>> guardian, sessions, djcelery, sites, auth, tastypie, maps, contenttypes,
>> base, upload, groups, services, taggit
>> Synchronizing apps without migrations:
>> Creating tables...
>> Creating table account_account
>> Creating table account_signupcode
>> Creating table account_signupcodeextended
>> Creating table account_signupcoderesult
>> Creating table account_emailaddress
>> Creating table account_emailconfirmation
>> Creating table account_accountdeletion
>> Creating table avatar_avatar
>> Creating table dialogos_comment
>> Creating table agon_ratings_overallrating
>> Creating table agon_ratings_rating
>> Creating table announcements_announcement
>> Creating table announcements_dismissal
>> Creating table user_messages_thread
>> Creating table user_messages_userthread
>> Creating table user_messages_message
>> Running deferred SQL...
>> Traceback (most recent call last):
>> File "manage.py", line 29, in <module>
>> execute_from_command_line(sys.argv)
>> File
>> "/usr/local/lib/python2.7/dist-packages/django/core/management/__init__.py",
>> line 354, in execute_from_command_line
>> utility.execute()
>> File
>> line 346, in execute
>> self.fetch_command(subcommand).run_from_argv(self.argv)
>> File
>> "/usr/local/lib/python2.7/dist-packages/django/core/management/base.py",
>> line 394, in run_from_argv
>> self.execute(*args, **cmd_options)
>> File
>> line 445, in execute
>> output = self.handle(*args, **options)
>> File
>> "/usr/local/lib/python2.7/dist-packages/django/core/management/commands/syncdb.py",
>> line 25, in handle
>> call_command("migrate", **options)
>> File
>> line 120, in call_command
>> return command.execute(*args, **defaults)
>> File
>> File
>> "/usr/local/lib/python2.7/dist-packages/django/core/management/commands/migrate.py",
>> line 179, in handle
>> created_models = self.sync_apps(connection,
>> executor.loader.unmigrated_apps)
>> File
>> line 318, in sync_apps
>> cursor.execute(statement)
>> File
>> "/usr/local/lib/python2.7/dist-packages/django/db/backends/utils.py", line
>> 79, in execute
>> return super(CursorDebugWrapper, self).execute(sql, params)
>> File
>> 64, in execute
>> return self.cursor.execute(sql, params)
>> File "/usr/local/lib/python2.7/dist-packages/django/db/utils.py", line
>> 98, in __exit__
>> six.reraise(dj_exc_type, dj_exc_value, traceback)
>> File
>> 62, in execute
>> return self.cursor.execute(sql)
>> django.db.utils.ProgrammingError: relation "people_profile" does not exist
>> Of course I performed the update of the dbs after run git pull on geonode
>> dir.
>> Can you help me?
>> Eugenio
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geonode-users
Angelos Tzotsos, PhD
OSGeo Charter Member
http://users.ntua.gr/tzotsos
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160707/5474d6a2/attachment-0001.html>
More information about the geonode-users
