[GeoNode-users] Settings for migration scripts
Benjamin Ducke
benducke at fastmail.fm
Thu Jul 7 23:53:45 PDT 2016
Dear All --
I am in the process of migrating a GeoNode 2.0
instance to GeoNode 2.4.
I am following the instructions here:
https://github.com/capooti/geonode/blob/migration_from20_to_24/scripts/migrations/migrate20to24/index.rst
... and I have downloaded the migration scripts
mentioned on the page above.
At the last step, "create_auth_group_and_update_res.py"
throws this error message:
django.core.exceptions.ImproperlyConfigured: In order to use
django-guardian's ObjectPermissionBackend authorization backend you have
to configure ANONYMOUS_USER_ID at your settings module
I assume that the problem is a wrong setting in the
"[path]" section of "gn_migration.cfg"
My current settings are:
[path]
geonode_path = /usr/local/lib/python2.7/dist-packages/geonode/
settings_path = geonode.local_settings
What would be the correct settings for a GeoNode
installation on Ubuntu 14.04 using the official
packages?
Thanks and best,
Ben
More information about the geonode-users
