[GeoNode-users] Notes and remarks on GeoServer 2.9.x upgrade
Alessio Fabiani
alessio.fabiani at geo-solutions.it
Tue Jul 12 10:02:39 PDT 2016
Dear all,
the update to GeoServer 2.9.x is ready and automatically deployed by the
continuous builder with few remarks:
The WARs and data directories can be found here
http://build.geonode.org/geoserver/latest/
*ATTENTION:* for the moment the default packages (geoserver.war and
data.zip) are still based on the old GeoServer 2.7.4 version in order to
avoid issues during GeoNode installations
*THE NEW WARs/ZIPs* can be found on the same folder with the classifier
*2.9.x*
*ATTENTION: *GeoServer 2.9.x works **only** with Java 1.8+, so you need to
upgrade your Tomcat instances too.
*Summarizing:*
(http://build.geonode.org/geoserver/latest/)
*The following ones are related to GeoServer 2.9.x*
* - data-2.9.x.zip - geonode-geoserver-ext-2.9.x-geoserver-plugin.zip -
geoserver-2.9.x.war The following ones are related to GeoServer 2.7.4 -
data.zip - geonode-geoserver-ext-2.7.4-geoserver-plugin.zip -
geoserver.war *
*NOTICE THAT: *The automatic installations from Ubuntu and paver, still use
GeoServer 2.7.4
Best Regards,
Alessio Fabiani.
GeoServer Professional Services from the experts!
Visit http://goo.gl/it488V for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054 Massarosa (LU)
Italy
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39 331 6233686
http://www.geo-solutions.it
*AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160712/5c6abeeb/attachment.html>
More information about the geonode-users
