[GeoNode-users] java heap size error uploading shapefile
Alessio Fabiani alessio.fabiani at geo-solutions.it
Tue Jul 12 10:29:50 PDT 2016
Hi Chris,
it is a bit strange the fact that you are getting a heap OOM error, as
Daniel already said, it would be very useful to take a look at some logs in
order to get some more info on the issue.
In any case, if you upgraded the available memory on your server you should
also update the JVM Options.
If I understood correctly you now have about 8Gb RAM available, so maybe
could be helpful to set the options like follows:
JAVA_OPTS="-Xms1024m -Xmx*4096*m -XX:MaxPermSize=*1024*m"
NOTE: maybe 4Gb is too much for your needs, it depends on your specific use
case. You can also try with 2048m.
Best Regards,
Alessio Fabiani.
GeoServer Professional Services from the experts!
Visit http://goo.gl/it488V for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
*AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
On Tue, Jul 12, 2016 at 6:25 PM, Daniel Berry <dberry at boundlessgeo.com>
wrote:
> Chris,
> Is it possible to send any logs? Also what is your configuration:
> Proxy Server - Apache/NGINX
> Application Server - Tomcat/Jetty/JBOSS
> Respectfully,
> Dan
> On Mon, Jul 11, 2016 at 7:27 PM, Chris Jones <
> Chris.Jones at sunshinecoast.qld.gov.au> wrote:
>> Hi all
>> I’m trying to upload a 200mb shapefile from Geonode into a RDS postgis
>> database and keep getting a java heap size error. I have a separate EC2
>> instance running geoserver and have increased the instance to
>> T2 large so have 8gb RAM. Geoserver has no other layers and is not in
>> production so it’s not being heavily used at all.
>> I’ve also tested different settings for the java heap size (see below).
>> This is what it’s currently set to. I have increased these settings but the
>> error persists.
>> JAVA_OPTS="-Xms1024m -Xmx1024m -XX:MaxPermSize=512m"
>> Can anyone advise what to try next?? Is there a limitation on shapefile
>> size??
>> Any help would be greatly appreciated.
>> Thanks
>> Chris
>> Chris Jones | Geospatial Analyst
>> Geospatial & Asset Systems
>> Information Communications Technology Services | Sunshine Coast Council
>> *Phone:  07 5475 8717*
>> *Email: * *Chris.Jones at Sunshinecoast.qld.gov.au
>> <Chris.Jones at Sunshinecoast.qld.gov.au>*
>> *Address: * Locked Bag 72 Sunshine Coast Mail Centre QLD 4560.
>> *Website: * http://maps.sunshinecoast.qld.gov.au/MyMaps
>> P Please consider the environment before printing this email
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geonode-users
> *Daniel Berry*
> Senior Software Engineer | Boundless
> 512-468-3946 (cell)
> @boundlessgeo
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160712/68a52ff2/attachment-0001.html>
More information about the geonode-users mailing list
