[GeoNode-users] MapQuest changed direct tile access
Daniel Victoria
daniel.victoria at gmail.com
Wed Jul 13 09:27:45 PDT 2016
Hi Simone et al,
Since we have a couple of servers running GeoNode, I though of placing the
python commands to change the background values in a script that could by
run ussing the 'geonode runscript' command. So I followed this Django
runscript example [1] and for testing purposes, created a script to list
all map names with the following content:
# scripts/change_basemaps_maps.py
from geonode.maps.models import MapLayer
def run():
for m in MapLayer.objects.iterate():
print m.name
When I issued the command 'geonode runscript /scripts/change_basemaps_maps'
I got a large error about the leaflet plugin, copied bellow:
daniel at daniel-VirtualBox:~/geonode/customizacao_ide_embrapa/scripts$
geonode runscript change_basemap_maps
Not enabling BingMaps base layer as a BING_API_KEY is not defined in
local_settings.py file.
File "/usr/bin/django-admin.py", line 5, in <module>
management.execute_from_command_line()
File
"/usr/lib/python2.7/dist-packages/django/core/management/__init__.py", line
399, in execute_from_command_line
utility.execute()
File
392, in execute
self.fetch_command(subcommand).run_from_argv(self.argv)
File "/usr/lib/python2.7/dist-packages/django/core/management/base.py",
line 242, in run_from_argv
self.execute(*args, **options.__dict__)
line 285, in execute
output = self.handle(*args, **options)
File
"/usr/lib/pymodules/python2.7/django_extensions/management/commands/runscript.py",
line 140, in handle
modules = find_modules_for_script(script)
File
line 115, in find_modules_for_script
mod = my_import("%s.%s.%s" % (app, subdir, script))
File
line 91, in my_import
path = imp.load_module(package, *module_tuple).__path__
File "/usr/lib/python2.7/dist-packages/leaflet/__init__.py", line 110, in
<module>
raise ImproperlyConfigured(error_msg)
django.core.exceptions.ImproperlyConfigured: LEAFLET_CONFIG['PLUGINS'] must
be dict of dicts in the format:
{ '[plugin_name]': { 'js': '[path-to-js]', 'css': '[path-to-css]' } } .)
Is there something else that is broken and that's why I can't call my
script? Any idea how to fix this?
Thanks
Daniel
[1] - http://django-extensions.readthedocs.io/en/latest/runscript.html
On Wed, Jul 13, 2016 at 11:29 AM, Daniel Victoria <daniel.victoria at gmail.com
> wrote:
> Great, will try that. Thanks
> On Wed, Jul 13, 2016 at 11:12 AM, Simone Dalmasso <
> simone.dalmasso at gmail.com> wrote:
>> Hi, you have to remove mapquest from your settings like here
>> https://github.com/GeoNode/geonode/commit/42d589cd9d86fa76fc9a9afd2eeacdf64c939705
>> and make mapnik the default one like here:
>> https://github.com/GeoNode/geonode/commit/8cb080534e69c590c8864a2603b2ea1eca2e8a73
>> 2016-07-13 16:08 GMT+02:00 Daniel Victoria <daniel.victoria at gmail.com>:
>>> Hi,
>>> This worked for my saved maps. Thanks.
>>> But how about the layers page (e.g.: /layers/geonode%4A<some layer
>>> name>) ? I'm still getting Mapquest as default background. Where do I
>>> change that?
>>> cheers
>>> Daniel
>>> On Wed, Jul 13, 2016 at 10:09 AM, Simone Dalmasso <
>>>> Hi, the following commands will use mapnik instead of mapquest
>>>> background for all saved maps:
>>>> $ geonode shell
>>>> >>>MapLayer.objects.filter(name='osm').update(visibility=False)
>>>> >>>MapLayer.objects.filter(name='mapnik').update(visibility=True)
>>>> for new maps you can remove the mapquest entries in MAP_BASELAYERS.
>>>> Hope this helps
>>>> 2016-07-13 14:45 GMT+02:00 Daniel Victoria <daniel.victoria at gmail.com>:
>>>>> Hi list,
>>>>> This is probably affecting others. I just opened a layer in GeoNode
>>>>> and saw that MapQuest changed their direct tile access policy [1]. Thus,
>>>>> the background of all my layers are messed up.
>>>>> How can I make geonode use some other basemap as default? Or fix my
>>>>> basemap issue?
>>>>> Thanks
>>>>> Daniel
>>>>> [1] -
>>>>> http://devblog.mapquest.com/2016/06/15/modernization-of-mapquest-results-in-changes-to-open-tile-access/
>>>>> _______________________________________________
>>>>> geonode-users mailing list
>>>>> geonode-users at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/geonode-users
>>>> Simone
>> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160713/e60eed04/attachment.html>
More information about the geonode-users
