[GeoNode-users] MapQuest changed direct tile access
Daniel Victoria
daniel.victoria at gmail.com
Wed Jul 13 09:48:58 PDT 2016
looks the same here...
On Wed, Jul 13, 2016 at 1:43 PM, Simone Dalmasso <simone.dalmasso at gmail.com>
wrote:
> Strange,
> can you make sure that the leaflet config looks like this?
> https://github.com/GeoNode/geonode/blob/2.4.x/geonode/settings.py#L773
> 2016-07-13 18:27 GMT+02:00 Daniel Victoria <daniel.victoria at gmail.com>:
>> Hi Simone et al,
>> Since we have a couple of servers running GeoNode, I though of placing
>> the python commands to change the background values in a script that could
>> by run ussing the 'geonode runscript' command. So I followed this Django
>> runscript example [1] and for testing purposes, created a script to list
>> all map names with the following content:
>> # scripts/change_basemaps_maps.py
>> from geonode.maps.models import MapLayer
>> def run():
>> for m in MapLayer.objects.iterate():
>> print m.name
>> When I issued the command 'geonode runscript
>> /scripts/change_basemaps_maps' I got a large error about the leaflet
>> plugin, copied bellow:
>> daniel at daniel-VirtualBox:~/geonode/customizacao_ide_embrapa/scripts$
>> geonode runscript change_basemap_maps
>> Not enabling BingMaps base layer as a BING_API_KEY is not defined in
>> local_settings.py file.
>> Traceback (most recent call last):
>> File "/usr/bin/django-admin.py", line 5, in <module>
>> management.execute_from_command_line()
>> File
>> "/usr/lib/python2.7/dist-packages/django/core/management/__init__.py", line
>> 399, in execute_from_command_line
>> utility.execute()
>> File
>> 392, in execute
>> self.fetch_command(subcommand).run_from_argv(self.argv)
>> File "/usr/lib/python2.7/dist-packages/django/core/management/base.py",
>> line 242, in run_from_argv
>> self.execute(*args, **options.__dict__)
>> line 285, in execute
>> output = self.handle(*args, **options)
>> File
>> "/usr/lib/pymodules/python2.7/django_extensions/management/commands/runscript.py",
>> line 140, in handle
>> modules = find_modules_for_script(script)
>> File
>> line 115, in find_modules_for_script
>> mod = my_import("%s.%s.%s" % (app, subdir, script))
>> File
>> line 91, in my_import
>> path = imp.load_module(package, *module_tuple).__path__
>> File "/usr/lib/python2.7/dist-packages/leaflet/__init__.py", line 110,
>> in <module>
>> raise ImproperlyConfigured(error_msg)
>> django.core.exceptions.ImproperlyConfigured: LEAFLET_CONFIG['PLUGINS']
>> must be dict of dicts in the format:
>> { '[plugin_name]': { 'js': '[path-to-js]', 'css': '[path-to-css]' } }
>> Is there something else that is broken and that's why I can't call my
>> script? Any idea how to fix this?
>> Thanks
>> Daniel
>> [1] - http://django-extensions.readthedocs.io/en/latest/runscript.html
>> On Wed, Jul 13, 2016 at 11:29 AM, Daniel Victoria <
>> daniel.victoria at gmail.com> wrote:
>>> Great, will try that. Thanks
>>> On Wed, Jul 13, 2016 at 11:12 AM, Simone Dalmasso <
>>> simone.dalmasso at gmail.com> wrote:
>>>> Hi, you have to remove mapquest from your settings like here
>>>> https://github.com/GeoNode/geonode/commit/42d589cd9d86fa76fc9a9afd2eeacdf64c939705
>>>> and make mapnik the default one like here:
>>>> https://github.com/GeoNode/geonode/commit/8cb080534e69c590c8864a2603b2ea1eca2e8a73
>>>> 2016-07-13 16:08 GMT+02:00 Daniel Victoria <daniel.victoria at gmail.com>:
>>>>> Hi,
>>>>> This worked for my saved maps. Thanks.
>>>>> But how about the layers page (e.g.: /layers/geonode%4A<some layer
>>>>> name>) ? I'm still getting Mapquest as default background. Where do I
>>>>> change that?
>>>>> cheers
>>>>> Daniel
>>>>> On Wed, Jul 13, 2016 at 10:09 AM, Simone Dalmasso <
>>>>>> Hi, the following commands will use mapnik instead of mapquest
>>>>>> background for all saved maps:
>>>>>> $ geonode shell
>>>>>> >>>MapLayer.objects.filter(name='osm').update(visibility=False)
>>>>>> >>>MapLayer.objects.filter(name='mapnik').update(visibility=True)
>>>>>> for new maps you can remove the mapquest entries in MAP_BASELAYERS.
>>>>>> Hope this helps
>>>>>> 2016-07-13 14:45 GMT+02:00 Daniel Victoria <daniel.victoria at gmail.com
>>>>>>> Hi list,
>>>>>>> This is probably affecting others. I just opened a layer in GeoNode
>>>>>>> and saw that MapQuest changed their direct tile access policy [1]. Thus,
>>>>>>> the background of all my layers are messed up.
>>>>>>> How can I make geonode use some other basemap as default? Or fix my
>>>>>>> basemap issue?
>>>>>>> Thanks
>>>>>>> Daniel
>>>>>>> [1] -
>>>>>>> http://devblog.mapquest.com/2016/06/15/modernization-of-mapquest-results-in-changes-to-open-tile-access/
>>>>>>> _______________________________________________
>>>>>>> geonode-users mailing list
>>>>>>> geonode-users at lists.osgeo.org
>>>>>>> http://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>>> Simone
>>>> Simone
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160713/04118cb9/attachment-0001.html>
More information about the geonode-users
