[GeoNode-users] Error creating superuser (gn2.4 on Debian)
Cristian Zamar cristian_zamar at hotmail.com
Fri Jul 15 11:42:38 PDT 2016
Hi all,
I'm trying to install GeoNode 2.4 on Debian 8.5 following the manual installation from the docs:
http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/index.html
Everything was going right until this step:
python manage.py createsuperuser
the error log is:
  File "manage.py", line 29, in <module>
    execute_from_command_line(sys.argv)
  File "/usr/local/lib/python2.7/dist-packages/django/core/management/__init__.py", line 354, in execute_from_command_line
    utility.execute()
  File "/usr/local/lib/python2.7/dist-packages/django/core/management/__init__.py", line 346, in execute
    self.fetch_command(subcommand).run_from_argv(self.argv)
  File "/usr/local/lib/python2.7/dist-packages/django/core/management/base.py", line 394, in run_from_argv
    self.execute(*args, **cmd_options)
  File "/usr/local/lib/python2.7/dist-packages/django/contrib/auth/management/commands/createsuperuser.py", line 50, in execute
    return super(Command, self).execute(*args, **options)
  File "/usr/local/lib/python2.7/dist-packages/django/core/management/base.py", line 445, in execute
    output = self.handle(*args, **options)
  File "/usr/local/lib/python2.7/dist-packages/django/contrib/auth/management/commands/createsuperuser.py", line 105, in handle
    self.UserModel._default_manager.db_manager(database).get_by_natural_key(username)
  File "/usr/local/lib/python2.7/dist-packages/django/contrib/auth/models.py", line 162, in get_by_natural_key
    return self.get(**{self.model.USERNAME_FIELD: username})
  File "/usr/local/lib/python2.7/dist-packages/django/db/models/manager.py", line 127, in manager_method
    return getattr(self.get_queryset(), name)(*args, **kwargs)
  File "/usr/local/lib/python2.7/dist-packages/django/db/models/query.py", line 328, in get
    num = len(clone)
  File "/usr/local/lib/python2.7/dist-packages/django/db/models/query.py", line 144, in __len__
    self._fetch_all()
  File "/usr/local/lib/python2.7/dist-packages/django/db/models/query.py", line 965, in _fetch_all
    self._result_cache = list(self.iterator())
  File "/usr/local/lib/python2.7/dist-packages/django/db/models/query.py", line 238, in iterator
    results = compiler.execute_sql()
  File "/usr/local/lib/python2.7/dist-packages/django/db/models/sql/compiler.py", line 840, in execute_sql
    cursor.execute(sql, params)
  File "/usr/local/lib/python2.7/dist-packages/django/db/backends/utils.py", line 79, in execute
    return super(CursorDebugWrapper, self).execute(sql, params)
  File "/usr/local/lib/python2.7/dist-packages/django/db/backends/utils.py", line 64, in execute
    return self.cursor.execute(sql, params)
  File "/usr/local/lib/python2.7/dist-packages/django/db/utils.py", line 98, in __exit__
    six.reraise(dj_exc_type, dj_exc_value, traceback)
django.db.utils.ProgrammingError: no existe la relación «people_profile»
LINE 1: ...ofile"."zipcode", "people_profile"."country" FROM "people_pr...
I see the geonode database is empty (no tables). Am I missing any step?
I've tried with syncdb but I got a similar error.
Hope you can help me.
Thanks in advance.
Lic. CRISTIAN R. ZAMAR
Developer - GIS Specialist
+54 370 4271736
linkedin
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160715/43617847/attachment-0001.html>
More information about the geonode-users mailing list
