[GeoNode-users] Error creating superuser (gn2.4 on Debian)
Cristian Zamar cristian_zamar at hotmail.com
Sat Jul 16 16:49:08 PDT 2016
Thank you Simone!! you were right about my wrong branch and now it works on Debian 8.5 :D
I will PR some changes on the docs soon.
Regards
Lic. CRISTIAN R. ZAMAR
Developer - GIS Specialist
+54 370 4271736
linkedin
Date: Sat, 16 Jul 2016 08:25:35 +0200
Subject: Re: [GeoNode-users] Error creating superuser (gn2.4 on Debian)
To: cristian_zamar at hotmail.com
CC: geonode-users at lists.osgeo.org
Hi, if you pulled from the master branch then is a Dev version with some changes. To create the db you have to use Python manage.py migrate.
If you want to stay with 2.4 then checkout the branch 2.4.x.
Hope this helps
Il venerdì 15 luglio 2016, Cristian Zamar <cristian_zamar at hotmail.com> ha scritto:
Hi all,
I'm trying to install GeoNode 2.4 on Debian 8.5 following the manual installation from the docs:
http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/index.html
Everything was going right until this step:
python manage.py createsuperuser
the error log is:
  File "manage.py", line 29, in <module>
    execute_from_command_line(sys.argv)
  File "/usr/local/lib/python2.7/dist-packages/django/core/management/__init__.py", line 354, in execute_from_command_line
    utility.execute()
  File "/usr/local/lib/python2.7/dist-packages/django/core/management/__init__.py", line 346, in execute
    self.fetch_command(subcommand).run_from_argv(self.argv)
  File "/usr/local/lib/python2.7/dist-packages/django/core/management/base.py", line 394, in run_from_argv
    self.execute(*args, **cmd_options)
  File "/usr/local/lib/python2.7/dist-packages/django/contrib/auth/management/commands/createsuperuser.py", line 50, in execute
    return super(Command, self).execute(*args, **options)
  File "/usr/local/lib/python2.7/dist-packages/django/core/management/base.py", line 445, in execute
    output = self.handle(*args, **options)
  File "/usr/local/lib/python2.7/dist-packages/django/contrib/auth/management/commands/createsuperuser.py", line 105, in handle
    self.UserModel._default_manager.db_manager(database).get_by_natural_key(username)
  File "/usr/local/lib/python2.7/dist-packages/django/contrib/auth/models.py", line 162, in get_by_natural_key
    return self.get(**{self.model.USERNAME_FIELD: username})
  File "/usr/local/lib/python2.7/dist-packages/django/db/models/manager.py", line 127, in manager_method
    return getattr(self.get_queryset(), name)(*args, **kwargs)
  File "/usr/local/lib/python2.7/dist-packages/django/db/models/query.py", line 328, in get
    num = len(clone)
  File "/usr/local/lib/python2.7/dist-packages/django/db/models/query.py", line 144, in __len__
    self._fetch_all()
  File "/usr/local/lib/python2.7/dist-packages/django/db/models/query.py", line 965, in _fetch_all
    self._result_cache = list(self.iterator())
  File "/usr/local/lib/python2.7/dist-packages/django/db/models/query.py", line 238, in iterator
    results = compiler.execute_sql()
  File "/usr/local/lib/python2.7/dist-packages/django/db/models/sql/compiler.py", line 840, in execute_sql
    cursor.execute(sql, params)
  File "/usr/local/lib/python2.7/dist-packages/django/db/backends/utils.py", line 79, in execute
    return super(CursorDebugWrapper, self).execute(sql, params)
  File "/usr/local/lib/python2.7/dist-packages/django/db/backends/utils.py", line 64, in execute
    return self.cursor.execute(sql, params)
  File "/usr/local/lib/python2.7/dist-packages/django/db/utils.py", line 98, in __exit__
    six.reraise(dj_exc_type, dj_exc_value, traceback)
django.db.utils.ProgrammingError: no existe la relación «people_profile»
LINE 1: ...ofile"."zipcode", "people_profile"."country" FROM "people_pr...
I see the geonode database is empty (no tables). Am I missing any step?
I've tried with syncdb but I got a similar error.
Hope you can help me.
Thanks in advance.
+54 370 4271736
linkedin
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160716/160f2052/attachment.html>
More information about the geonode-users mailing list
