[GeoNode-users] Deleted layers persist in Geonode
Simone Dalmasso
simone.dalmasso at gmail.com
Fri Jun 3 01:18:30 PDT 2016
Hi, do you have any stacktrace from /var/logs/apache2/error.log of when you
try to delete one layer from the admin console?
2016-06-02 22:18 GMT+02:00 Stefan Steiniger <sstein at geo.uzh.ch>:
> Perhaps the last option may be to check the Database(s) directly, e.g.
> connecting with PgAdmin.
> stefan
> On 02-06-2016 11:58, Nic Tait wrote:
> Hello Geonode users,
> I added layers to Geonode from an external service and then deleted them
> in Geoserver but they are still visible as empty layers in 'Explore Layers'
> and the 'Admin console' within Geonode
> I deleted the relevant layers , stores and workspace in Geoserver and
> cannot find any other reference in Geoserver and then ran the management
> command:
> 'python manage.py updatelayers --remove-deleted'
> which returned '[delete_failed]' for all the layers
> Layers are still visible in the admin console but get 'Internal Server
> Error' when trying to delete them this way.
> Have restarted Geonode with 'sudo service apache2 restart' as well to see
> if that might fix but no luck
> Any ideas on how to proceed ?
> Regards,
> Nic
> geonode-users mailing listgeonode-users at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/geonode-users
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160603/3cf96c9e/attachment.html>
More information about the geonode-users
