[GeoNode-users] FW: Running GeoNode 2.4 on Ubuntu
Franklin, Chris CFranklin at AngloGoldAshanti.com
Mon Jun 6 17:15:25 PDT 2016
Hi Jeffery,
I can see the UI for GeoServer instance and I can see the data in the open layers viewer with the correct style applied in GeoNode.
[cid:image002.png at 01D1C094.AA8B6550]
http://172.16.0.101:32770/geoserver/geonode/wms?service=WMS&version=1.1.0&request=GetMap&layers=geonode:geoheritage&styles=&bbox=1.2018575442992084E7,-4160946.9365616455,1.5006434018685888E7,-1671701.8885140594&width=768&height=639&srs=EPSG:900913&format=application/openlayers
Regards
Chris Franklin
GIS and Database Co-ordinator
Exploration Australia
[cid:image001.jpg at 01D1C094.AA9613B0]
Tel:         +61 08 9425 4719
Fax:        +61 08 9425 4650
Email:      cfranklin at anglogoldashanti.com<mailto:cfranklin at anglogoldashanti.com>
Consider the environment. Think before you print.
From: Jeffrey Johnson [mailto:ortelius at gmail.com]
Sent: Tuesday, 7 June 2016 8:07 AM
To: Franklin, Chris <CFranklin at AngloGoldAshanti.com>
Cc: Simone Dalmasso <simone.dalmasso at gmail.com>; geonode-users at lists.osgeo.org
Subject: Re: [GeoNode-users] FW: Running GeoNode 2.4 on Ubuntu
Is http://localhost:8080/geoserver itself answering?
On Mon, Jun 6, 2016 at 5:04 PM, Franklin, Chris <CFranklin at anglogoldashanti.com<mailto:CFranklin at anglogoldashanti.com>> wrote:
The base url is:
1.  Request URL:
http://localhost:8080/geoserver/wms?LAYERS=geonode%3Ageoheritage&FORMAT=image%2Fjpeg&TRANSPARENT=FALSE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=12523442.7125,-3757032.81375,13775786.98375,-2504688.5425&WIDTH=256&HEIGHT=256
[cid:image007.png at 01D1C094.AA8B6550]
Thanks
Chris Franklin
[cid:image008.jpg at 01D1C094.AA8B6550]
Tel:         +61 08 9425 4719<tel:%2B61%2008%209425%204719>
Fax:        +61 08 9425 4650<tel:%2B61%2008%209425%204650>
From: Jeffrey Johnson [mailto:ortelius at gmail.com<mailto:ortelius at gmail.com>]
Sent: Tuesday, 7 June 2016 8:01 AM
To: Franklin, Chris <CFranklin at AngloGoldAshanti.com<mailto:CFranklin at AngloGoldAshanti.com>>
Cc: Simone Dalmasso <simone.dalmasso at gmail.com<mailto:simone.dalmasso at gmail.com>>; geonode-users at lists.osgeo.org<mailto:geonode-users at lists.osgeo.org>
Can you let us know what URL is being requested. We only see the wms part not the root URL
On Mon, Jun 6, 2016 at 4:53 PM, Franklin, Chris <CFranklin at anglogoldashanti.com<mailto:CFranklin at anglogoldashanti.com>> wrote:
Sorry for the delay in replying, I have checked the errors in the F12 dev tools and found the connection was refused: (failed) net::ERR_CONNECTION_REFUSED – what do I need to do here?
[cid:image009.png at 01D1C094.AA8B6550]
Thanks
Chris Franklin
[cid:image010.jpg at 01D1C094.AA8B6550]
From: Simone Dalmasso [mailto:simone.dalmasso at gmail.com]
Sent: Saturday, 4 June 2016 6:22 PM
Cc: Stefan Steiniger <sstein at geo.uzh.ch<mailto:sstein at geo.uzh.ch>>; geonode-users at lists.osgeo.org<mailto:geonode-users at lists.osgeo.org>
Subject: Re: [GeoNode-users] Running GeoNode 2.4 on Ubuntu
Hi, you can use the browser developer toolbar to track what happens when the client is requesting one of the urls that return a pink tile. In the network panel right click on one of the failing requests and open in a new tab. It should download a file containing some clues on the error.
2016-06-03 23:00 GMT+02:00 Franklin, Chris <CFranklin at anglogoldashanti.com<mailto:CFranklin at anglogoldashanti.com>>:
Hi Stefan,
Yes I do, with the style applied in geonode.
Chris Franklin
On 4 Jun 2016, at 02:33, Stefan Steiniger <sstein at geo.uzh.ch<mailto:sstein at geo.uzh.ch>> wrote:
could be an access problem. If you go as Admin to the Geoserver UI and check in the Layer-Preview using OpenLayers button, do you see your map data there?
stefan
------ Originalnachricht ------
Von: Franklin, Chris
Datum: 03.06.2016 11:40
An: geonode-users at lists.osgeo.org<mailto:geonode-users at lists.osgeo.org>;
Betreff:[GeoNode-users] Running GeoNode 2.4 on Ubuntu
I have the interface working no problem, can upload shp files but when trying to view in either the layer view of map view I get Geoservers pink squares of death?
Can see the data in the openlayers view from GS itself sop I know the data is good.
Can anyone help me out?
Chris
This email, and its attachments, is subject to important warnings and disclaimers which are legally incorporated into this email in terms of Section 11(3) of the South African Electronic Communications and Transactions Act, 25 of 2002. The full text of the warnings and disclaimers, together with the company details and directors is available by clicking on http://www.anglogoldashanti.com/en/Pages/legal.aspx
geonode-users mailing list
http://lists.osgeo.org/mailman/listinfo/geonode-users
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160607/c1e2f3a5/attachment-0001.html>
Type: image/png
Desc: image002.png
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160607/c1e2f3a5/attachment-0003.png>
Type: image/png
Desc: image007.png
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160607/c1e2f3a5/attachment-0004.png>
Type: image/jpeg
Desc: image008.jpg
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160607/c1e2f3a5/attachment-0003.jpg>
Type: image/png
Desc: image009.png
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160607/c1e2f3a5/attachment-0005.png>
Type: image/jpeg
Desc: image010.jpg
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160607/c1e2f3a5/attachment-0004.jpg>
Type: image/jpeg
Desc: image001.jpg
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160607/c1e2f3a5/attachment-0005.jpg>
More information about the geonode-users mailing list
