[GeoNode-users] Error: IP Change
Miguel Torres
migtorres at gmail.com
Mon Jun 13 07:33:01 PDT 2016
It shows me the right ones ['10.2.0.122', 'localhost']
2016-06-13 13:22 GMT+01:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
> Hm, let's check it the settings are correctly used, type the following:
> $ geonode shell
> >>> from django.conf import settings
> >>> settings. ALLOWED_HOSTS
> and see is the output is as expected.
> 2016-06-13 10:17 GMT+02:00 Miguel Torres <migtorres at gmail.com>:
>> Yes, I have restarted apache2 and tomcat7 several times and tryed
>> ALLOWED_HOSTS = ['*'] just to test and still got the 400 error
>> 2016-06-13 6:16 GMT+01:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
>>> Hi Miguel,
>>> have you tried by restarting the web server? Maybe that part was skipped
>>> in the updateip command
>>> 2016-06-12 23:42 GMT+02:00 Miguel Torres <migtorres at gmail.com>:
>>>> Hi!
>>>> I have changed the ip address of the server with our Geonode installation
>>>> and I have ran geonode-updateip to point to the new one.
>>>> When I try to access it shows Bad Request (400). In the logs it shows:
>>>> Invalid HTTP_HOST header: 'MY-IP'.You may need to add u'MY-IP' to
>>>> ALLOWED_HOSTS
>>>> I have checked in local_settings.py and I have:
>>>> ALLOWED_HOSTS= [ 'MY-IP', 'localhost', ]
>>>> So it seems to be ok.
>>>> Do you have any idea of what should be happening?
>>>> Best,
>>>> Miguel Torres
>>>> _______________________________________________
>>>> geonode-users mailing list
>>>> geonode-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/geonode-users
>>> Simone
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160613/40a358f1/attachment-0001.html>
More information about the geonode-users
