[GeoNode-users] Create Geonode-Project Problem
Francesco Bartoli
xbartolone at gmail.com
Wed Jun 15 11:36:41 PDT 2016
Hi Carlo,
can you please try the same procedure within a virtualenv environment?
Francesco
Il giorno 15/giu/2016, alle ore 20:04, Carlo Di Michele <carlo.dimichele at gmail.com> ha scritto:
> Hello,
> I've a clean installation of geonode 2.4. using the quick install.
> Everything works fine.
> Now I wish to create an app using Geonode-Project 2.4 and I'm facing the following problem typing:
> $ django-admin startproject my_geonode --template=https://github.com/GeoNode/geonode-project/archive/2.4.zip -epy,rst
> The error message is:
> The program 'django-admin' is currently not installed. You can install it by typing:
> sudo apt-get install python-django
> So I type:
> and the message is:
> Reading package lists... Done
> Building dependency tree
> Reading state information... Done
> python-django is already the newest version.
> 0 upgraded, 0 newly installed, 0 to remove and 137 not upgraded.
> Typing again:
> Again The error message is:
> If I skip the $ django-admin startproject my_geonode --template=htt........ and I go directly to:
> $ sudo pip install -e my_geonode
> The message is:
> my_geonode should either be a path to a local project or a VCS url beginning with svn+, git+, hg+, or bzr+
> Storing debug log for failure in /home/carlo/.pip/pip.log
> Thanks for any hint.
> Regards
> Carlo
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160615/faefed14/attachment.html>
More information about the geonode-users
