[GeoNode-users] Internal server error when adding WMS remote service... but it works using add layers in GEOXP..
Paolo Corti
pcorti at gmail.com
Wed Jun 15 13:41:24 PDT 2016
Hi Amedeo
could you please provide more details about the way you are
registering the remote service?
Are you using the GetCapabilities WMS endpoint or something different?
p
On Mon, Jun 13, 2016 at 6:26 AM, Amedeo Fadini <amefad at gmail.com> wrote:
> Hi everybody..
> I'm using Geonode 2.4 installed with apt-get from ubuntu ppa.
> I have a strange behaviour with remote WMS service: when I try to
> register a new service for Regione Emilia romagna serivces like
> http://servizigis.regione.emilia-romagna.it/wms/dbtr2013_ctr5_light
> Geonode doesn't create the new remote service and raise an "internal
> server error". Inside Apache logs i can see that the djiango function
> reverse() fails adding the url.
> I discovered that is still possible add the WMS layer to my map using
> the add layer command in Geoexplorer and then Add new server".
> It raise the error "internal server error" and in the popoup window
> this log lines pasted below. It seems to me that the trouble is on the
> remote server side, but I'm not so sure
> Maybe could be useful to others that are trying to register a new WMS
> service and use geoexplorer.
> Amedeo Fadini
> java.net.ConnectException: Connection refused: connect
> java.net.PlainSocketImpl.socketConnect(Native Method)
> java.net.PlainSocketImpl.doConnect(Unknown Source)
> java.net.PlainSocketImpl.connectToAddress(Unknown Source)
> java.net.PlainSocketImpl.connect(Unknown Source)
> java.net.SocksSocketImpl.connect(Unknown Source)
> java.net.Socket.connect(Unknown Source)
> java.net.Socket.<init>(Unknown Source)
> com.esri.arcgis.interop.PDUManagerImpl$0.run(Unknown Source)
> java.security.AccessController.doPrivileged(Native Method)
> com.esri.arcgis.interop.PDUManagerImpl.openConnection(Unknown Source)
> com.esri.arcgis.interop.RpcConnectionHandler.a(Unknown Source)
> com.esri.arcgis.interop.RpcConnectionHandler.<init>(Unknown Source)
> com.esri.arcgis.interop.gb.a(Unknown Source)
> com.esri.arcgis.interop.StdObjRef.a(Unknown Source)
> com.esri.arcgis.interop.Dispatch.vtblInvoke(Unknown Source)
> com.esri.arcgis.server.IServerContextProxy.releaseContext(Unknown Source)
> com.esri.arcgisws.ServiceHandlerServlet.a(Unknown Source)
> com.esri.arcgisws.ServiceHandlerServlet.doGet(Unknown Source)
> javax.servlet.http.HttpServlet.service(HttpServlet.java:624)
> javax.servlet.http.HttpServlet.service(HttpServlet.java:731)
> com.esri.arcgisws.DispatcherServlet.service(Unknown Source)
> org.apache.catalina.filters.CorsFilter.handleNonCORS(CorsFilter.java:436)
> org.apache.catalina.filters.CorsFilter.doFilter(CorsFilter.java:177)
> com.esri.arcgis.security.filter.TokenFilter.doFilter(Unknown Source)
> note The full stack trace of the root cause is available in the
> Regione Emilia-Romagna/2.0.1 logs.
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geonode-users
Paolo Corti
Geospatial software developer
web: http://www.paolocorti.net
twitter: @capooti
skype: capooti
More information about the geonode-users
