[GeoNode-users] Create Geonode-Project Problem
Carlo Di Michele
carlo.dimichele at gmail.com
Thu Jun 16 00:12:05 PDT 2016
Thanks to everybody, worked perfectly using django-admin.py
Regards
Carlo
2016-06-15 20:57 GMT+01:00 Finnegan Pope-Carter <
f.pope-carter at magnitudesurveys.co.uk>:
> I had exactly the same issue today when attempting to modify the geonode
> styling.
> Replace django-admin with django-admin.py and it worked correctly.
> This was sent using a LG Mobile. On O2
> ------ Original message------
> *From: *Carlo Di Michele
> *Date: *Wed, 15 Jun 2016 19:04
> *To: *geonode-users;
> *Cc: *
> *Subject:*[GeoNode-users] Create Geonode-Project Problem
> Hello,
> I've a clean installation of geonode 2.4. using the quick install.
> Everything works fine.
> Now I wish to create an app using Geonode-Project 2.4 and I'm facing the
> following problem typing:
> $ django-admin startproject my_geonode --template=https://github.com/GeoNode/geonode-project/archive/2.4.zip -epy,rst
> The error message is:
> The program 'django-admin' is currently not installed. You can install it by typing:
> sudo apt-get install python-django
> So I type:
> and the message is:
> Reading package lists... Done
> Building dependency tree
> Reading state information... Done
> python-django is already the newest version.
> 0 upgraded, 0 newly installed, 0 to remove and 137 not upgraded.
> Typing again:
> Again The error message is:
> If I skip the $ django-admin startproject my_geonode
> --template=htt........ and I go directly to:
> $ sudo pip install -e my_geonode
> The message is:
> my_geonode should either be a path to a local project or a VCS url
> beginning with svn+, git+, hg+, or bzr+
> Storing debug log for failure in /home/carlo/.pip/pip.log
> Thanks for any hint.
> Regards
> Carlo
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160616/dd3726b8/attachment.html>
More information about the geonode-users
