[GeoNode-users] Error Updating Ip
Finnegan Pope-Carter f.pope-carter at magnitudesurveys.co.uk
Fri Jun 17 02:20:16 PDT 2016
Hi Paolo
Thanks for your help, I checked and one layer had the incorrect ows_url field which I’ve updated to match the rest.
This appears to have had the desired effect for that one layer (Which is an external cascading wms layer) however it hasn’t worked for the layers which are stored on geoserver
These layers are still being loaded from geonode.magnitudesurveys.com even though the ows_url field for these layers is gis.magnitudesurveys.com as shown below:
124;37;8;"image/png";"geonode:MSSP14_MG_Poly";1;"''";TRUE;FALSE;"";TRUE;"http://gis.magnitudesurveys.com/geoserver/wms";"{"attribution": null, "restUrl": "/gs/rest", "bbox": [-175047.00181363, 6868012.1607306, -174085.22390339, 6868848.3795379], "cached": false, "title": "MSSP14_MG_Poly", "url": "http://geonode.magnitudesurveys.com/geoserver/wms", "selected": false, "srs": "EPSG:900913", "queryable": true, "tiled": true}";"{"restUrl": "/gs/rest", "title": "My GeoServer WMS", "baseParams": {"VERSION": "1.1.1", "REQUEST": "GetCapabilities", "TILED": true, "SERVICE": "WMS"}, "ptype": "gxp_wmscsource", "id": "3"}";TRUE
It appears that the url parameter in layar_params_text is overriding the ows_url field
I’m not particularly strong on postgres commands so I’m not sure how to automatically change the values. It also appears that the keys are still loading from geonode.magnitudesurveys.com
Thanks
FInn
Sent: 16 June 2016 15:41
To: Finnegan Pope-Carter <f.pope-carter at magnitudesurveys.co.uk>
Cc: geonode-users at lists.osgeo.org
Subject: Re: [GeoNode-users] Error Updating Ip
After looking at your screenshot, it looks to me that updatemaplayerip did not work properly for all layers (not sure why).
Is the ows_url field correctly updated in the maps_maplayer table?
You can check with:
select ows_url from maps_maplayer;
p
On Thu, Jun 16, 2016 at 10:28 AM, Finnegan Pope-Carter <f.pope-carter at magnitudesurveys.co.uk<mailto:f.pope-carter at magnitudesurveys.co.uk>> wrote:
Hi Paolo
Yes updatelayers has also completed successfully.
Finn
From: Paolo Corti [mailto:pcorti at gmail.com<mailto:pcorti at gmail.com>]
Sent: 16 June 2016 15:23
To: Finnegan Pope-Carter <f.pope-carter at magnitudesurveys.co.uk<mailto:f.pope-carter at magnitudesurveys.co.uk>>
Cc: geonode-users at lists.osgeo.org<mailto:geonode-users at lists.osgeo.org>
Oh I was not aware that updateip is also changing SITEURL in settings, good to know.
Did the updatelayers command within geonode.updateip also completed successfully?
p
On Thu, Jun 16, 2016 at 10:08 AM, Finnegan Pope-Carter <f.pope-carter at magnitudesurveys.co.uk<mailto:f.pope-carter at magnitudesurveys.co.uk>> wrote:
SITEURL was updated automatically by updateip and I’ve manually checked local_settings and printed the settings out of the Django shell. SITEURL is definitely gis.magnitudesurveys.com<http://gis.magnitudesurveys.com>
Sent: 16 June 2016 14:44
Did you change SITEURL in your settings file?
p
On Thu, Jun 16, 2016 at 5:05 AM, Finnegan Pope-Carter <f.pope-carter at magnitudesurveys.co.uk<mailto:f.pope-carter at magnitudesurveys.co.uk>> wrote:
I originally had geonode running on the domain geonode.magnitudesurveys.com<http://geonode.magnitudesurveys.com>, I wanted to update the domain name to gis.magnitudesurveys.com<http://gis.magnitudesurveys.com>.
I’ve run sudo geonode-updateip gis.magnitudesurveys.com<http://gis.magnitudesurveys.com> which completes successfully.
When I navigate to a map view and inspect sources the majority of layers are still loading from geonode.magnitudesurveys.com<http://geonode.magnitudesurveys.com>. Am I missing a setting anywhere that needs updating as well as running updateip?
[cid:image001.png at 01D1C87F.D285A230]
Thanks in advance for your assistance
Finn
Finnegan Pope-Carter BSc (Hons) MSc FGS
Director of Research & Development
[horizontal-alpha_300px]<http://www.magnitudesurveys.co.uk/>
www.magnitudesurveys.co.uk<http://www.magnitudesurveys.co.uk>
Office: +44(0)1274 926020<tel:%2B44%280%291274%20926020>
Mobile: +44(0)1274 926022<tel:%2B44%280%291274%20926022>
The information in this email is confidential and solely for the use of the intended recipient(s). If you receive this email in error, please notify the sender and delete the email from your system immediately. In such circumstances, you must not make any use of the email or its contents.
Magnitude Surveys Ltd. Registered office: 50 Kirkgate, Shipley, West Yorkshire, BD18 3EL. Registered in England. Registered number: 09605400.
geonode-users mailing list
http://lists.osgeo.org/mailman/listinfo/geonode-users
Paolo Corti
Geospatial software developer
web: http://www.paolocorti.net
twitter: @capooti
skype: capooti
Paolo Corti
twitter: @capooti
skype: capooti
Paolo Corti
twitter: @capooti
skype: capooti
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160617/6154be2c/attachment-0001.html>
Type: image/png
Desc: image001.png
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160617/6154be2c/attachment-0002.png>
Type: image/png
Desc: image002.png
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160617/6154be2c/attachment-0003.png>
More information about the geonode-users mailing list
