[GeoNode-users] Error saving style back to server
Daniel Victoria daniel.victoria at gmail.com
Wed Jun 22 04:54:27 PDT 2016
Just an update. I checked the same thing on an internal test server that I
have (that I believe does not uses https) and I don't get the server error.
So it's probably the hostname mismatch thing that is preventing me to
change the layer style. Will talk to the network guys and hope they know
how to fix it.
cheers
Daniel
On Wed, Jun 22, 2016 at 8:34 AM, Daniel Victoria <daniel.victoria at gmail.com>
wrote:
> Hi Simone,
> Thanks for the tip. Looking at the apache2.log it appears that it's some
> problem with a cerificateHostnameMismatch. Am I reading the log correct?
> I'll talk to the people that maintains out network and see about this
> certificate.
> On the same topic, in local_setting.py what should I put in SITEURL. The
> actual name of my virtual machine (some funny thing like dmzv014)? Or the
> name it's known in the internet (https://www.some.pretty.name.here)
> Thanks
> Daniel
> On Wed, Jun 22, 2016 at 6:41 AM, Simone Dalmasso <
> simone.dalmasso at gmail.com> wrote:
>> Hi, take a look at the apache logs when the 500 error code appears, they
>> should tell you more.
>> 2016-06-21 20:12 GMT+02:00 Daniel Victoria <daniel.victoria at gmail.com>:
>>> Hi list,
>>> I have a GeoNode instance running on Ubuntu, installed via
>>> apt-get.Everything appears to be working fine however, when I try to change
>>> a layer style, I get the error: "There was an error saving the style
>>> back to the server."
>>> Looking at the development console, I see that when I try to alter the
>>> layer style there are 2 PUT calls to the server. The first one fails with
>>> error 500 Internal server error. This is the call that's sending the SLD to
>>> the server. The second one returns 200 OK and it's sending the a JSON
>>> {"layer":{"defaultStyle":{"name":"estados"},"styles":{},"enabled":true}}
>>> I'm trying to debug this error but can't find what is going on. I'm
>>> running behind a proxy server. Could this be a security setting? Is it
>>> normal that one PUT call fails and the other works?
>>> Thanks
>>> Daniel
>>> geonode-users mailing list
>>> geonode-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/geonode-users
>> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160622/ecef9dee/attachment.html>
More information about the geonode-users mailing list
