[GeoNode-users] database update error
Simone Dalmasso
simone.dalmasso at gmail.com
Mon Jun 27 04:16:41 PDT 2016
Eugenio, sorry for the delay.
I did not have time to test it on postgres so my suggestion at the moment
is to stick with the 2.4 stable release.
2016-06-23 11:22 GMT+02:00 Eugenio Trumpy <frippe12573 at hotmail.com>:
> Hi Simone,
> django is at 1.8.7 version, is that correct for the master? how can I
> check the version of the data model?
> However, from empty geonode db I run manage.py migrate auth:
> System check identified some issues:
> WARNINGS:
> account.EmailConfirmation.created: (fields.W161) Fixed default value
> provided.
> HINT: It seems you set a fixed date / time / datetime value as default
> for this field. This may not be what you want. If you want to have the
> current date as default, use `django.utils.timezone.now`
> dialogos.Comment.ip_address: (fields.W900) IPAddressField has been
> deprecated. Support for it (except in historical migrations) will be
> removed in Django 1.9.
> HINT: Use GenericIPAddressField instead.
> Operations to perform:
> Apply all migrations: auth
> Running migrations:
> Rendering model states... DONE
> Applying contenttypes.0001_initial... OK
> Applying contenttypes.0002_remove_content_type_name... OK
> Applying auth.0001_initial... OK
> Applying auth.0002_alter_permission_name_max_length... OK
> Applying auth.0003_alter_user_email_max_length... OK
> Applying auth.0004_alter_user_username_opts... OK
> Applying auth.0005_alter_user_last_login_null... OK
> Applying auth.0006_require_contenttypes_0002... OK
> Traceback (most recent call last):
> File "manage.py", line 29, in <module>
> execute_from_command_line(sys.argv)
> File
> "/usr/local/lib/python2.7/dist-packages/django/core/management/__init__.py",
> line 354, in execute_from_command_line
> utility.execute()
> File
> line 346, in execute
> self.fetch_command(subcommand).run_from_argv(self.argv)
> File
> "/usr/local/lib/python2.7/dist-packages/django/core/management/base.py",
> line 394, in run_from_argv
> self.execute(*args, **cmd_options)
> File
> line 445, in execute
> output = self.handle(*args, **options)
> File
> "/usr/local/lib/python2.7/dist-packages/django/core/management/commands/migrate.py",
> line 226, in handle
> emit_post_migrate_signal(created_models, self.verbosity,
> self.interactive, connection.alias)
> File
> "/usr/local/lib/python2.7/dist-packages/django/core/management/sql.py",
> line 280, in emit_post_migrate_signal
> using=db)
> File
> "/usr/local/lib/python2.7/dist-packages/django/dispatch/dispatcher.py",
> line 189, in send
> response = receiver(signal=self, sender=sender, **named)
> File
> "/usr/local/lib/python2.7/dist-packages/django/contrib/sites/management.py",
> line 20, in create_default_site
> if not Site.objects.using(using).exists():
> File "/usr/local/lib/python2.7/dist-packages/django/db/models/query.py",
> line 586, in exists
> return self.query.has_results(using=self.db)
> File
> "/usr/local/lib/python2.7/dist-packages/django/db/models/sql/query.py",
> line 484, in has_results
> return compiler.has_results()
> File
> "/usr/local/lib/python2.7/dist-packages/django/db/models/sql/compiler.py",
> line 811, in has_results
> return bool(self.execute_sql(SINGLE))
> File
> line 840, in execute_sql
> cursor.execute(sql, params)
> File
> "/usr/local/lib/python2.7/dist-packages/django/db/backends/utils.py", line
> 79, in execute
> return super(CursorDebugWrapper, self).execute(sql, params)
> File
> 64, in execute
> return self.cursor.execute(sql, params)
> File "/usr/local/lib/python2.7/dist-packages/django/db/utils.py", line
> 98, in __exit__
> six.reraise(dj_exc_type, dj_exc_value, traceback)
> File
> 64, in execute
> django.db.utils.ProgrammingError: relation "django_site" does not exist
> LINE 1: SELECT (1) AS "a" FROM "django_site" LIMIT 1
> then I run manage.py migrate sites:
> WARNINGS:
> provided.
> Apply all migrations: sites
> Running migrations:
> Applying sites.0001_initial... OK
> File
> utility.execute()
> File
> File
> File
> File
> line 226, in handle
> File
> using=db)
> File
> line 189, in send
> File
> "/usr/local/lib/python2.7/dist-packages/guardian/management/__init__.py",
> line 32, in create_anonymous_user
> User.objects.get(pk=guardian_settings.ANONYMOUS_USER_ID)
> File
> "/usr/local/lib/python2.7/dist-packages/django/db/models/manager.py", line
> 127, in manager_method
> return getattr(self.get_queryset(), name)(*args, **kwargs)
> line 328, in get
> num = len(clone)
> line 144, in __len__
> self._fetch_all()
> line 965, in _fetch_all
> self._result_cache = list(self.iterator())
> line 238, in iterator
> results = compiler.execute_sql()
> File
> File
> 79, in execute
> File
> 64, in execute
> 98, in __exit__
> File
> 64, in execute
> django.db.utils.ProgrammingError: relation "people_profile" does not exist
> LINE 1: ...ofile"."zipcode", "people_profile"."country" FROM "people_pr...
> then manage.py migrate people:
> WARNINGS:
> provided.
> Apply all migrations: people
> Running migrations:
> Applying taggit.0001_initial... OK
> Applying taggit.0002_auto_20150616_2121... OK
> Applying people.0001_initial... OK
> Applying people.0002_auto_20160623_0404... OK
> File
> utility.execute()
> File
> File
> File
> File
> line 226, in handle
> File
> using=db)
> File
> line 189, in send
> File
> line 39, in create_anonymous_user
> user.save()
> File "/usr/local/lib/python2.7/dist-packages/django/db/models/base.py",
> line 734, in save
> force_update=force_update, update_fields=update_fields)
> line 771, in save_base
> update_fields=update_fields, raw=raw, using=using)
> File
> line 189, in send
> File "/usr/local/lib/python2.7/dist-packages/account/models.py", line
> 106, in user_post_save
> Account.create(user=user)
> 63, in create
> account.save()
> line 734, in save
> line 762, in save_base
> updated = self._save_table(raw, cls, force_insert, force_update,
> using, update_fields)
> line 846, in _save_table
> result = self._do_insert(cls._base_manager, using, fields, update_pk,
> raw)
> line 885, in _do_insert
> using=using, raw=raw)
> File
> line 920, in _insert
> return query.get_compiler(using=using).execute_sql(return_id)
> File
> line 974, in execute_sql
> File
> 79, in execute
> File
> 64, in execute
> 98, in __exit__
> File
> 64, in execute
> django.db.utils.ProgrammingError: relation "account_account" does not exist
> LINE 1: INSERT INTO "account_account" ("user_id", "timezone", "langu...
> then manage.py migrate:
> WARNINGS:
> provided.
> Synchronize unmigrated apps: tasks, dialogos, modeltranslation,
> django_extensions, djcelery, polymorphic, agon_ratings, gis,
> pinax_theme_bootstrap_account, django_forms_bootstrap, catalogue, humanize,
> geoserver, announcements, storages, user_messages, mptt, friendlytagloader,
> staticfiles, geoexplorer, sitemaps, proxy, account, pinax_theme_bootstrap,
> pagination, autocomplete_light, messages, leaflet, api, avatar, social,
> security
> Apply all migrations: layers, documents, actstream, people, admin,
> guardian, sessions, sites, auth, tastypie, maps, contenttypes, base,
> upload, groups, services, taggit
> Synchronizing apps without migrations:
> Creating tables...
> Creating table celery_taskmeta
> Creating table celery_tasksetmeta
> Creating table djcelery_intervalschedule
> Creating table djcelery_crontabschedule
> Creating table djcelery_periodictasks
> Creating table djcelery_workerstate
> Creating table djcelery_taskstate
> Creating table account_account
> Creating table account_signupcode
> Creating table account_signupcodeextended
> Creating table account_signupcoderesult
> Creating table account_emailaddress
> Creating table account_emailconfirmation
> Creating table account_accountdeletion
> Creating table avatar_avatar
> Creating table dialogos_comment
> Creating table agon_ratings_overallrating
> Creating table agon_ratings_rating
> Creating table announcements_announcement
> Creating table announcements_dismissal
> Creating table user_messages_thread
> Creating table user_messages_userthread
> Creating table user_messages_message
> Running deferred SQL...
> Installing custom SQL...
> Running migrations:
> Applying actstream.0001_initial... OK
> Applying admin.0001_initial... OK
> Applying base.0001_initial... OK
> Applying base.0002_topiccategory_fa_class... OK
> Applying base.0003_auto_20160623_0404... OK
> Applying documents.0001_initial... OK
> Applying groups.0001_initial... OK
> Applying guardian.0001_initial... OK
> Applying layers.0001_initial... OK
> Applying services.0001_initial... OK
> Applying layers.0002_initial_step2... OK
> Applying layers.0003_auto_20160623_0404... OK
> Applying maps.0001_initial... OK
> Applying services.0002_auto_20160623_0404... OK
> Applying sessions.0001_initial... OK
> Applying tastypie.0001_initial... OK
> Applying upload.0001_initial... OK
> Is that ok? How/can I restore the dump file of my previous DBs?
> Thanks
> Eugenio
> From: simone.dalmasso at gmail.com
> Date: Thu, 23 Jun 2016 10:55:47 +0200
> Subject: Re: [GeoNode-users] database update error
> To: frippe12573 at hotmail.com
> CC: geonode-users at lists.osgeo.org
> Hi Eugenio,
> beware that the data model and django version is changed in master. This
> issue happens when using postgres as db and not sqllite. At the moment the
> way to create the new db is by doing
> manage.py migrate
> We will fix this in the future.
> 2016-06-23 10:27 GMT+02:00 Eugenio Trumpy <frippe12573 at hotmail.com>:
> Hi all,
> today I was trying to update geonode from git (custom installation on
> ubuntu 14.04).
> I made a backup of the data from geonode and geonode_data db, then I
> created new DBs,
> and I run syncdb --noinput, but something seems not working:
> WARNINGS:
> provided.
> django_extensions, polymorphic, agon_ratings, gis,
> security
> guardian, sessions, djcelery, sites, auth, tastypie, maps, contenttypes,
> base, upload, groups, services, taggit
> Creating tables...
> File
> utility.execute()
> File
> File
> File
> File
> "/usr/local/lib/python2.7/dist-packages/django/core/management/commands/syncdb.py",
> line 25, in handle
> call_command("migrate", **options)
> File
> line 120, in call_command
> return command.execute(*args, **defaults)
> File
> File
> line 179, in handle
> created_models = self.sync_apps(connection,
> executor.loader.unmigrated_apps)
> File
> line 318, in sync_apps
> cursor.execute(statement)
> File
> 79, in execute
> File
> 64, in execute
> 98, in __exit__
> File
> 62, in execute
> return self.cursor.execute(sql)
> Of course I performed the update of the dbs after run git pull on geonode
> dir.
> Can you help me?
> Eugenio
> geonode-users mailing list
> http://lists.osgeo.org/mailman/listinfo/geonode-users
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160627/e0c03561/attachment-0001.html>
More information about the geonode-users
