[GeoNode-users] database update error
    Simone Dalmasso
    simone.dalmasso at gmail.com
    Mon Jun 27 08:56:06 PDT 2016
It's likely to be the django version. Django on 2.4 has to be 1.6.11
2016-06-27 16:40 GMT+02:00 Eugenio Trumpy <frippe12573 at hotmail.com>:
> Hi Simone,
> I forgot I had both the dbs backups and /geonode (the once I had before
> the git pull) saved.
> So I restore the old /geonode (I removed all the new geonode dir obtained
> with the git pull) and restored the DBs dumps.
> Everything seems to be working, I see the right number of the layers and
> maps, groups, people...
> However, clicking on layer I have an empty page (no layers available).
> So I run python manage.py updatelayers, but I get:
> Traceback (most recent call last):
>   File "manage.py", line 29, in <module>
>     execute_from_command_line(sys.argv)
>   File
> "/usr/local/lib/python2.7/dist-packages/django/core/management/__init__.py",
> line 399, in execute_from_command_line
>     utility.execute()
>   File
> line 392, in execute
>     self.fetch_command(subcommand).run_from_argv(self.argv)
>   File
> line 272, in fetch_command
>     klass = load_command_class(app_name, subcommand)
>   File
> line 75, in load_command_class
>     module = import_module('%s.management.commands.%s' % (app_name, name))
>   File "/usr/local/lib/python2.7/dist-packages/django/utils/importlib.py",
> line 40, in import_module
>     __import__(name)
>   File
> "/dati/geonode/geonode/geoserver/management/commands/updatelayers.py", line
> 24, in <module>
>     from geonode.geoserver.helpers import gs_slurp
>   File "/dati/geonode/geonode/geoserver/helpers.py", line 70, in <module>
>     from geonode.layers.utils import layer_type, get_files
>   File "/dati/geonode/geonode/layers/utils.py", line 46, in <module>
>     from geonode.layers.models import Layer, UploadSession
>   File "/dati/geonode/geonode/layers/models.py", line 35, in <module>
>     from geonode.base.models import ResourceBase, ResourceBaseManager,
> resourcebase_post_save
>   File "/dati/geonode/geonode/base/models.py", line 41, in <module>
>     from mptt.models import MPTTModel, TreeForeignKey
>   File "/usr/local/lib/python2.7/dist-packages/mptt/models.py", line 15,
> in <module>
>     from mptt.managers import TreeManager
>   File "/usr/local/lib/python2.7/dist-packages/mptt/managers.py", line 63,
> in <module>
>     class TreeManager(models.Manager.from_queryset(TreeQuerySet)):
> AttributeError: type object 'Manager' has no attribute 'from_queryset'
> Any ideas?
> E.
> *Da:* Simone Dalmasso <simone.dalmasso at gmail.com>
> *Inviato:* lunedì 27 giugno 2016 14.39
> *A:* Eugenio Trumpy
> *Cc:* geonode-users at lists.osgeo.org
> *Oggetto:* Re: [GeoNode-users] database update error
> you can use the git branch 2.4.x. git checkout is the command.
> 2016-06-27 14:25 GMT+02:00 Eugenio Trumpy <frippe12573 at hotmail.com>:
>> Hi Simone,
>> thank you for your answer so far.
>> So my solution is to put the head of my git repo to the once that was
>> working up to the last week, isn't it?
>> How can I re-set the git head to such version? I don't remember the code
>> version.
>> Thanks
>> E.
>> *Inviato:* lunedì 27 giugno 2016 13.16
>> *A:* Eugenio Trumpy
>> Eugenio, sorry for the delay.
>> I did not have time to test it on postgres so my suggestion at the moment
>> is to stick with the 2.4 stable release.
>> 2016-06-23 11:22 GMT+02:00 Eugenio Trumpy <frippe12573 at hotmail.com>:
>>> Hi Simone,
>>> django is at 1.8.7 version, is that correct for the master? how can I
>>> check the version of the data model?
>>> However, from empty geonode db I run manage.py migrate auth:
>>>  System check identified some issues:
>>> WARNINGS:
>>> account.EmailConfirmation.created: (fields.W161) Fixed default value
>>> provided.
>>>     HINT: It seems you set a fixed date / time / datetime value as
>>> default for this field. This may not be what you want. If you want to have
>>> the current date as default, use `django.utils.timezone.now`
>>> dialogos.Comment.ip_address: (fields.W900) IPAddressField has been
>>> deprecated. Support for it (except in historical migrations) will be
>>> removed in Django 1.9.
>>>     HINT: Use GenericIPAddressField instead.
>>> Operations to perform:
>>>   Apply all migrations: auth
>>> Running migrations:
>>>   Rendering model states... DONE
>>>   Applying contenttypes.0001_initial... OK
>>>   Applying contenttypes.0002_remove_content_type_name... OK
>>>   Applying auth.0001_initial... OK
>>>   Applying auth.0002_alter_permission_name_max_length... OK
>>>   Applying auth.0003_alter_user_email_max_length... OK
>>>   Applying auth.0004_alter_user_username_opts... OK
>>>   Applying auth.0005_alter_user_last_login_null... OK
>>>   Applying auth.0006_require_contenttypes_0002... OK
>>>   File
>>> line 354, in execute_from_command_line
>>>     utility.execute()
>>>   File
>>> line 346, in execute
>>>   File
>>> "/usr/local/lib/python2.7/dist-packages/django/core/management/base.py",
>>> line 394, in run_from_argv
>>>     self.execute(*args, **cmd_options)
>>>   File
>>> line 445, in execute
>>>     output = self.handle(*args, **options)
>>>   File
>>> "/usr/local/lib/python2.7/dist-packages/django/core/management/commands/migrate.py",
>>> line 226, in handle
>>>     emit_post_migrate_signal(created_models, self.verbosity,
>>> self.interactive, connection.alias)
>>>   File
>>> "/usr/local/lib/python2.7/dist-packages/django/core/management/sql.py",
>>> line 280, in emit_post_migrate_signal
>>>     using=db)
>>>   File
>>> "/usr/local/lib/python2.7/dist-packages/django/dispatch/dispatcher.py",
>>> line 189, in send
>>>     response = receiver(signal=self, sender=sender, **named)
>>>   File
>>> "/usr/local/lib/python2.7/dist-packages/django/contrib/sites/management.py",
>>> line 20, in create_default_site
>>>     if not Site.objects.using(using).exists():
>>>   File
>>> "/usr/local/lib/python2.7/dist-packages/django/db/models/query.py", line
>>> 586, in exists
>>>     return self.query.has_results(using=self.db)
>>>   File
>>> "/usr/local/lib/python2.7/dist-packages/django/db/models/sql/query.py",
>>> line 484, in has_results
>>>     return compiler.has_results()
>>>   File
>>> "/usr/local/lib/python2.7/dist-packages/django/db/models/sql/compiler.py",
>>> line 811, in has_results
>>>     return bool(self.execute_sql(SINGLE))
>>>   File
>>> line 840, in execute_sql
>>>     cursor.execute(sql, params)
>>>   File
>>> "/usr/local/lib/python2.7/dist-packages/django/db/backends/utils.py", line
>>> 79, in execute
>>>     return super(CursorDebugWrapper, self).execute(sql, params)
>>>   File
>>> 64, in execute
>>>     return self.cursor.execute(sql, params)
>>>   File "/usr/local/lib/python2.7/dist-packages/django/db/utils.py", line
>>> 98, in __exit__
>>>     six.reraise(dj_exc_type, dj_exc_value, traceback)
>>>   File
>>> 64, in execute
>>> django.db.utils.ProgrammingError: relation "django_site" does not exist
>>> LINE 1: SELECT (1) AS "a" FROM "django_site" LIMIT 1
>>> then I run manage.py migrate sites:
>>> WARNINGS:
>>> provided.
>>>   Apply all migrations: sites
>>> Running migrations:
>>>   Applying sites.0001_initial... OK
>>>   File
>>>     utility.execute()
>>>   File
>>>   File
>>>   File
>>>   File
>>> line 226, in handle
>>>   File
>>>     using=db)
>>>   File
>>> line 189, in send
>>>   File
>>> "/usr/local/lib/python2.7/dist-packages/guardian/management/__init__.py",
>>> line 32, in create_anonymous_user
>>>     User.objects.get(pk=guardian_settings.ANONYMOUS_USER_ID)
>>>   File
>>> "/usr/local/lib/python2.7/dist-packages/django/db/models/manager.py", line
>>> 127, in manager_method
>>>     return getattr(self.get_queryset(), name)(*args, **kwargs)
>>>   File
>>> 328, in get
>>>     num = len(clone)
>>>   File
>>> 144, in __len__
>>>     self._fetch_all()
>>>   File
>>> 965, in _fetch_all
>>>     self._result_cache = list(self.iterator())
>>>   File
>>> 238, in iterator
>>>     results = compiler.execute_sql()
>>>   File
>>>   File
>>> 79, in execute
>>>   File
>>> 64, in execute
>>> 98, in __exit__
>>>   File
>>> 64, in execute
>>> django.db.utils.ProgrammingError: relation "people_profile" does not
>>> exist
>>> LINE 1: ...ofile"."zipcode", "people_profile"."country" FROM
>>> "people_pr...
>>> then manage.py migrate people:
>>> WARNINGS:
>>> provided.
>>>   Apply all migrations: people
>>> Running migrations:
>>>   Applying taggit.0001_initial... OK
>>>   Applying taggit.0002_auto_20150616_2121... OK
>>>   Applying people.0001_initial... OK
>>>   Applying people.0002_auto_20160623_0404... OK
>>>   File
>>>     utility.execute()
>>>   File
>>>   File
>>>   File
>>>   File
>>> line 226, in handle
>>>   File
>>>     using=db)
>>>   File
>>> line 189, in send
>>>   File
>>> line 39, in create_anonymous_user
>>>     user.save()
>>>   File
>>> "/usr/local/lib/python2.7/dist-packages/django/db/models/base.py", line
>>> 734, in save
>>>     force_update=force_update, update_fields=update_fields)
>>>   File
>>> 771, in save_base
>>>     update_fields=update_fields, raw=raw, using=using)
>>>   File
>>> line 189, in send
>>>   File "/usr/local/lib/python2.7/dist-packages/account/models.py", line
>>> 106, in user_post_save
>>>     Account.create(user=user)
>>> 63, in create
>>>     account.save()
>>>   File
>>> 734, in save
>>>   File
>>> 762, in save_base
>>>     updated = self._save_table(raw, cls, force_insert, force_update,
>>> using, update_fields)
>>>   File
>>> 846, in _save_table
>>>     result = self._do_insert(cls._base_manager, using, fields,
>>> update_pk, raw)
>>>   File
>>> 885, in _do_insert
>>>     using=using, raw=raw)
>>>   File
>>>   File
>>> 920, in _insert
>>>     return query.get_compiler(using=using).execute_sql(return_id)
>>>   File
>>> line 974, in execute_sql
>>>   File
>>> 79, in execute
>>>   File
>>> 64, in execute
>>> 98, in __exit__
>>>   File
>>> 64, in execute
>>> django.db.utils.ProgrammingError: relation "account_account" does not
>>> exist
>>> LINE 1: INSERT INTO "account_account" ("user_id", "timezone", "langu...
>>> then manage.py migrate:
>>> WARNINGS:
>>> provided.
>>>   Synchronize unmigrated apps: tasks, dialogos, modeltranslation,
>>> django_extensions, djcelery, polymorphic, agon_ratings, gis,
>>> pinax_theme_bootstrap_account, django_forms_bootstrap, catalogue, humanize,
>>> geoserver, announcements, storages, user_messages, mptt, friendlytagloader,
>>> staticfiles, geoexplorer, sitemaps, proxy, account, pinax_theme_bootstrap,
>>> pagination, autocomplete_light, messages, leaflet, api, avatar, social,
>>> security
>>>   Apply all migrations: layers, documents, actstream, people, admin,
>>> guardian, sessions, sites, auth, tastypie, maps, contenttypes, base,
>>> upload, groups, services, taggit
>>> Synchronizing apps without migrations:
>>>   Creating tables...
>>>     Creating table celery_taskmeta
>>>     Creating table celery_tasksetmeta
>>>     Creating table djcelery_intervalschedule
>>>     Creating table djcelery_crontabschedule
>>>     Creating table djcelery_periodictasks
>>>     Creating table djcelery_workerstate
>>>     Creating table djcelery_taskstate
>>>     Creating table account_account
>>>     Creating table account_signupcode
>>>     Creating table account_signupcodeextended
>>>     Creating table account_signupcoderesult
>>>     Creating table account_emailaddress
>>>     Creating table account_emailconfirmation
>>>     Creating table account_accountdeletion
>>>     Creating table avatar_avatar
>>>     Creating table dialogos_comment
>>>     Creating table agon_ratings_overallrating
>>>     Creating table agon_ratings_rating
>>>     Creating table announcements_announcement
>>>     Creating table announcements_dismissal
>>>     Creating table user_messages_thread
>>>     Creating table user_messages_userthread
>>>     Creating table user_messages_message
>>>     Running deferred SQL...
>>>   Installing custom SQL...
>>> Running migrations:
>>>   Applying actstream.0001_initial... OK
>>>   Applying admin.0001_initial... OK
>>>   Applying base.0001_initial... OK
>>>   Applying base.0002_topiccategory_fa_class... OK
>>>   Applying base.0003_auto_20160623_0404... OK
>>>   Applying documents.0001_initial... OK
>>>   Applying groups.0001_initial... OK
>>>   Applying guardian.0001_initial... OK
>>>   Applying layers.0001_initial... OK
>>>   Applying services.0001_initial... OK
>>>   Applying layers.0002_initial_step2... OK
>>>   Applying layers.0003_auto_20160623_0404... OK
>>>   Applying maps.0001_initial... OK
>>>   Applying services.0002_auto_20160623_0404... OK
>>>   Applying sessions.0001_initial... OK
>>>   Applying tastypie.0001_initial... OK
>>>   Applying upload.0001_initial... OK
>>> Is that ok? How/can I restore the dump file of my previous DBs?
>>> Thanks
>>> Eugenio
>>> From: simone.dalmasso at gmail.com
>>> Date: Thu, 23 Jun 2016 10:55:47 +0200
>>> Subject: Re: [GeoNode-users] database update error
>>> To: frippe12573 at hotmail.com
>>> CC: geonode-users at lists.osgeo.org
>>> Hi Eugenio,
>>> beware that the data model and django version is changed in master. This
>>> issue happens when using postgres as db and not sqllite. At the moment the
>>> way to create the new db is by doing
>>> manage.py migrate
>>> We will fix this in the future.
>>> 2016-06-23 10:27 GMT+02:00 Eugenio Trumpy <frippe12573 at hotmail.com>:
>>> Hi all,
>>> today I was trying to update geonode from git (custom installation on
>>> ubuntu 14.04).
>>> I made a backup of the data from geonode and geonode_data db, then I
>>> created new DBs,
>>> and I run syncdb --noinput, but something seems not working:
>>> WARNINGS:
>>> provided.
>>> django_extensions, polymorphic, agon_ratings, gis,
>>> security
>>> guardian, sessions, djcelery, sites, auth, tastypie, maps, contenttypes,
>>> base, upload, groups, services, taggit
>>>   Creating tables...
>>>   File
>>>     utility.execute()
>>>   File
>>>   File
>>>   File
>>>   File
>>> "/usr/local/lib/python2.7/dist-packages/django/core/management/commands/syncdb.py",
>>> line 25, in handle
>>>     call_command("migrate", **options)
>>>   File
>>> line 120, in call_command
>>>     return command.execute(*args, **defaults)
>>>   File
>>>   File
>>> line 179, in handle
>>>     created_models = self.sync_apps(connection,
>>> executor.loader.unmigrated_apps)
>>>   File
>>> line 318, in sync_apps
>>>     cursor.execute(statement)
>>>   File
>>> 79, in execute
>>>   File
>>> 64, in execute
>>> 98, in __exit__
>>>   File
>>> 62, in execute
>>>     return self.cursor.execute(sql)
>>> exist
>>> Of course I performed the update of the dbs after run git pull on
>>> geonode dir.
>>> Can you help me?
>>> Eugenio
>>> geonode-users mailing list
>>> http://lists.osgeo.org/mailman/listinfo/geonode-users
>> Simone
> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160627/be07b007/attachment-0001.html>
More information about the geonode-users
