[GeoNode-users] geonode updatelayers exception "non-XML response"
Israel López
asralf at gmail.com
Mon Jun 27 12:16:38 PDT 2016
Is there a solution for this problem??? I have a similar error with
uploading a layer...
2015-11-10 10:16 GMT-06:00 Christian Willmes <c.willmes at uni-koeln.de>:
> Hi,
> I get the attached two error stack traces in catalina.out, regarding
> remote services.
> I tried to add this service:
> http://geonode.crc806db.uni-koeln.de:8081/GEBCO/service?REQUEST=GetCapabilities
> The Metadata is read in correctly, on accessing the layer from the GeoNode
> frontend, I get error1.log.
> On accessing the layer remotely from a third party application, I get the
> error2.log stack trace.
> It seems the metadata is read in correctly, but the layer is not created...
> Regards,
> Christian
> Am 10.11.2015 um 09:41 schrieb Christian Willmes:
>> The "catalina.out" provides some useful information. I did not looked
>> there yet, will take some time for it this afternoon, and report back if
>> there is still a problem, and what its about. If I still can't fix it, I
>> will try to join during the sprint online next week.
>> Thanks,
>> Christian
>> Am 09.11.2015 um 15:48 schrieb Jeffrey Johnson:
>>> Christian,
>>> Can you join us online next week during the sprint to look into this
>>> issue? Also, its probably helpful if you paste the stacktrace from
>>> tomcat.
>>> Jeff
>>> On Sun, Nov 8, 2015 at 11:49 PM, Christian Willmes
>>> <christian.willmes at googlemail.com> wrote:
>>>> Hi,
>>>> any advice on this? How can I fix it and preserve my data, and most
>>>> important the URLs?
>>>> I considered reinstalling Geonode, by preserving the GeoServer, but I
>>>> figured, that this may break the URLs, which would be bad, because other
>>>> applications link to the Geonode resources.
>>>> Regards,
>>>> Christian
>>>> Am 05.11.2015 um 16:58 schrieb Christian Willmes:
>>>>> Hi,
>>>>> I can't run the "geonode updatelayers" command anymore, because it
>>>>> always
>>>>> aborts with an error like:
>>>>> Exception: ('GeoServer gave non-XML response for [GET
>>>>>>> http://localhost:8080/geoserver/rest/workspaces/geonode/datastores/datastore/featuretypes/lgm_landmask_hires.xml]:
>>>>>>> <featureType>\n <name>lgm_landmask_hires</name>\n
>>>>>>> <nativeName>lgm_landmask_hires</nativeName>\n <namespace>\n
>>>>>>> <name>geonode</name>\n [...]
>>>>>> I cant fix the schema in geoserver by reloading the feature type in
>>>>> the
>>>>> Layer edit view, but it does not work. It throws really long java stack
>>>>> trace in the "publication" tab, one line says:
>>>>> Caused by: java.io.IOException: Schema 'lgm_landmask_hires' does not
>>>>>>> exist.
>>>>>> I also completely deleted another layer, that throwed this same error
>>>>> before. But its not really an option to delete all layers to be able
>>>>> to run
>>>>> the command again.
>>>>> I also tried with the --ignore-errors option, but got the same error /
>>>>> abort.
>>>>> How can I fix or circumvent this problem?
>>>>> Thanks and regards,
>>>>> Christian
>>>>> _______________________________________________
>>>> geonode-users mailing list
>>>> geonode-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/geonode-users
> Christian Willmes
> AG GIS & Fernerkundung | GIS & RS Group
> Geographisches Institut | Institute of Geography
> Universität zu Köln | University of Cologne
> Tel.: +49 (0)221 470 6234
> http://www.geographie.uni-koeln.de/willmes-christian.695.en.html
> http://www.sfb806.de
> http://crc806db.uni-koeln.de
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160627/15ff0a9e/attachment.html>
More information about the geonode-users
