[GeoNode-users] database update error
Simone Dalmasso simone.dalmasso at gmail.com
Tue Jun 28 00:52:13 PDT 2016
hm, nope.
try a pip install -e geonode maybe you miss something
2016-06-28 9:42 GMT+02:00 Eugenio Trumpy <frippe12573 at hotmail.com>:
> Hi Simone,
> Django seems to be already at 1.6.11 version
> Any other hints?
> E.
> *Da:* Simone Dalmasso <simone.dalmasso at gmail.com>
> *Inviato:* lunedì 27 giugno 2016 17.56
> *A:* Eugenio Trumpy
> *Cc:* geonode-users at lists.osgeo.org
> *Oggetto:* Re: [GeoNode-users] database update error
> It's likely to be the django version. Django on 2.4 has to be 1.6.11
> 2016-06-27 16:40 GMT+02:00 Eugenio Trumpy <frippe12573 at hotmail.com>:
>> Hi Simone,
>> I forgot I had both the dbs backups and /geonode (the once I had before
>> the git pull) saved.
>> So I restore the old /geonode (I removed all the new geonode dir obtained
>> with the git pull) and restored the DBs dumps.
>> Everything seems to be working, I see the right number of the layers and
>> maps, groups, people...
>> However, clicking on layer I have an empty page (no layers available).
>> So I run python manage.py updatelayers, but I get:
>> Traceback (most recent call last):
>>   File "manage.py", line 29, in <module>
>>     execute_from_command_line(sys.argv)
>>   File
>> "/usr/local/lib/python2.7/dist-packages/django/core/management/__init__.py",
>> line 399, in execute_from_command_line
>>     utility.execute()
>>   File
>> line 392, in execute
>>     self.fetch_command(subcommand).run_from_argv(self.argv)
>>   File
>> line 272, in fetch_command
>>     klass = load_command_class(app_name, subcommand)
>>   File
>> line 75, in load_command_class
>>     module = import_module('%s.management.commands.%s' % (app_name, name))
>>   File
>> "/usr/local/lib/python2.7/dist-packages/django/utils/importlib.py", line
>> 40, in import_module
>>     __import__(name)
>>   File
>> "/dati/geonode/geonode/geoserver/management/commands/updatelayers.py", line
>> 24, in <module>
>>     from geonode.geoserver.helpers import gs_slurp
>>   File "/dati/geonode/geonode/geoserver/helpers.py", line 70, in <module>
>>     from geonode.layers.utils import layer_type, get_files
>>   File "/dati/geonode/geonode/layers/utils.py", line 46, in <module>
>>     from geonode.layers.models import Layer, UploadSession
>>   File "/dati/geonode/geonode/layers/models.py", line 35, in <module>
>>     from geonode.base.models import ResourceBase, ResourceBaseManager,
>> resourcebase_post_save
>>   File "/dati/geonode/geonode/base/models.py", line 41, in <module>
>>     from mptt.models import MPTTModel, TreeForeignKey
>>   File "/usr/local/lib/python2.7/dist-packages/mptt/models.py", line 15,
>> in <module>
>>     from mptt.managers import TreeManager
>>   File "/usr/local/lib/python2.7/dist-packages/mptt/managers.py", line
>> 63, in <module>
>>     class TreeManager(models.Manager.from_queryset(TreeQuerySet)):
>> AttributeError: type object 'Manager' has no attribute 'from_queryset'
>> Any ideas?
>> E.
>> *Inviato:* lunedì 27 giugno 2016 14.39
>> *A:* Eugenio Trumpy
>> you can use the git branch 2.4.x. git checkout is the command.
>> 2016-06-27 14:25 GMT+02:00 Eugenio Trumpy <frippe12573 at hotmail.com>:
>>> Hi Simone,
>>> thank you for your answer so far.
>>> So my solution is to put the head of my git repo to the once that was
>>> working up to the last week, isn't it?
>>> How can I re-set the git head to such version? I don't remember the code
>>> version.
>>> Thanks
>>> E.
>>> *Inviato:* lunedì 27 giugno 2016 13.16
>>> *A:* Eugenio Trumpy
>>> Eugenio, sorry for the delay.
>>> I did not have time to test it on postgres so my suggestion at the
>>> moment is to stick with the 2.4 stable release.
>>> 2016-06-23 11:22 GMT+02:00 Eugenio Trumpy <frippe12573 at hotmail.com>:
>>>> Hi Simone,
>>>> django is at 1.8.7 version, is that correct for the master? how can I
>>>> check the version of the data model?
>>>> However, from empty geonode db I run manage.py migrate auth:
>>>>  System check identified some issues:
>>>> WARNINGS:
>>>> account.EmailConfirmation.created: (fields.W161) Fixed default value
>>>> provided.
>>>>     HINT: It seems you set a fixed date / time / datetime value as
>>>> default for this field. This may not be what you want. If you want to have
>>>> the current date as default, use `django.utils.timezone.now`
>>>> dialogos.Comment.ip_address: (fields.W900) IPAddressField has been
>>>> deprecated. Support for it (except in historical migrations) will be
>>>> removed in Django 1.9.
>>>>     HINT: Use GenericIPAddressField instead.
>>>> Operations to perform:
>>>>   Apply all migrations: auth
>>>> Running migrations:
>>>>   Rendering model states... DONE
>>>>   Applying contenttypes.0001_initial... OK
>>>>   Applying contenttypes.0002_remove_content_type_name... OK
>>>>   Applying auth.0001_initial... OK
>>>>   Applying auth.0002_alter_permission_name_max_length... OK
>>>>   Applying auth.0003_alter_user_email_max_length... OK
>>>>   Applying auth.0004_alter_user_username_opts... OK
>>>>   Applying auth.0005_alter_user_last_login_null... OK
>>>>   Applying auth.0006_require_contenttypes_0002... OK
>>>>   File
>>>> line 354, in execute_from_command_line
>>>>     utility.execute()
>>>>   File
>>>> line 346, in execute
>>>>   File
>>>> "/usr/local/lib/python2.7/dist-packages/django/core/management/base.py",
>>>> line 394, in run_from_argv
>>>>     self.execute(*args, **cmd_options)
>>>>   File
>>>> line 445, in execute
>>>>     output = self.handle(*args, **options)
>>>>   File
>>>> "/usr/local/lib/python2.7/dist-packages/django/core/management/commands/migrate.py",
>>>> line 226, in handle
>>>>     emit_post_migrate_signal(created_models, self.verbosity,
>>>> self.interactive, connection.alias)
>>>>   File
>>>> "/usr/local/lib/python2.7/dist-packages/django/core/management/sql.py",
>>>> line 280, in emit_post_migrate_signal
>>>>     using=db)
>>>>   File
>>>> "/usr/local/lib/python2.7/dist-packages/django/dispatch/dispatcher.py",
>>>> line 189, in send
>>>>     response = receiver(signal=self, sender=sender, **named)
>>>>   File
>>>> "/usr/local/lib/python2.7/dist-packages/django/contrib/sites/management.py",
>>>> line 20, in create_default_site
>>>>     if not Site.objects.using(using).exists():
>>>>   File
>>>> "/usr/local/lib/python2.7/dist-packages/django/db/models/query.py", line
>>>> 586, in exists
>>>>     return self.query.has_results(using=self.db)
>>>>   File
>>>> "/usr/local/lib/python2.7/dist-packages/django/db/models/sql/query.py",
>>>> line 484, in has_results
>>>>     return compiler.has_results()
>>>>   File
>>>> "/usr/local/lib/python2.7/dist-packages/django/db/models/sql/compiler.py",
>>>> line 811, in has_results
>>>>     return bool(self.execute_sql(SINGLE))
>>>>   File
>>>> line 840, in execute_sql
>>>>     cursor.execute(sql, params)
>>>>   File
>>>> "/usr/local/lib/python2.7/dist-packages/django/db/backends/utils.py", line
>>>> 79, in execute
>>>>     return super(CursorDebugWrapper, self).execute(sql, params)
>>>>   File
>>>> 64, in execute
>>>>     return self.cursor.execute(sql, params)
>>>>   File "/usr/local/lib/python2.7/dist-packages/django/db/utils.py",
>>>> line 98, in __exit__
>>>>     six.reraise(dj_exc_type, dj_exc_value, traceback)
>>>>   File
>>>> 64, in execute
>>>> django.db.utils.ProgrammingError: relation "django_site" does not exist
>>>> LINE 1: SELECT (1) AS "a" FROM "django_site" LIMIT 1
>>>> then I run manage.py migrate sites:
>>>> WARNINGS:
>>>> provided.
>>>>   Apply all migrations: sites
>>>> Running migrations:
>>>>   Applying sites.0001_initial... OK
>>>>   File
>>>>     utility.execute()
>>>>   File
>>>>   File
>>>>   File
>>>>   File
>>>> line 226, in handle
>>>>   File
>>>>     using=db)
>>>>   File
>>>> line 189, in send
>>>>   File
>>>> "/usr/local/lib/python2.7/dist-packages/guardian/management/__init__.py",
>>>> line 32, in create_anonymous_user
>>>>     User.objects.get(pk=guardian_settings.ANONYMOUS_USER_ID)
>>>>   File
>>>> "/usr/local/lib/python2.7/dist-packages/django/db/models/manager.py", line
>>>> 127, in manager_method
>>>>     return getattr(self.get_queryset(), name)(*args, **kwargs)
>>>>   File
>>>> 328, in get
>>>>     num = len(clone)
>>>>   File
>>>> 144, in __len__
>>>>     self._fetch_all()
>>>>   File
>>>> 965, in _fetch_all
>>>>     self._result_cache = list(self.iterator())
>>>>   File
>>>> 238, in iterator
>>>>     results = compiler.execute_sql()
>>>>   File
>>>>   File
>>>> 79, in execute
>>>>   File
>>>> 64, in execute
>>>>   File
>>>> 64, in execute
>>>> django.db.utils.ProgrammingError: relation "people_profile" does not
>>>> exist
>>>> LINE 1: ...ofile"."zipcode", "people_profile"."country" FROM
>>>> "people_pr...
>>>> then manage.py migrate people:
>>>> WARNINGS:
>>>> provided.
>>>>   Apply all migrations: people
>>>> Running migrations:
>>>>   Applying taggit.0001_initial... OK
>>>>   Applying taggit.0002_auto_20150616_2121... OK
>>>>   Applying people.0001_initial... OK
>>>>   Applying people.0002_auto_20160623_0404... OK
>>>>   File
>>>>     utility.execute()
>>>>   File
>>>>   File
>>>>   File
>>>>   File
>>>> line 226, in handle
>>>>   File
>>>>     using=db)
>>>>   File
>>>> line 189, in send
>>>>   File
>>>> line 39, in create_anonymous_user
>>>>     user.save()
>>>>   File
>>>> "/usr/local/lib/python2.7/dist-packages/django/db/models/base.py", line
>>>> 734, in save
>>>>     force_update=force_update, update_fields=update_fields)
>>>>   File
>>>> 771, in save_base
>>>>     update_fields=update_fields, raw=raw, using=using)
>>>>   File
>>>> line 189, in send
>>>>   File "/usr/local/lib/python2.7/dist-packages/account/models.py", line
>>>> 106, in user_post_save
>>>>     Account.create(user=user)
>>>> 63, in create
>>>>     account.save()
>>>>   File
>>>> 734, in save
>>>>   File
>>>> 762, in save_base
>>>>     updated = self._save_table(raw, cls, force_insert, force_update,
>>>> using, update_fields)
>>>>   File
>>>> 846, in _save_table
>>>>     result = self._do_insert(cls._base_manager, using, fields,
>>>> update_pk, raw)
>>>>   File
>>>> 885, in _do_insert
>>>>     using=using, raw=raw)
>>>>   File
>>>>   File
>>>> 920, in _insert
>>>>     return query.get_compiler(using=using).execute_sql(return_id)
>>>>   File
>>>> line 974, in execute_sql
>>>>   File
>>>> 79, in execute
>>>>   File
>>>> 64, in execute
>>>>   File
>>>> 64, in execute
>>>> django.db.utils.ProgrammingError: relation "account_account" does not
>>>> exist
>>>> LINE 1: INSERT INTO "account_account" ("user_id", "timezone", "langu...
>>>> then manage.py migrate:
>>>> WARNINGS:
>>>> provided.
>>>>   Synchronize unmigrated apps: tasks, dialogos, modeltranslation,
>>>> django_extensions, djcelery, polymorphic, agon_ratings, gis,
>>>> pinax_theme_bootstrap_account, django_forms_bootstrap, catalogue, humanize,
>>>> geoserver, announcements, storages, user_messages, mptt, friendlytagloader,
>>>> staticfiles, geoexplorer, sitemaps, proxy, account, pinax_theme_bootstrap,
>>>> pagination, autocomplete_light, messages, leaflet, api, avatar, social,
>>>> security
>>>>   Apply all migrations: layers, documents, actstream, people, admin,
>>>> guardian, sessions, sites, auth, tastypie, maps, contenttypes, base,
>>>> upload, groups, services, taggit
>>>> Synchronizing apps without migrations:
>>>>   Creating tables...
>>>>     Creating table celery_taskmeta
>>>>     Creating table celery_tasksetmeta
>>>>     Creating table djcelery_intervalschedule
>>>>     Creating table djcelery_crontabschedule
>>>>     Creating table djcelery_periodictasks
>>>>     Creating table djcelery_workerstate
>>>>     Creating table djcelery_taskstate
>>>>     Creating table account_account
>>>>     Creating table account_signupcode
>>>>     Creating table account_signupcodeextended
>>>>     Creating table account_signupcoderesult
>>>>     Creating table account_emailaddress
>>>>     Creating table account_emailconfirmation
>>>>     Creating table account_accountdeletion
>>>>     Creating table avatar_avatar
>>>>     Creating table dialogos_comment
>>>>     Creating table agon_ratings_overallrating
>>>>     Creating table agon_ratings_rating
>>>>     Creating table announcements_announcement
>>>>     Creating table announcements_dismissal
>>>>     Creating table user_messages_thread
>>>>     Creating table user_messages_userthread
>>>>     Creating table user_messages_message
>>>>     Running deferred SQL...
>>>>   Installing custom SQL...
>>>> Running migrations:
>>>>   Applying actstream.0001_initial... OK
>>>>   Applying admin.0001_initial... OK
>>>>   Applying base.0001_initial... OK
>>>>   Applying base.0002_topiccategory_fa_class... OK
>>>>   Applying base.0003_auto_20160623_0404... OK
>>>>   Applying documents.0001_initial... OK
>>>>   Applying groups.0001_initial... OK
>>>>   Applying guardian.0001_initial... OK
>>>>   Applying layers.0001_initial... OK
>>>>   Applying services.0001_initial... OK
>>>>   Applying layers.0002_initial_step2... OK
>>>>   Applying layers.0003_auto_20160623_0404... OK
>>>>   Applying maps.0001_initial... OK
>>>>   Applying services.0002_auto_20160623_0404... OK
>>>>   Applying sessions.0001_initial... OK
>>>>   Applying tastypie.0001_initial... OK
>>>>   Applying upload.0001_initial... OK
>>>> Is that ok? How/can I restore the dump file of my previous DBs?
>>>> Thanks
>>>> Eugenio
>>>> From: simone.dalmasso at gmail.com
>>>> Date: Thu, 23 Jun 2016 10:55:47 +0200
>>>> Subject: Re: [GeoNode-users] database update error
>>>> To: frippe12573 at hotmail.com
>>>> CC: geonode-users at lists.osgeo.org
>>>> Hi Eugenio,
>>>> beware that the data model and django version is changed in master.
>>>> This issue happens when using postgres as db and not sqllite. At the moment
>>>> the way to create the new db is by doing
>>>> manage.py migrate
>>>> We will fix this in the future.
>>>> 2016-06-23 10:27 GMT+02:00 Eugenio Trumpy <frippe12573 at hotmail.com>:
>>>> Hi all,
>>>> today I was trying to update geonode from git (custom installation on
>>>> ubuntu 14.04).
>>>> I made a backup of the data from geonode and geonode_data db, then I
>>>> created new DBs,
>>>> and I run syncdb --noinput, but something seems not working:
>>>> WARNINGS:
>>>> provided.
>>>> django_extensions, polymorphic, agon_ratings, gis,
>>>> security
>>>> guardian, sessions, djcelery, sites, auth, tastypie, maps, contenttypes,
>>>> base, upload, groups, services, taggit
>>>>   Creating tables...
>>>>   File
>>>>     utility.execute()
>>>>   File
>>>>   File
>>>>   File
>>>>   File
>>>> "/usr/local/lib/python2.7/dist-packages/django/core/management/commands/syncdb.py",
>>>> line 25, in handle
>>>>     call_command("migrate", **options)
>>>>   File
>>>> line 120, in call_command
>>>>     return command.execute(*args, **defaults)
>>>>   File
>>>>   File
>>>> line 179, in handle
>>>>     created_models = self.sync_apps(connection,
>>>> executor.loader.unmigrated_apps)
>>>>   File
>>>> line 318, in sync_apps
>>>>     cursor.execute(statement)
>>>>   File
>>>> 79, in execute
>>>>   File
>>>> 64, in execute
>>>>   File
>>>> 62, in execute
>>>>     return self.cursor.execute(sql)
>>>> exist
>>>> Of course I performed the update of the dbs after run git pull on
>>>> geonode dir.
>>>> Can you help me?
>>>> Eugenio
>>>> _______________________________________________
>>>> geonode-users mailing list
>>>> http://lists.osgeo.org/mailman/listinfo/geonode-users
>>> Simone
>> Simone
> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160628/b788e9bc/attachment-0001.html>
More information about the geonode-users mailing list
