[GeoNode-users] Error saving style back to server
Daniel Victoria daniel.victoria at gmail.com
Tue Jun 28 09:33:57 PDT 2016
Hi Francesco,
Thanks for the help. Just to clarify, what should I place in
/usr/share/geoserver/data/security/auth/geonodeAuthProvider/config.xml?
<BaseUrl> was set to http://localhost/. I changed to my site URL, restarted
tomcat7 & apache, but it did not change anything.
Cheers
Daniel
On Tue, Jun 28, 2016 at 1:00 PM, Francesco Bartoli <xbartolone at gmail.com>
wrote:
> Hi Daniel,
> the SSL configuration is due just on the geonode virtual host of Apache
> web server where GeoServer is proxy passed. So nothing special than a
> standard SSL apache configuration. Actually GeoServer with the release 2.4
> is deployed under Tomcat 7 so you should have a look there.
> For instance to configure the geonode base url you can edit this file in
> ubuntu:
> Francesco
> Il giorno 28/giu/2016, alle ore 17:20, Daniel Victoria <
> daniel.victoria at gmail.com> ha scritto:
> So, we've not been able to sort out this problem with a certificate that
> is not matching our site. And since the guys that keep the network running
> here do not know much about geonode/geoserver, we are a bit lost. Are there
> any special configurations needed in order for GeoNode to play nice with
> SSL certificates?
> We found this doc online
> http://docs.geonode.org/en/master/tutorials/advanced/geonode_production/ssl.html
> But it mentions Tomcat6 and some directories that are not present in my
> GeoNode install, like /var/lib/tomcat6/webapps/geoserver/WEB-INF/web.xml
> I'm running geonode 2.4 in Ubuntu 14.04, installed using the apt-get
> command.
> My site uses a SSL certificate from Let's Encrypt
> Thanks
> Daniel
> On Wed, Jun 22, 2016 at 8:54 AM, Daniel Victoria <
> daniel.victoria at gmail.com> wrote:
>> Just an update. I checked the same thing on an internal test server that
>> I have (that I believe does not uses https) and I don't get the server
>> error. So it's probably the hostname mismatch thing that is preventing me
>> to change the layer style. Will talk to the network guys and hope they know
>> how to fix it.
>> cheers
>> Daniel
>> On Wed, Jun 22, 2016 at 8:34 AM, Daniel Victoria <
>>> Hi Simone,
>>> Thanks for the tip. Looking at the apache2.log it appears that it's some
>>> problem with a cerificateHostnameMismatch. Am I reading the log correct?
>>> I'll talk to the people that maintains out network and see about this
>>> certificate.
>>> On the same topic, in local_setting.py what should I put in SITEURL. The
>>> actual name of my virtual machine (some funny thing like dmzv014)? Or the
>>> name it's known in the internet (https://www.some.pretty.name.here)
>>> Thanks
>>> Daniel
>>> On Wed, Jun 22, 2016 at 6:41 AM, Simone Dalmasso <
>>> simone.dalmasso at gmail.com> wrote:
>>>> Hi, take a look at the apache logs when the 500 error code appears,
>>>> they should tell you more.
>>>> 2016-06-21 20:12 GMT+02:00 Daniel Victoria <daniel.victoria at gmail.com>:
>>>>> Hi list,
>>>>> I have a GeoNode instance running on Ubuntu, installed via
>>>>> apt-get.Everything appears to be working fine however, when I try to change
>>>>> a layer style, I get the error: "There was an error saving the style
>>>>> back to the server."
>>>>> Looking at the development console, I see that when I try to alter the
>>>>> layer style there are 2 PUT calls to the server. The first one fails with
>>>>> error 500 Internal server error. This is the call that's sending the SLD to
>>>>> the server. The second one returns 200 OK and it's sending the a JSON
>>>>> {"layer":{"defaultStyle":{"name":"estados"},"styles":{},"enabled":true}}
>>>>> I'm trying to debug this error but can't find what is going on. I'm
>>>>> running behind a proxy server. Could this be a security setting? Is it
>>>>> normal that one PUT call fails and the other works?
>>>>> Thanks
>>>>> Daniel
>>>>> _______________________________________________
>>>>> geonode-users mailing list
>>>>> geonode-users at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/geonode-users
>>>> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160628/fe824ce4/attachment-0001.html>
More information about the geonode-users mailing list
