[GeoNode-users] Fwd: Error saving style back to server
Daniel Victoria daniel.victoria at gmail.com
Wed Jun 29 07:18:16 PDT 2016
Forwarding to the list to keep the discussion among all
---------- Forwarded message ----------
Date: Wed, Jun 29, 2016 at 7:33 AM
Subject: Re: [GeoNode-users] Error saving style back to server
To: Daniel Victoria <daniel.victoria at gmail.com>
Hi everybody,
me too I've experienced the same error with styles setted in Geoserver
after I ran genode updatalyers as root and not www-data user. That
time i think the error was 403. Couple of 500 error based on wrong
SITEURL or hostname anywhere, last time found it in local_settings.pyc
inside /usr/local/lib/python2.7/dist-packages/geonode dir..
If anyone needs to know, in a test envirnoment I've also temporary
disabled certificate validation in
/usr/lib/python2.7/dist-packages/geoserver/catalog.py (74)
2016-06-28 21:05 GMT+02:00 Daniel Victoria <daniel.victoria at gmail.com>:
> Thanks Francesco!
> I ran the command here and I'm also seeing a different subject. I don't
> understand much about SSL and certificates, but I'll forward this to the
> people that maintains the network here.
I 've just finished to setup my installation (ubuntu server via
apt-get) for working with ssl...
Based on  the guide:
http://docs.geonode.org/en/master/tutorials/advanced/geonode_production/ssl.html
I've found the differences below:
Tomcat configuration
found file in
/etc/tomcat7/server.xml
instead of
/var/lib/tomcat6/conf/server.xml
GeoServer Configuration
found in
/usr/share/geoserver/WEB-INF/web.xml
instead of
/var/lib/tomcat6/webapps/geoserver/WEB-INF/web.xml
also the file
/var/lib/geoserver/geonode-data/global.xml
doesn't exist and seems not necessary
Also my server works without complete the step
"Next add the certificate to the cacerts file for python and java:"
Am I right?
Should I update the guide and make a merge request?
('d like to change also that static ip 192.168.10.10 mentioned in the
snippets)
amefad
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160629/e4b2f350/attachment-0001.html>
More information about the geonode-users mailing list
