[GeoNode-users] importing private layer creates a public layer
Carmine Massarelli
carmine.massarelli at ba.irsa.cnr.it
Tue Mar 1 00:46:00 PST 2016
Yes to all,
in addiction I report that if I try to print the layer with the print
tool the layer disappear (as it should be for a protected layer).
I use geonode version 2.4b25 on Ubuntu server 14.04.
I am opening a ticket on github.
Is it possible (at the moment) to prevent other user to create map?
Thanks
Carmine
Il 02/29/2016 09:30 PM, Paolo Corti ha scritto:
> If I understand correctly:
> * you set a layer as not being downloadable using the "Set
> permissions" form in the layer page
> * the layer details page correctly does not display the "Download
> layer" button
> * clicking on the "Download map" button in the map details page you
> will get that layer in the download zip file
> If confirmed, it is a bug, so please file a ticket in github.
> Having said so, please consider that even after fixing the bug (pretty
> easy in this case) at this time the layer download permissions are
> honored only by the GeoNode Django interface, and not by GeoServer:
> https://github.com/GeoNode/geonode/issues/2085
> best
> p
> On Mon, Feb 29, 2016 at 1:44 PM, Carmine Massarelli
> <carmine.massarelli at ba.irsa.cnr.it
> <mailto:carmine.massarelli at ba.irsa.cnr.it>> wrote:
> thanks for the reply but unfortunately does not solve the problem.
> The layer is set only in display mode but if a user creates a map
> with this layer and clicks on the map download he can download the
> layer zip file. I made only changes in settings.py about allowed
> hosts, the user belongs to a group. In a WM duplicate of the
> platform I get a warning that says that you can not download the
> layer for safety reasons, while in the published version on the
> web there is no such notice. What could be related?
> Thank you
> Carmine
> Il 28/02/2016 08:45, Simone Dalmasso ha scritto:
>> Hi, you can set whether a new layer is public or not by changing
>> those two settings here
>> https://github.com/GeoNode/geonode/blob/master/geonode/settings.py#L405
>> Hope it helps
>> 2016-02-28 0:05 GMT+01:00 Carmine Massarelli
>> <mailto:carmine.massarelli at ba.irsa.cnr.it>>:
>> Dear,
>> how can I avoid this: when I upload a private layer (no edit
>> and no download permitted, only view and query) another user
>> is able to download it by creating a new public map with this
>> layer. Is there a way to prevent other users from creating
>> maps or downloading private layer if imported in other maps?
>> Regards
>> Carmine
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> <mailto:geonode-users at lists.osgeo.org>
>> http://lists.osgeo.org/mailman/listinfo/geonode-users
>> Simone
> geonode-users at lists.osgeo.org <mailto:geonode-users at lists.osgeo.org>
> Paolo Corti
> Geospatial software developer
> web: http://www.paolocorti.net
> twitter: @capooti
> skype: capooti
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160301/fe63ea15/attachment.html>
More information about the geonode-users
