[GeoNode-users] unable to locate package geonode
Levi Westerveld levi.westerveld at gmail.com
Thu Mar 10 03:44:41 PST 2016
Hi Simone,
I hadn't seen your message by the time I had already removed geonode. Now
when trying to reinstall after updating I get this issue:
administrator at Opengeo:~$ sudo apt-get install geonode
Reading package lists... Done
Building dependency tree
Reading state information... Done
geonode is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 184 not upgraded.
1 not fully installed or removed.
Need to get 0 B/4 172 kB of archives.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] y
dpkg: error processing package geonode (--configure):
 package geonode is not ready for configuration
 cannot configure (current status `half-installed')
Errors were encountered while processing:
 geonode
E: Sub-process /usr/bin/dpkg returned an error code (1)
On Thu, Mar 10, 2016 at 12:25 PM, Simone Dalmasso <simone.dalmasso at gmail.com
> wrote:
> Hi,
> Do a tail -f /var/logs/apache2/error.log and take a look at what error is.
> There shouldn't be the need of a reinstall
> Il giovedì 10 marzo 2016, Levi Westerveld <levi.westerveld at gmail.com> ha
> scritto:
>> Hi again,
>> thank you for updating the documentation.
>> after setting up a superuser, it didn't recognize the associated password
>> when trying to login in the browser. i tried creating a new superuser with
>> a different password but the problem was the same. now when i type my ip
>> address in the browser i get: Internal Server Error.. The server
>> encountered an internal error or misc...
>> should i uninstall and try to reinstall geonode?
>> thank you,
>> levi
>> On Thu, Mar 10, 2016 at 10:59 AM, Paolo Pasquali <
>> paolo.pasquali at ithaca.polito.it> wrote:
>>> Hi,
>>> the documentation was not updated:
>>> http://docs.geonode.org/en/latest/tutorials/install_and_admin/quick_install.html#quick-installation
>>> There is still a reference to ppa:geonode/release
>>> Should be updated to ppa:geonode/stable
>>> Paolo Pasquali
>>> ITHACA
>>> Information Technology for Humanitarian Assistance, Cooperation and
>>> Action
>>> via Pier Carlo Boggio, 61 - 10138 Torino - Italy
>>> Tel. +39 011 1975 1872
>>> Fax +39 011 1975 1122
>>> www.ithacaweb.org
>>> On Thu, Mar 10, 2016 at 10:16 AM, Simone Dalmasso <
>>> simone.dalmasso at gmail.com> wrote:
>>>> Hi Levi,
>>>> what ppa did you use?
>>>> the correct one is ppa:geonode/stable
>>>> then sudo apt-get update
>>>> 2016-03-10 10:13 GMT+01:00 Levi Westerveld <levi.westerveld at gmail.com>:
>>>>> Hello,
>>>>> I have been trying to install geonode 2.4 on an Ubuntu 14.04 machine.
>>>>> I first had an issue with KEYS but that was solved using the Y-PPA-manager.
>>>>> I now get this error, I haven't been able to solve it, I wonder if there is
>>>>> a problem elsewhere?..
>>>>> E: Unable to locate package geonode
>>>>> thank you,
>>>>> Levi
>>>>> _______________________________________________
>>>>> geonode-users mailing list
>>>>> geonode-users at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/geonode-users
>>>> Simone
>> Levi Westerveld
> Simone
Levi Westerveld
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160310/82b4ef2e/attachment.html>
More information about the geonode-users mailing list
