[GeoNode-users] Site_base.css is not found when theming
Kevin Côté
Kevin.Cote2 at USherbrooke.ca
Thu Mar 10 08:10:29 PST 2016
I'm trying to customize the GeoNode page following the tutorial in the
docs.
I've updated the site_base.css file as explained, and did the "python
manage.py collectstatic" command in my project folder.
Then, I'm getting this message:
" You have requested to collect static files at the destination
location as specified in your settings:
/usr/lib/python2.7/site-packages/geonode/static_root
This will overwrite existing files!
Are you sure you want to do this? "
I answer 'yes' and then 2 files are copied to the
/usr/lib/python2.7/site-packages/geonode/static_root (I'm guessing the
site_base.css file and the logo). I restart the Apache server and when I
access my localhost, I'm getting only the text of GeoNode site (no css
are loaded).
If I look at the source code of the page and click on the
/static/site_base.css link, I'm getting a 404 error.
Where does this problem comes from ? Do I need to set a path somewhere
in a configuration file ?
Thanks for your help !!!
Kevin
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160310/e72de25e/attachment.html>
More information about the geonode-users
