[GeoNode-users] unable to locate package geonode
Simone Dalmasso
simone.dalmasso at gmail.com
Thu Mar 10 12:39:50 PST 2016
Hi seems that the new installation did not properly remove the
/etc/geonode/local_setting.py file.
My suggestion is to change the postgresql password for the user geonode and
the update accordingly in that file.
2016-03-10 12:49 GMT+01:00 Levi Westerveld <levi.westerveld at gmail.com>:
> And this the error message I get when I try creating a new superuser
> administrator at Opengeo:~$ geonode createsuperuser
> Not enabling BingMaps base layer as a BING_API_KEY is not defined in
> local_settings.py file.
> Username: gridadmin3
> Traceback (most recent call last):
> File "/usr/bin/django-admin.py", line 5, in <module>
> management.execute_from_command_line()
> File
> "/usr/lib/python2.7/dist-packages/django/core/management/__init__.py", line
> 399, in execute_from_command_line
> utility.execute()
> File
> 392, in execute
> self.fetch_command(subcommand).run_from_argv(self.argv)
> File "/usr/lib/python2.7/dist-packages/django/core/management/base.py",
> line 242, in run_from_argv
> self.execute(*args, **options.__dict__)
> line 285, in execute
> output = self.handle(*args, **options)
> File
> "/usr/lib/python2.7/dist-packages/django/contrib/auth/management/commands/createsuperuser.py",
> line 102, in handle
> self.UserModel._default_manager.db_manager(database).get_by_natural_key(username)
> File "/usr/lib/python2.7/dist-packages/django/contrib/auth/models.py",
> line 167, in get_by_natural_key
> return self.get(**{self.model.USERNAME_FIELD: username})
> File "/usr/lib/python2.7/dist-packages/django/db/models/manager.py",
> line 151, in get
> return self.get_queryset().get(*args, **kwargs)
> File "/usr/lib/python2.7/dist-packages/django/db/models/query.py", line
> 304, in get
> num = len(clone)
> 77, in __len__
> self._fetch_all()
> 857, in _fetch_all
> self._result_cache = list(self.iterator())
> 220, in iterator
> for row in compiler.results_iter():
> File
> "/usr/lib/python2.7/dist-packages/django/db/models/sql/compiler.py", line
> 713, in results_iter
> for rows in self.execute_sql(MULTI):
> File
> 785, in execute_sql
> cursor = self.connection.cursor()
> File "/usr/lib/python2.7/dist-packages/django/db/backends/__init__.py",
> line 162, in cursor
> cursor = util.CursorWrapper(self._cursor(), self)
> line 132, in _cursor
> self.ensure_connection()
> line 127, in ensure_connection
> self.connect()
> File "/usr/lib/python2.7/dist-packages/django/db/utils.py", line 99, in
> __exit__
> six.reraise(dj_exc_type, dj_exc_value, traceback)
> self.connect()
> line 115, in connect
> self.connection = self.get_new_connection(conn_params)
> File
> "/usr/lib/python2.7/dist-packages/django/db/backends/postgresql_psycopg2/base.py",
> line 115, in get_new_connection
> return Database.connect(**conn_params)
> File "/usr/lib/python2.7/dist-packages/psycopg2/__init__.py", line 179,
> in connect
> connection_factory=connection_factory, async=async)
> django.db.utils.OperationalError: FATAL: password authentication failed
> for user "geonode"
> FATAL: password authentication failed for user "geonode"
> On Thu, Mar 10, 2016 at 12:44 PM, Levi Westerveld <
> levi.westerveld at gmail.com> wrote:
>> Hi Simone,
>> I hadn't seen your message by the time I had already removed geonode. Now
>> when trying to reinstall after updating I get this issue:
>> administrator at Opengeo:~$ sudo apt-get install geonode
>> Reading package lists... Done
>> Building dependency tree
>> Reading state information... Done
>> geonode is already the newest version.
>> 0 upgraded, 0 newly installed, 0 to remove and 184 not upgraded.
>> 1 not fully installed or removed.
>> Need to get 0 B/4 172 kB of archives.
>> After this operation, 0 B of additional disk space will be used.
>> Do you want to continue? [Y/n] y
>> dpkg: error processing package geonode (--configure):
>> package geonode is not ready for configuration
>> cannot configure (current status `half-installed')
>> Errors were encountered while processing:
>> geonode
>> E: Sub-process /usr/bin/dpkg returned an error code (1)
>> On Thu, Mar 10, 2016 at 12:25 PM, Simone Dalmasso <
>> simone.dalmasso at gmail.com> wrote:
>>> Hi,
>>> Do a tail -f /var/logs/apache2/error.log and take a look at what error
>>> is. There shouldn't be the need of a reinstall
>>> Il giovedì 10 marzo 2016, Levi Westerveld <levi.westerveld at gmail.com>
>>> ha scritto:
>>>> Hi again,
>>>> thank you for updating the documentation.
>>>> after setting up a superuser, it didn't recognize the associated
>>>> password when trying to login in the browser. i tried creating a new
>>>> superuser with a different password but the problem was the same. now when
>>>> i type my ip address in the browser i get: Internal Server Error.. The
>>>> server encountered an internal error or misc...
>>>> should i uninstall and try to reinstall geonode?
>>>> thank you,
>>>> levi
>>>> On Thu, Mar 10, 2016 at 10:59 AM, Paolo Pasquali <
>>>> paolo.pasquali at ithaca.polito.it> wrote:
>>>>> Hi,
>>>>> the documentation was not updated:
>>>>> http://docs.geonode.org/en/latest/tutorials/install_and_admin/quick_install.html#quick-installation
>>>>> There is still a reference to ppa:geonode/release
>>>>> Should be updated to ppa:geonode/stable
>>>>> Paolo Pasquali
>>>>> ITHACA
>>>>> Information Technology for Humanitarian Assistance, Cooperation and
>>>>> Action
>>>>> via Pier Carlo Boggio, 61 - 10138 Torino - Italy
>>>>> Tel. +39 011 1975 1872
>>>>> Fax +39 011 1975 1122
>>>>> www.ithacaweb.org
>>>>> On Thu, Mar 10, 2016 at 10:16 AM, Simone Dalmasso <
>>>>>> Hi Levi,
>>>>>> what ppa did you use?
>>>>>> the correct one is ppa:geonode/stable
>>>>>> then sudo apt-get update
>>>>>> 2016-03-10 10:13 GMT+01:00 Levi Westerveld <levi.westerveld at gmail.com
>>>>>>> Hello,
>>>>>>> I have been trying to install geonode 2.4 on an Ubuntu 14.04
>>>>>>> machine. I first had an issue with KEYS but that was solved using the
>>>>>>> Y-PPA-manager. I now get this error, I haven't been able to solve it, I
>>>>>>> wonder if there is a problem elsewhere?..
>>>>>>> E: Unable to locate package geonode
>>>>>>> thank you,
>>>>>>> Levi
>>>>>>> _______________________________________________
>>>>>>> geonode-users mailing list
>>>>>>> geonode-users at lists.osgeo.org
>>>>>>> http://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>>> Simone
>>>> Levi Westerveld
>>> Simone
>> Levi Westerveld
> Levi Westerveld
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160310/6f911b7e/attachment-0001.html>
More information about the geonode-users
