[GeoNode-users] Geonode authentication error from geoserver
Lavalle, Mirko lavalle at gesp.it
Mon Mar 21 04:45:15 PDT 2016
i have an issue loading a shape file from layers section of geonoe. I have
the following error after files are uploaded:
 - HTTP full authentication is required.
Looking for a solution on the web it seems the problem is the comunication
from geoserver calling the authentication class of geonode: it seems
geoserver is not be able to reach geonode to get back confirm of
authentication.
I properly set all url configurations of config.xml (into security of
geoserver data), web.xml and local_setting.py, trying both with
"localhost", and with the IP of the server, but the error persists.
My environment is:
- Windows 2012
- Apache 2.2 (Osgeo4w)
- Tomcat 7
Here the stack trace:
21 Mar 12:10:21 WARN [geonode.security] - Error connecting to the GeoNode
server for authentication purposes
org.springframework.security.authentication.AuthenticationServiceException:
Communication with GeoNode failed (GeoNodeSessionAuthToken)
 at
org.geonode.security.GeoNodeAuthenticationProvider.authenticate(GeoNodeAuthenticationProvider.java:68)
 at
org.geoserver.security.GeoServerAuthenticationProvider.authenticate(GeoServerAuthenticationProvider.java:58)
 at
org.springframework.security.authentication.ProviderManager.authenticate(ProviderManager.java:156)
 at
org.geonode.security.GeoNodeCookieProcessingFilter.doFilter(GeoNodeCookieProcessingFilter.java:98)
 at
org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323)
 at
org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:69)
 at
org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
 at
org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:53)
 at
org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:73)
 at
org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:92)
 at
 at
org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:173)
 at
org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:135)
 at
org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
 at
org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:259)
 at
org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241)
 at
org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208)
 at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:87)
 at
 at
 at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
 at
 at
 at
org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:48)
 at
 at
 at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:44)
 at
 at
 at
org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:109)
 at
 at
 at
org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:220)
 at
org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:122)
 at
org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:505)
 at
org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:169)
 at
org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:103)
 at
org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:956)
 at
org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:116)
 at
org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:436)
 at
org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1078)
 at
org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:625)
 at
org.apache.tomcat.util.net.AprEndpoint$SocketProcessor.doRun(AprEndpoint.java:2517)
 at
org.apache.tomcat.util.net.AprEndpoint$SocketProcessor.run(AprEndpoint.java:2506)
 at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
 at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
 at
org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
 at java.lang.Thread.run(Unknown Source)
Caused by: java.net.SocketTimeoutException: Read timed out
 at java.net.SocketInputStream.socketRead0(Native Method)
 at java.net.SocketInputStream.read(Unknown Source)
 at java.io.BufferedInputStream.fill(Unknown Source)
 at java.io.BufferedInputStream.read(Unknown Source)
 at org.apache.commons.httpclient.HttpParser.readRawLine(HttpParser.java:78)
 at org.apache.commons.httpclient.HttpParser.readLine(HttpParser.java:106)
 at
org.apache.commons.httpclient.HttpConnection.readLine(HttpConnection.java:1116)
 at
org.apache.commons.httpclient.HttpMethodBase.readStatusLine(HttpMethodBase.java:1973)
 at
org.apache.commons.httpclient.HttpMethodBase.readResponse(HttpMethodBase.java:1735)
 at
org.apache.commons.httpclient.HttpMethodBase.execute(HttpMethodBase.java:1098)
 at
org.apache.commons.httpclient.HttpMethodDirector.executeWithRetry(HttpMethodDirector.java:398)
 at
org.apache.commons.httpclient.HttpMethodDirector.executeMethod(HttpMethodDirector.java:171)
 at
org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:397)
 at
org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:323)
 at org.geonode.security.HTTPClient.sendGET(HTTPClient.java:89)
 at
org.geonode.security.DefaultSecurityClient.authenticate(DefaultSecurityClient.java:185)
 at
org.geonode.security.DefaultSecurityClient.authenticateCookie(DefaultSecurityClient.java:116)
 at
org.geonode.security.GeoNodeAuthenticationProvider.authenticate(GeoNodeAuthenticationProvider.java:66)
 ... 47 more
Eny help is appreciated.
Thanks
Mirko
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160321/b5f307c0/attachment.html>
More information about the geonode-users mailing list
