[GeoNode-users] Error accesing geonode
Simone Dalmasso
simone.dalmasso at gmail.com
Mon May 2 23:26:34 PDT 2016
Hi, systemwide is usually the best option using ppa:geonode/stable on
ubuntu 14.04.
A custom installation is possible and the doc is
http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/index.html
2016-05-02 18:34 GMT+02:00 Eduardo Pascoal <pascoal.egeo at gmail.com>:
> Hi all,
> I have this same issue.. "OperationalError at / unable to open database
> file" it how can i install geonode without ppa:geonode/testing i mean
> without installing in systemwide.
> I'm having some problems to run geonode 2.4.x (the same that David has
> reported).
> There is any installation guide for 2.4.x. Running for development it
> seems to work fine.. but if i run from apache2 it will broke with "OperationalError
> at / unable to open database file".
> What am i missing?
> 2015-11-18 11:00 GMT+00:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
>> Apologize, we are in the process of a new release and update docs.
>> Yes it is much better to do a clean install of geonode using
>> ppa:geonode/testing.
>> 2015-11-18 11:49 GMT+01:00 David Alda Fernandez de Lezea <dalda at hazi.eus>
>>> Ok, so that's the problem.
>>> So the documentation
>>> https://geonode.readthedocs.org/en/2.0/tutorials/admin/customize_admin/setup_admin.html#customize-setup-admin
>>> Should be corrected, because I followed the steps described there but
>>> the instructions to download pointed to a newer version. That is confusing
>>> if it remains like that.
>>> Anyway, is there anything I can do to fix it? Or do I have to reinstall
>>> everything..
>>> Regards,
>>> Agur bero bat,
>>> David Alda Fernández de Lezea
>>> Área de Sistemas de Información Geográfica, Planificación Territorial y
>>> Forestal Informazio Geografikoen Sistemak, Lurralde eta Baso Antolaketaren
>>> Arloa.
>>> dalda at hazi.eus | www.hazi.eus
>>> T 945 003 240 – M 627 923 170 – F 945 003 290
>>> Hazi | Granja Modelo de Arkaute s/n | 01192 Arkaute – Araba
>>> ********************* LEGE OHARRA ******************* AVISOLEGAL
>>> ******************* DISCLAIMER *****************************
>>> Mezu hau pertsonala eta isilpekoa da eta baimenik gabeko erabilera
>>> debekatua dago legalki. Jasotzailea ez bazara ezabatu mezua, bidali eta
>>> kontserbatu gabe.
>>> Este mensaje es personal y confidencial y su uso no autorizado está
>>> prohibido legalmente. Si usted no es el destinatario, proceda a borrarlo,
>>> sin reenviarlo ni conservarlo.
>>> This message is personal and confidential, unauthorised use is legally
>>> prohibited. If you are not the intended recipient, delete it without
>>> resending or backing it.
>>> De: Simone Dalmasso [mailto:simone.dalmasso at gmail.com]
>>> Enviado el: miércoles, 18 de noviembre de 2015 10:37
>>> Para: David Alda Fernandez de Lezea
>>> CC: geonode-users at lists.osgeo.org
>>> Asunto: Re: [GeoNode-users] Error accesing geonode
>>> Ah! now I see.
>>> Yes you used the wrong project. I suggest you to use the geonode from
>>> ppa:geonode/testing. It is the 2.4 rc2. We are going to release the stable
>>> in few days though.
>>> 2015-11-18 10:16 GMT+01:00 David Alda Fernandez de Lezea <dalda at hazi.eus
>>> Hi,
>>> I don't think so, unless I've made the mistake of editing the wrong file
>>> since the beginning...
>>> After the installation I began to edit the file local_settings.py under
>>> /etc/geonode. I changed GeServer urls, added different base layers,
>>> activated email registration and so on.
>>> I guess is the right one.
>>> What I'm thinking is that I installed geonode from apt-get which is
>>> 2.0.1 version and when I followed the steps for customizing the line
>>> django-admin startproject my_geonode --template=
>>> https://github.com/GeoNode/geonode-project/archive/master.zip -epy,rst
>>> does download the correct templates for my version? Because this is the
>>> only thing different that I've noticed.
>>> Agur bero bat,
>>> Arloa.
>>> kontserbatu gabe.
>>> Enviado el: miércoles, 18 de noviembre de 2015 9:02
>>> David,
>>> was the PRINTNG in the local_settings?
>>> my suspect is that the etc settings is old and comes from an older
>>> installation, is that possible?
>>> Make sure it is similar to
>>> https://github.com/GeoNode/geonode/blob/master/geonode/local_settings.py.sample
>>> 2015-11-18 8:56 GMT+01:00 David Alda Fernandez de Lezea <dalda at hazi.eus
>>> Hi,
>>> No way man. After doing what you said, I restarted the web server and
>>> tried to visit geonode's main page but I get 500 error. This is the output:
>>> [Wed Nov 18 08:47:04 2015] [notice] caught SIGTERM, shutting down
>>> [Wed Nov 18 01:47:04 2015] [error] Exception TypeError: "'NoneType'
>>> object is not callable" in <bound method LGEOS320.__del__ of
>>> <shapely.geos.LGEOS320 object at 0x7f492fa1e258>> ignored
>>> Error opening file for reading: Permission denied
>>> [Wed Nov 18 08:47:05 2015] [notice] Apache/2.2.22 (Ubuntu) mod_wsgi/3.3
>>> Python/2.7.3 configured -- resuming normal operations
>>> [Wed Nov 18 01:47:17 2015] [error] [client 192.168.1.65] mod_wsgi
>>> (pid=11385): Exception occurred processing WSGI script
>>> '/var/www/geonode/wsgi/geonode.wsgi'.
>>> [Wed Nov 18 01:47:17 2015] [error] [client 192.168.1.65] Traceback (most
>>> recent call last):
>>> [Wed Nov 18 01:47:17 2015] [error] [client 192.168.1.65] File
>>> "/usr/local/lib/python2.7/dist-packages/django/core/handlers/wsgi.py", line
>>> 187, in __call__
>>> self.load_middleware()
>>> "/usr/local/lib/python2.7/dist-packages/django/core/handlers/base.py", line
>>> 47, in load_middleware
>>> [Wed Nov 18 01:47:17 2015] [error] [client 192.168.1.65] mw_instance
>>> = mw_class()
>>> "/usr/local/lib/python2.7/dist-packages/django/middleware/locale.py", line
>>> 24, in __init__
>>> [Wed Nov 18 01:47:17 2015] [error] [client 192.168.1.65] for
>>> url_pattern in get_resolver(None).url_patterns:
>>> "/usr/local/lib/python2.7/dist-packages/django/core/urlresolvers.py", line
>>> 365, in url_patterns
>>> [Wed Nov 18 01:47:17 2015] [error] [client 192.168.1.65] patterns =
>>> getattr(self.urlconf_module, "urlpatterns", self.urlconf_module)
>>> 360, in urlconf_module
>>> self._urlconf_module = import_module(self.urlconf_name)
>>> "/usr/local/lib/python2.7/dist-packages/django/utils/importlib.py", line
>>> 40, in import_module
>>> __import__(name)
>>> "/usr/local/lib/python2.7/dist-packages/geonode/urls.py", line 30, in
>>> <module>
>>> [Wed Nov 18 01:47:17 2015] [error] [client 192.168.1.65] from
>>> geonode.api.urls import api
>>> "/usr/local/lib/python2.7/dist-packages/geonode/api/urls.py", line 3, in
>>> <module>
>>> [Wed Nov 18 01:47:17 2015] [error] [client 192.168.1.65] from .api
>>> import TagResource, TopicCategoryResource, ProfileResource, \\
>>> "/usr/local/lib/python2.7/dist-packages/geonode/api/api.py", line 188, in
>>> <module>
>>> [Wed Nov 18 01:47:17 2015] [error] [client 192.168.1.65] class
>>> ProfileResource(ModelResource):
>>> "/usr/local/lib/python2.7/dist-packages/geonode/api/api.py", line 276, in
>>> ProfileResource
>>> [Wed Nov 18 01:47:17 2015] [error] [client 192.168.1.65] class Meta:
>>> "/usr/local/lib/python2.7/dist-packages/geonode/api/api.py", line 277, in
>>> Meta
>>> [Wed Nov 18 01:47:17 2015] [error] [client 192.168.1.65] queryset =
>>> get_user_model().objects.exclude(username='AnonymousUser')
>>> "/usr/local/lib/python2.7/dist-packages/django/contrib/auth/__init__.py",
>>> line 127, in get_user_model
>>> [Wed Nov 18 01:47:17 2015] [error] [client 192.168.1.65] user_model
>>> = get_model(app_label, model_name)
>>> "/usr/local/lib/python2.7/dist-packages/django/db/models/loading.py", line
>>> 271, in get_model
>>> self._populate()
>>> 75, in _populate
>>> self.load_app(app_name, True)
>>> 99, in load_app
>>> [Wed Nov 18 01:47:17 2015] [error] [client 192.168.1.65] models =
>>> import_module('%s.models' % app_name)
>>> __import__(name)
>>> "/usr/local/lib/python2.7/dist-packages/geonode/upload/models.py", line 28,
>>> in <module>
>>> geonode.geoserver.helpers import gs_uploader, ogc_server_settings
>>> "/usr/local/lib/python2.7/dist-packages/geonode/geoserver/helpers.py", line
>>> 1548, in <module>
>>> ogc_server_settings = OGC_Servers_Handler(settings.OGC_SERVER)['default']
>>> 1349, in __getitem__
>>> self.ensure_valid_configuration(alias)
>>> 1319, in ensure_valid_configuration
>>> [Wed Nov 18 01:47:17 2015] [error] [client 192.168.1.65] raise
>>> ImproperlyConfigured("The PRINTNG_ENABLED setting has been removed, use
>>> 'PRINT_NG_ENABLED' instead.")
>>> ImproperlyConfigured: The PRINTNG_ENABLED setting has been removed, use
>>> u0899dal at Geonode:/var/log/apache2$
>>> Then I changed PRINTNG_ENABLED to PRINT_NG_ENABLED (I don't know why do
>>> I have to this because it was working fine after the everything started to
>>> crash down) but I get the following error:
>>> [Wed Nov 18 08:52:48 2015] [notice] caught SIGTERM, shutting down
>>> [Wed Nov 18 08:52:49 2015] [notice] Apache/2.2.22 (Ubuntu) mod_wsgi/3.3
>>> [Wed Nov 18 01:53:06 2015] [error] Internal Server Error: /
>>> [Wed Nov 18 01:53:06 2015] [error] Traceback (most recent call last):
>>> [Wed Nov 18 01:53:06 2015] [error] File
>>> 137, in get_response
>>> [Wed Nov 18 01:53:06 2015] [error] response = response.render()
>>> "/usr/local/lib/python2.7/dist-packages/django/template/response.py", line
>>> 105, in render
>>> [Wed Nov 18 01:53:06 2015] [error] self.content =
>>> self.rendered_content
>>> 82, in rendered_content
>>> [Wed Nov 18 01:53:06 2015] [error] content = template.render(context)
>>> "/usr/local/lib/python2.7/dist-packages/django/template/base.py", line 140,
>>> in render
>>> [Wed Nov 18 01:53:06 2015] [error] return self._render(context)
>>> "/usr/local/lib/python2.7/dist-packages/django/template/base.py", line 134,
>>> in _render
>>> self.nodelist.render(context)
>>> "/usr/local/lib/python2.7/dist-packages/django/template/base.py", line 840,
>>> in render
>>> [Wed Nov 18 01:53:06 2015] [error] bit = self.render_node(node,
>>> context)
>>> "/usr/local/lib/python2.7/dist-packages/django/template/base.py", line 854,
>>> in render_node
>>> [Wed Nov 18 01:53:06 2015] [error] return node.render(context)
>>> "/usr/local/lib/python2.7/dist-packages/django/template/loader_tags.py",
>>> line 123, in render
>>> compiled_parent._render(context)
>>> in _render
>>> in render
>>> context)
>>> in render_node
>>> line 123, in render
>>> in _render
>>> in render
>>> context)
>>> in render_node
>>> line 62, in render
>>> [Wed Nov 18 01:53:06 2015] [error] result =
>>> block.nodelist.render(context)
>>> in render
>>> context)
>>> in render_node
>>> "/usr/local/lib/python2.7/dist-packages/django/template/base.py", line 891,
>>> in render
>>> [Wed Nov 18 01:53:06 2015] [error] output =
>>> self.filter_expression.resolve(context)
>>> "/usr/local/lib/python2.7/dist-packages/django/template/base.py", line 585,
>>> in resolve
>>> [Wed Nov 18 01:53:06 2015] [error] obj = self.var.resolve(context)
>>> "/usr/local/lib/python2.7/dist-packages/django/template/base.py", line 735,
>>> in resolve
>>> [Wed Nov 18 01:53:06 2015] [error] value =
>>> self._resolve_lookup(context)
>>> "/usr/local/lib/python2.7/dist-packages/django/template/base.py", line 789,
>>> in _resolve_lookup
>>> [Wed Nov 18 01:53:06 2015] [error] current = current()
>>> line 72, in super
>>> mark_safe(self.render(self.context))
>>> line 62, in render
>>> in render
>>> context)
>>> in render_node
>>> line 155, in render
>>> self.render_template(self.template, context)
>>> line 137, in render_template
>>> [Wed Nov 18 01:53:06 2015] [error] output = template.render(context)
>>> in render
>>> in _render
>>> in render
>>> context)
>>> in render_node
>>> "/usr/local/lib/python2.7/dist-packages/django/template/defaulttags.py",
>>> line 304, in render
>>> [Wed Nov 18 01:53:06 2015] [error] if match:
>>> "/usr/local/lib/python2.7/dist-packages/django/db/models/query.py", line
>>> 100, in __nonzero__
>>> [Wed Nov 18 01:53:06 2015] [error] self._fetch_all()
>>> 857, in _fetch_all
>>> [Wed Nov 18 01:53:06 2015] [error] self._result_cache =
>>> list(self.iterator())
>>> 220, in iterator
>>> [Wed Nov 18 01:53:06 2015] [error] for row in
>>> compiler.results_iter():
>>> "/usr/local/lib/python2.7/dist-packages/django/db/models/sql/compiler.py",
>>> line 713, in results_iter
>>> [Wed Nov 18 01:53:06 2015] [error] for rows in
>>> self.execute_sql(MULTI):
>>> line 786, in execute_sql
>>> [Wed Nov 18 01:53:06 2015] [error] cursor.execute(sql, params)
>>> "/usr/local/lib/python2.7/dist-packages/django/db/backends/util.py", line
>>> 53, in execute
>>> [Wed Nov 18 01:53:06 2015] [error] return self.cursor.execute(sql,
>>> params)
>>> "/usr/local/lib/python2.7/dist-packages/django/db/utils.py", line 99, in
>>> __exit__
>>> [Wed Nov 18 01:53:06 2015] [error] six.reraise(dj_exc_type,
>>> dj_exc_value, traceback)
>>> 53, in execute
>>> params)
>>> [Wed Nov 18 01:53:06 2015] [error] ProgrammingError: column
>>> announcements_announcement.level does not exist
>>> [Wed Nov 18 01:53:06 2015] [error] LINE 1: ...ment"."id",
>>> "announcements_announcement"."title", "announcem...
>>> [Wed Nov 18 01:53:06 2015] [error] [client 192.168.1.65] mod_wsgi
>>> (pid=11661): Exception occurred processing WSGI script
>>> [Wed Nov 18 01:53:06 2015] [error] [client 192.168.1.65] Traceback (most
>>> recent call last):
>>> [Wed Nov 18 01:53:06 2015] [error] [client 192.168.1.65] File
>>> 206, in __call__
>>> [Wed Nov 18 01:53:06 2015] [error] [client 192.168.1.65] response =
>>> self.get_response(request)
>>> 194, in get_response
>>> self.handle_uncaught_exception(request, resolver, sys.exc_info())
>>> 236, in handle_uncaught_exception
>>> [Wed Nov 18 01:53:06 2015] [error] [client 192.168.1.65] return
>>> callback(request, **param_dict)
>>> "/usr/local/lib/python2.7/dist-packages/django/utils/decorators.py", line
>>> 99, in _wrapped_view
>>> view_func(request, *args, **kwargs)
>>> "/usr/local/lib/python2.7/dist-packages/django/views/defaults.py", line 46,
>>> in server_error
>>> http.HttpResponseServerError(template.render(Context({})))
>>> in render
>>> in _render
>>> in render
>>> [Wed Nov 18 01:53:06 2015] [error] [client 192.168.1.65] bit =
>>> self.render_node(node, context)
>>> in render_node
>>> line 53, in render
>>> [Wed Nov 18 01:53:06 2015] [error] [client 192.168.1.65] result =
>>> in render
>>> in render_node
>>> line 155, in render
>>> [Wed Nov 18 01:53:06 2015] [error] [client 192.168.1.65] output =
>>> in render
>>> in _render
>>> in render
>>> in render_node
>>> "/usr/local/lib/python2.7/dist-packages/announcements/templatetags/announcements_tags.py",
>>> line 24, in render
>>> [Wed Nov 18 01:53:06 2015] [error] [client 192.168.1.65] request =
>>> context["request"]
>>> "/usr/local/lib/python2.7/dist-packages/django/template/context.py", line
>>> 56, in __getitem__
>>> [Wed Nov 18 01:53:06 2015] [error] [client 192.168.1.65] raise
>>> KeyError(key)
>>> [Wed Nov 18 01:53:06 2015] [error] [client 192.168.1.65] KeyError:
>>> 'request'
>>> I'm running out of ideas.
>>> Regards,
>>> Agur bero bat,
>>> Arloa.
>>> kontserbatu gabe.
>>> Enviado el: miércoles, 18 de noviembre de 2015 8:35
>>> ok then create the symlink:
>>> $ sudo ln -sf
>>> /etc/geonode/local_settings.py /usr/local/lib/python2.7/dist-packages/geonode/local_settings.py
>>> that points to /etc/geonode/local_settings.py
>>> restart the web server and you should be ok
>>> 2015-11-18 8:25 GMT+01:00 David Alda Fernandez de Lezea <dalda at hazi.eus
>>> Hi,
>>> In the mentioned directory there's no "local_setttings.py" but there is
>>> a settings.py which has another GeoNode set up as I can see. Here's the
>>> content of the directory:
>>> u0899dal at Geonode:/usr/local/lib/python2.7/dist-packages/geonode$ ls -al
>>> total 264
>>> drwxr-sr-x 23 root staff 4096 nov 13 14:23 .
>>> drwxrwsr-x 107 root staff 4096 nov 13 14:20 ..
>>> drwxr-sr-x 2 root staff 4096 nov 13 14:19 api
>>> drwxr-sr-x 6 root staff 4096 nov 13 14:19 base
>>> drwxr-sr-x 4 root staff 4096 nov 13 14:19 catalogue
>>> -rw-r--r-- 1 root staff 314 nov 13 14:17 celery_app.py
>>> -rw-r--r-- 1 root staff 477 nov 13 14:19 celery_app.pyc
>>> -rw-r--r-- 1 root staff 3018 nov 13 14:17 context_processors.py
>>> -rw-r--r-- 1 root staff 1874 nov 13 14:19 context_processors.pyc
>>> drwxr-sr-x 4 root staff 4096 nov 13 14:19 contrib
>>> drwxr-sr-x 5 root staff 4096 nov 13 14:19 documents
>>> drwxr-sr-x 3 root staff 4096 nov 13 14:19 geoserver
>>> drwxr-sr-x 4 root staff 4096 nov 13 14:19 groups
>>> -rw-r--r-- 1 root staff 1291 nov 13 14:17 __init__.py
>>> -rw-r--r-- 1 root staff 1195 nov 13 14:19 __init__.pyc
>>> drwxr-sr-x 5 root staff 4096 nov 13 14:19 layers
>>> drwxr-sr-x 38 root staff 4096 nov 13 14:19 locale
>>> drwxr-sr-x 4 root staff 4096 nov 13 14:19 maps
>>> -rw-r--r-- 1 root staff 1192 nov 13 14:17 middleware.py
>>> -rw-r--r-- 1 root staff 1832 nov 13 14:19 middleware.pyc
>>> drwxr-sr-x 5 root staff 4096 nov 13 14:19 people
>>> drwxr-sr-x 2 root staff 4096 nov 13 14:19 proxy
>>> drwxr-sr-x 3 root staff 4096 nov 13 14:19 security
>>> drwxr-sr-x 4 root staff 4096 nov 13 14:19 services
>>> -rw-r--r-- 1 root staff 26032 nov 13 14:17 settings.py
>>> -rw-r--r-- 1 root staff 18850 nov 13 14:19 settings.pyc
>>> -rw-r--r-- 1 root staff 1218 nov 13 14:17 sitemap.py
>>> -rw-r--r-- 1 root staff 1336 nov 13 14:19 sitemap.pyc
>>> drwxr-sr-x 4 root staff 4096 nov 13 14:19 social
>>> drwxr-sr-x 4 root staff 4096 nov 13 14:19 static
>>> drwxr-sr-x 21 root staff 4096 nov 13 14:23 static_root
>>> drwxr-sr-x 2 root staff 4096 nov 13 14:19 tasks
>>> drwxr-sr-x 13 root staff 4096 nov 13 14:19 templates
>>> drwxr-sr-x 2 root staff 4096 nov 13 14:19 tests
>>> drwxr-sr-x 4 root staff 4096 nov 13 14:19 upload
>>> -rw-r--r-- 1 root staff 5638 nov 13 14:17 urls.py
>>> -rw-r--r-- 1 root staff 3999 nov 13 14:19 urls.pyc
>>> -rw-r--r-- 1 root staff 21450 nov 13 14:17 utils.py
>>> -rw-r--r-- 1 root staff 21371 nov 13 14:19 utils.pyc
>>> -rw-r--r-- 1 root staff 2623 nov 13 14:17 version.py
>>> -rw-r--r-- 1 root staff 2268 nov 13 14:19 version.pyc
>>> -rw-r--r-- 1 root staff 3927 nov 13 14:17 views.py
>>> -rw-r--r-- 1 root staff 3385 nov 13 14:19 views.pyc
>>> -rw-r--r-- 1 root staff 1105 nov 13 14:17 wsgi.py
>>> -rw-r--r-- 1 root staff 362 nov 13 14:19 wsgi.pyc
>>> Regards,
>>> Agur bero bat,
>>> Arloa.
>>> kontserbatu gabe.
>>> Enviado el: martes, 17 de noviembre de 2015 18:05
>>> Hi,
>>> there is a symlink in
>>> /usr/local/lib/python2.7/dist-packages/geonode/local_settings.py that
>>> points to /etc/geonode/local_settings.py.
>>> 2015-11-17 9:27 GMT+01:00 David Alda Fernandez de Lezea <dalda at hazi.eus
>>> Hi again,
>>> In theory, the local_settigns.py does not have errors as it was working
>>> before the change.. Where is referenced from python the file
>>> /etc/geonode/local_settings.py??
>>> Agur bero bat,
>>> Arloa.
>>> kontserbatu gabe.
>>> Enviado el: lunes, 16 de noviembre de 2015 10:47
>>> Ok then the /etc/geonode/local_settings.py file is not read correctly.
>>> The customization process that you used does not modify at all the
>>> geonode installation and to revert to a vanilla geonode it's enough to just
>>> point apache to the correct wsgi. So it must be something with the
>>> settings. Also a syntax erro in the local_settings could be the cause.
>>> 2015-11-16 10:40 GMT+01:00 David Alda Fernandez de Lezea <dalda at hazi.eus
>>> I think I'm pointing to the right one:
>>> /etc/apache2/sites-available/geonode
>>> WSGIProcessGroup geonode
>>> WSGIPassAuthorization On
>>> WSGIScriptAlias / /var/www/geonode/wsgi/geonode.wsgi
>>> <Directory "/var/www/geonode/">
>>> Order allow,deny
>>> Options Indexes FollowSymLinks
>>> Allow from all
>>> IndexOptions FancyIndexing
>>> </Directory>
>>> Still getting the same error.
>>> Agur bero bat,
>>> Arloa.
>>> kontserbatu gabe.
>>> Enviado el: lunes, 16 de noviembre de 2015 10:00
>>> Maybe apache is still pointing to the wrong wsgi file, not the original
>>> geonode. Also try to turn on debug in your settings, you will discover if
>>> they are actually used and in case yes where the error is.
>>> 2015-11-16 9:44 GMT+01:00 David Alda Fernandez de Lezea <dalda at hazi.eus
>>> Hi Simone,
>>> I had it working normally before I started modifying all the look and
>>> feel part. Indeed, I haven't changed anything to pint to sqllite.
>>> I also have my local_settigns.py customized and it was working fine. How
>>> can I point the app to my settings file ?
>>> By the way I forgot to put the link with the instructions I followed:
>>> https://geonode.readthedocs.org/en/master/tutorials/admin/customize_admin/setup_admin.html#customize-setup-admin
>>> Agur bero bat,
>>> Arloa.
>>> kontserbatu gabe.
>>> Enviado el: lunes, 16 de noviembre de 2015 9:37
>>> Hi David,
>>> it seems that your settings file is not configured with the correct
>>> database. Is trying to access a file so it's likely that is configured to
>>> use sqllite.
>>> Regards
>>> 2015-11-16 9:25 GMT+01:00 David Alda Fernandez de Lezea <dalda at hazi.eus
>>> Hi list,
>>> I've been trying to customize the look and feel of my geonode following
>>> the instructions in . After configuring several options and not achieving
>>> to get anything working y decide to rollback, but now while accessing my
>>> geonode app y get the following error:
>>> Request Method: GET
>>> Request URL: http://192.168.1.190/
>>> Django Version: 1.6.10
>>> Exception Type: OperationalError
>>> Exception Value:
>>> Exception Location:
>>> /usr/local/lib/python2.7/dist-packages/django/db/backends/sqlite3/base.py
>>> in get_new_connection, line 347
>>> Python Executable: /usr/bin/python
>>> Python Version: 2.7.3
>>> Python Path:
>>> ['/usr/lib/python2.7',
>>> '/usr/lib/python2.7/plat-linux2',
>>> '/usr/lib/python2.7/lib-tk',
>>> '/usr/lib/python2.7/lib-old',
>>> '/usr/lib/python2.7/lib-dynload',
>>> '/usr/local/lib/python2.7/dist-packages',
>>> '/usr/lib/python2.7/dist-packages',
>>> '/usr/lib/python2.7/dist-packages/PIL',
>>> '/usr/lib/python2.7/dist-packages/gst-0.10',
>>> '/usr/lib/python2.7/dist-packages/gtk-2.0',
>>> '/usr/lib/pymodules/python2.7',
>>> '/usr/lib/python2.7/dist-packages/ubuntu-sso-client',
>>> '/usr/lib/python2.7/dist-packages/ubuntuone-client',
>>> '/usr/lib/python2.7/dist-packages/ubuntuone-control-panel',
>>> '/usr/lib/python2.7/dist-packages/ubuntuone-couch',
>>> '/usr/lib/python2.7/dist-packages/ubuntuone-installer',
>>> '/usr/lib/python2.7/dist-packages/ubuntuone-storage-protocol',
>>> '/var/www']
>>> Server time: Mon, 16 Nov 2015 02:16:42 -0600
>>> I can access GeoServer though.
>>> Any ideas? Thanks in advance.
>>> Regards,
>>> Agur bero bat,
>>> Arloa.
>>> T 945 003 240 - M 627 923 170 - F 945 003 290
>>> Hazi | Granja Modelo de Arkaute s/n | 01192 Arkaute - Araba
>>> kontserbatu gabe.
>>> geonode-users mailing list
>>> http://lists.osgeo.org/mailman/listinfo/geonode-users
>>> Simone
>>> Simone
>>> Simone
>>> Simone
>>> Simone
>>> Simone
>>> Simone
>> Simone
> Eduardo Pascoal
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160503/11f5c603/attachment-0001.html>
More information about the geonode-users
