[GeoNode-users] geonode listen ports
Francesco Bartoli
xbartolone at gmail.com
Tue May 3 04:56:37 PDT 2016
Hi Arthur,
yes usually those ports are sufficient.
Regards,
Francesco
Il giorno 03/mag/2016, alle ore 13:53, Arthur Abbott <aabbott at seafortheng.ca> ha scritto:
> Francesco,
> Thanks for the response.
> So what you are saying is that I only need to worry about ports 80 and 8080?
> Thanks,
> Arthur
> On Mon, May 2, 2016 at 6:36 PM, Francesco Bartoli <xbartolone at gmail.com> wrote:
> Arthur,
> actually the django process (GeoNode) would be running on the Apache port while the tomcat process takes on GeoServer on port 8080. So normally, for instance, you would access the Geonode UI at http://localhost:80/
> Francesco
> Il giorno 02/mag/2016, alle ore 18:43, Arthur Abbott <aabbott at seafortheng.ca> ha scritto:
>> All,
>> I have gone through the ubuntu 14.04 quick install and no problems. I am now getting ready to things up for production, but I need to port forward through our server. I wish to make sure I have all of the required port numbers before I try this. So far, I think I need:
>> Apache: 80
>> Tomcat: 8080
>> Postgresql: 5432
>> Geonode: 8080
>> Are there any that I have missed?
>> Thanks,
>> Arthur
>> Arthur Abbott
>> GIS Technician
>> Seaforth Geosurveys Inc.
>> 300 Prince Albert Rd., Suite 200
>> Dartmouth NS Canada B2Y 4J2
>> P: (902) 468-3579 ext. 232
>> F: (902) 468.6865
>> www.seaforthgeosurveys.com
>> Notice this communication, including any attachments, is confidential and is intended only for the person or persons to whom it is addressed. If you have received this e-mail in error, any use, copying or distribution is strictly unauthorizes and you should delete it and any attachments. Please also notify the sender by e-mail or telephone at 902-468-3579. Thank you.
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geonode-users
> Arthur Abbott
> GIS Technician
> F: (902) 468.6865
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160503/74e0453f/attachment.html>
More information about the geonode-users
