[GeoNode-users] Uploading Arc ASCII grid
Arthur Abbott
aabbott at seafortheng.ca
Tue May 3 09:29:00 PDT 2016
I am attempting to upload an ASCII grid into geonode via geoserver. I have
successfully made the datastore and loaded the grid into geoserver. I can
preview the layer and query it.
I understand that the next step is to run: *$ python manage.py updatelayers*.
Where is this script? I did a search and found a copy at
*/usr/lib/python2.7/dist-packages/example_projects*. It did not have the
*updatelayers* as a subcommand. Nor does it have the *importlayers* or
*fixsitename* subcommands. The version of the file is 1.6.11
Am I missing a newer version of the script or is there another way of doing
this?
I installed via the quick install on ubuntu 14.04.
Thanks in advance,
Arthur
Arthur Abbott
GIS Technician
Seaforth Geosurveys Inc.
300 Prince Albert Rd., Suite 200
Dartmouth NS Canada B2Y 4J2
P: (902) 468-3579 ext. 232
F: (902) 468.6865
www.seaforthgeosurveys.com
Notice this communication, including any attachments, is confidential and
is intended only for the person or persons to whom it is addressed. If you
have received this e-mail in error, any use, copying or distribution is
strictly unauthorizes and you should delete it and any attachments. Please
also notify the sender by e-mail or telephone at 902-468-3579. Thank you.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160503/11a4b9ca/attachment-0001.html>
More information about the geonode-users
